Question about Matrix T3Xi Treadmill
Belt not moving when turning treadmill on
Turning treadmill on, belt doesnt move even when setting the speed. then the red light by the stop botton comes on. belt never does anything and no error code as well
Possessed Treadmill!
Your problem is your motor controller is blown out. This happens when you don't replace your walking belt routinely. You'll need a new belt and a new controller. Depending on the model of treadmill you have the parts could range between $250-$400.
Jun 11, 2017 | Proform Treadmill with iFit Live
I currently replaced the walking belt on my C954i/C956i treadmill. When I plugged it back in and turned on the power, the treadmill has no power. What could have happened?
Dear Sir:
I can read you trouble, and follow the next steps:
ALIGNING AND ADJUSTING THE RUNNING BELT
The correct alignment of the running belt is critical to the smooth operation of the treadmill. The belt is properly aligned at the factory. However, during shipping and handling or by use on an uneven surface, the belt may move off center and require a few simple adjustments. Before aligning the running belt, check its operation by following the procedure in Checking the Alignment of the Running Belt. If you determine that the belt needs alignment, follow the instructions here. CAUTION: Special care must be taken when aligning the running belt. Turn OFF the treadmill while adjusting or working near the rear roller. Remove any loose clothing and tie back your hair. Be very careful to keep your finger or any other object clear of the belt and rollers, especially in front of the roller and behind the deck. The treadmill will not stop immediately if an object becomes caught in the belt or rollers. Realigning the belt takes a few simple adjustments. If you are unsure about this procedure, call Precor Customer Support (see Obtaining Service.) Take the following steps to align the running belt on the treadmill. To ensure your safety, make all adjustments while the treadmill is OFF. 1. Make sure the treadmill is OFF and the running belt has completely stopped. 2. Locate the right belt adjustment bolt in the rear end cap of the treadmill. (To determine left and right, stand at the rear of the treadmill and face the display.) See Diagram 24. The direction you turn the bolt depends on how the belt is tracking. Make all belt adjustments on the right rear corner bolt using the hex key provided. • If the belt is off center to the RIGHT, turn the adjusting bolt ¼ turn clockwise, which moves the running belt to the left. • If the belt tracks off center to the LEFT, turn the bolt ¼ turn counterclockwise; this moves the belt to the right. Important: Do not turn the adjusting bolt more than ¼ turn at a time. Overtightening the bolt can damage the treadmill. 3. Turn the unit ON. 4. Stand beside the treadmill and press QUICKSTART. 5. If you are prompted for a password, press INCLINE ??¼, SPEED ??¼, SPEED ??². The running belt starts automatically after the 3-second countdown appears on the display. 6. Press the SPEED ??² key until the display shows a speed of 3 mph (5 kph). 7. Walk around to the rear of the unit and observe the running belt for a few minutes. The belt should run centered along the running bed. If the belt drifts off center, you will need to make adjustments. CAUTION: If you hear any chafing or the running belt appears to be getting damaged, stop the running belt immediately by pressing the red STOP button. Contact Precor Customer Support. 8. If the belt needs additional alignment, repeat steps 1 through 7 until the belt is properly aligned. 9. After aligning the belt, press the STOP button and RESET. Turn OFF the treadmill. Tighten any loose fasteners or other components on the equipment. If you hear unusual noises or you feel that the treadmill is in need of repair or service, contact Precor Customer Support. Refer to Obtaining Service.
Finally, check if the power cord is loose, connect it again. a) See if the breaker of Home is tripped? b) See if the breaker of the Treadmill is tripped. If do the Belt is very Tighted! loose a little. Try again.
Thank you in advance, if you need assistance, you can contact me, Blessing. sincerely.
E. CUADRA Managua, Nicaragua. C.A.
Sep 26, 2011 | Precor C954i Commercial Treadmill
My T81 treadmill quit working. All of the lights and bells and whistles all work but the belt doesnt move and the incline doesnt move. Ive only had it for about 2 years. It was working fine before I moved...
you need to check voltage going to the motors. no power ,the contoller board is not working. check the connections on the boardmake sure they are in all the way,also the power connections
Mar 17, 2011 | Horizon T91 Treadmill
The treadmill will sometimes start and most times will not, even though there is still power. Then I will be on and the belt will stop turning. I can move the incline level but that is all.
With the motor cover off and the power on, make sure there is a red light/led lit on the controler, if yes then press the start button then press #3 on the speed side. If not lit, you dont have power to the controller. If you had a red light, and pressed the speed button, the light should start flashing just before the walk belt starts to move. If the speed button is pushed and the light on the controller does not flash, you have a problem in the console. This is only fixed by replaceing the controler.
Sorry.
Hope this was at least helpfull, Matt
Dec 30, 2010 | Reebok Acd1 Treadmill Motor Control Board ...
Will not move belt
Press the Stop and the Speed Up keys down while inserting the safety key.
Press the Stop key one time. The Time window should read EP:2P. Some newer models may also say FP, Pass, or the like. This means that it passes the EPROM test.
Press either incline key and the incline will calibrate automatically.
BE CAREFUL, THE TREADMILL WILL RUN AT FULL SPEED IN THIS NEXT MODE! DO NOT STAND ON THE WALKING BELT. Press the Speed Up key and hold it down until 85 is shown in the Distance window (some models may show the 85 number in another window).
If the top speed of the treadmill does not match the displayed speed on the computer console, adjust the max speed potentiometer (pot) on the motor control board. This is the board that the red and black motor wires connect directly into in the motor area. The Max Speed pot is clearly labeled. The max speed potentiometer is a small square with a mobile center and is located in one corner of the board and is labeled MAX SPD. It is near the harness that carries the speed signal labeled H,W,L. Using a small insulated screwdriver adjust this potentiometer clockwise to speed up and counter-clockwise to slow down the max speed of the treadmill. A tiny turn of this potentiometer will make a big difference in speed so be careful when making adjustments. It is not important to get the speed set exactly at the max speed of the treadmill but do make sure to get the speed within .2 MPH of the max speed of the treadmill. For instance if the max speed of the treadmill is 10 MPH, make sure to have the speed set between 9.8 MPH and 10.2 MPH. Some models have a 12 MPH top speed, so please check your manual if you aren’t sure. THIS IS A VERY IMPORTANT STEP BECAUSE YOU WILL GET AN ERROR MESSAGE IF THIS STEP IS SKIPPED. After completing calibration of the speed, press the Speed Down key. The treadmill will automatically return to 0 MPH. Please allow the unit to stop completely before continuing. Press the Stop key once and remove the safety key.
May 27, 2010 | Proform 560hr Treadmill Walking Belt
Belt won't move
does is just not move when you're standing on it, or not even move when you're not standing on it. It may be a simple belt adjustment or if the motor is running but there's no track movement you may be looking at a loose/broken drive belt. Take the cover off, start it up and look at the motor/drive pulley assembly. If the motor turns and the front roller doesn't, tension the drive motor by moving it back. If the front roller turns but the track doesnt, do a track adjustment as per your users manual.
May 26, 2010 | Proform CrossTrainer Treadmill
Tredmill not moving
That's an embarrasing admission. A treadmill works like a conveyor belt or a car's fan belt. If it is too loose it will slip under load. There will be an ajuster on your treadmill. All you have to do is tighten the belt. Do not overtighten it though. an
Feb 17, 2010 | Cadence Weslo 825 Treadmill Walking Belt
Horizon treadmill won't start running
The manual said that after lubricating the deck, press Stop and Speed buttons together for 5 minutes and this will reset the lubrication message and the treadmill should work.
Jan 25, 2010 | Horizon Exercise & Fitness
Manual Treadmills vs. Motorized Treadmills
Treadmills come in two basic varieties, just like lawnmowers: manual and motorized. But, unlike a lawnmower, you will generally get a better workout from a motorized treadmill. Manual Treadmills - Getting Going On a manual treadmill, the action of your feet against the deck moves the belt. Pros * You provide all of the motive power and exercise your lower body. Cons * It can be difficult to get the belt moving intially. That straining against the belt can stress your joints. * You may have to raise the incline of the treadmill significantly to make it easy enough to get the belt moving. * Once the belt is moving, however, you would have to stop and get off to change the incline, so you are stuck with one incline level during each workout. Motorized Treadmill Advantages * The belt is moved by the motor, you don't have to strain to start it. * On many treadmills, you can adjust the speed and incline while you are still walking or running. On others, you may have to get off and adjust the incline manually, but you just have to turn on the treadmill to start the belt again. Manual Treadmills - Speed With a manual treadmill, you go only as fast as you push yourself. If you slow, it slows. If you stop, it stops. Motorized Treadmill Speed and Workouts The speed is adjustable and many motorized treadmills have workout programs that adjust the speed to give you a varied workout. This pushes you to go faster. The constantly moving belt of a motorized treadmill motivates you to keep up. Costs Manual treadmills are relatively inexpensive, in the $100-200 US range. Motorized treadmills for home use cost from $750-$5000, and generally the more you pay, the better you get. Most motorized treadmills under $1000 have underpowered motors and are less sturdy and have fewer options for adjusting the incline, programmed workouts, etc.
Dec 01, 2008 | Endurance TF3i Folding Treadmill
Matrix T3Xi Treadmill Logo
24 people viewed this question
Top Matrix Exercise & Fitness Experts
Electro Med Services...
David Payne
David Payne
greg kinsley
Are you a Matrix Exercise and Fitnes Expert? Answer questions, earn points and help others
