Question about Maytag Dishwashers
KEYPAD BUTTONS STUCK
THE HEATING ELEMENT STAYS LIT AND ON NUMBER 3. REPLACED THE CONTROL PANEL WITH TOUCHPAD AND MADE NO DIFFERENCE
  • 1,511 Answers
The touch pad sends a signal in sequential orientation that starts and stops various functions. When the controller sent a message to the heater coil to disconnect it failed to negotiate the command. The problem therefore is the electronic switch in the heater circuit. It could also be as simple as a temporary short due to moisture buildup on sensitive electronics and connections. Check all internal wiring for disruption or damaged insulation.
Posted on Mar 18, 2014
SOURCE: Dishwasher Heating element not working
my wife shut the water off to the dishwasher and forgot to turn it back on and then used the dishwasher.
the heating element went on but there was nop water.
when we turned the water back on,the drying cycle does not work.i would think that the element needs to be changed or is there a relay on the computer board?
this is a two year old Jennair unit.
any suggestions?
Posted on Apr 29, 2008
Benimur
  • 6966 Answers
SOURCE: Whirlpool Quiet Plus Dishwasher
Hi again,
Lost you on the Live Session. Have you checked the bottom plate/panel? We need to determine the error code by entering the diagnostics cycle. How you enter it varies by model. the machine's tech sheets should be located on the dishwasher somewhere, usually on the back side of the bottom kickplate.
In some models, probable fault are:
  • door latch (likely);
  • heating system (most likely).
Incidentally, there was a recall order on some Whirpool models due to the heating system.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Oct 27, 2008
SOURCE: Stays in wash cycle Whirlpool Dishwasher Du1050SS
my repairman contacted whirlpool about my washing machine staying on
wash.. to his surprise.. and mine.. and his co=workers.. this is the answer,
it worked.. and we have never heard this before.
In your original istallation booklet it tells you to let the dishwasher run til its complete
the first time you use it as it may rinse twice... my original installation man told me this also.
however.. if you suffer a "blip" in your electricity.. it could put the little dishwasher "brain"
out of whack.. it can run as long as 3 to 4 hours on wash to reset itself.. if you stop it
(like others have mentioned.. and which I did also).. it doesn't complete the reset and it
will attempt to do it the next time..
answer?.. just let it go once as unnerving as this is.. it works.. They did mention that
if it went to 5 hours.. call your repairman because you need a new mechanism.
karen in Dothan
Posted on Apr 03, 2009
Macmarkus
  • 2605 Answers
SOURCE: HAVE ERROR CODE E1, WATER IS NOT HEATING UP . NO
Macmarkus Rank: Guru bosch.gif dishwashers_small.png
Rating: 98%, 1499 Votes
Welcome to FixYa.
The error code on your Bosch indicates a heating fault has been detected. To determine why you'll need to run a diagnostic program and perform a couple of test's. I can provide the data of what to look for but you will require a multimeter...preferably one that includes a "clamp on" ammeter to measure current or the amount amps being drawn.
First to enter the diagnostic...
To interpret errors,
Then finally the test to determine if you have a faulty heater or a control...it's typically the heater relay on the control itself.
Let me know what you make out of this info or if any of it is not clear you can post your email address and I'd be happy to send you the entire service manual as an attachment to an email.
Thanks for choosing FixYa and good luck. If this indeed was all the info you require or solved the problem please take a moment to rate the info when you're completed.
Thanks again,
Regards,
Macmarkus :)
Posted on Nov 14, 2010
Macmarkus
  • 2605 Answers
SOURCE: Asko D1776 - Heating element stays on after the
Welcome to FixYa.
Based on your description it is likely a faulty control board, unfortunately. Here's what you can do to check...
**Turn off any power to the unit...safety first**
You'll need to access the control, this is best done by way of removing the front panel, i.e.
Once to this point, identify the wires on contact PF2 and inspect the closest relay to it, which will be K1.
If you are capable, measure amperage from PF2 when the unit is idle there shouldn't be power present, you'll require an ammeter.
Having said all that, it may be obvious when you visually inspect the control, if it's burnt up or if the relay looks burnt inside.
This is an example of a damaged control but it may not be as extreme with a heater relay defective...
Let me know what you find and I'll try to help you further if necessary. For the control should be available at "repairclinic.com"...but if not let me know I may have one left.
Good luck and thanks for choosing FixYa.
Regards,
Macmarkus :)
Posted on Nov 17, 2010
Have a Miele G1220SC dishwasher. It recently developed a strange problem: when switching it on ALL program lights come on and the machine starts taking water. after a while it stops taking water and starts...
follow this steps and fix it. God bless you
Heating Element
If lights are flashing on the control panel, the heating element might have burned out. The heating element heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element can be checked for continuity with an Ohm meter.
Heating Element Assembly
If lights are flashing on the control panel, the heating element assembly might have burned out. The heating element assembly heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element assembly can be checked for continuity with an Ohm meter.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Check Fault Codes
If the display lights are flashing and there is an error code in the display window, check the wiring diagram and tech sheet in the dishwasher that will provide information on the fault.
Drain Pump
If lights are flashing on the control panel, the drain pump might not be working properly. For two-wire drain pump motors check them for continuity using an Ohm meter. If it's defective You'll need to replace it. Drain pumps are not repairable.
Touchpad and Control Panel
If the lights are flashing on the display the entire touchpad and control panel assembly might be defective. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced.
Touchpad
If the display lights are flickering for no reason, the touchpad might need to be replaced. Sometimes when the touchpad is defective the display lights are flashing randomly.
Jul 30, 2013 | Miele Dishwashers
I have a Fisher&Paykal DD6031 drawer dishwasher. Stopped running mid cycle. Lights flashing on drawer front green,red,yellow,red green,red,yellow . I don't know what that code means. On the inside Heavy...
follow this steps and fix it. GOD BLESS YOU
Heating Element
Check Fault Codes
Drain Pump
Touchpad
Jul 30, 2013 | Fisher and Paykel 24 in. DD603H W Built-in...
My Hotpoint DWF40 Dishwasher flashes wash and rinse lights. Water fills and drains fine. How do i fix it?
test this and fix it. God bless you
Heating Element
Check Fault Codes
Drain Pump
Touchpad
Jul 24, 2013 | Dishwashers
G 2582 scvi
make this test and fix it. God bless you
Heating Element
Check Fault Codes
Drain Pump
Touchpad
IF THE MACHINE START IT SHOWS FLASH AFTER 2min
test this steps and fix it. God bless you
Heating Element
Check Fault Codes
Drain Pump
Touchpad
Jul 22, 2013 | Dishwashers
Whirlpool quiet partner iii pots & PANS LIGHT flashing
test the steps and fix it. God bless you
Heating Element
Check Fault Codes
Drain Pump
Touchpad
Kenmore dishwasher clean button constantly flashing ,washer has been unplugged ???maybe reset itself did not work. 2 yrs old
please follow this steps and fix it. God bless you
Heating Element
Check Fault Codes
Drain Pump
Touchpad
Jul 09, 2013 | Dishwashers
Why won't my Kenmore dishwasher display work properly?
Heating Element
Check Fault Codes
Drain Pump
Touchpad
Dishwasher Siemens /se64m359gb tap light comes on in red on main display,what does this mean?
Heating Element
Check Fault Codes
Drain Pump
Touchpad
Jul 08, 2013 | Dishwashers
Selection Buttons on GE Cafe Dishwasher
see this causes and fix it. God bless you
Drain Pump If lights are flashing on the control panel, the drain pump might not be working properly. For two-wire drain pump motors check them for continuity using an Ohm meter. If it's defective YOU'LL need to replace it. Drain pumps are not repairable.
Heating Element If lights are flashing on the control panel, the heating element might have burned out. The heating element heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element can be checked for continuity with an Ohm meter.
Heating Element Assembly If lights are flashing on the control panel, the heating element assembly might have burned out. The heating element assembly heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element assembly can be checked for continuity with an Ohm meter.
Touchpad and Control Panel If the lights are flashing on the display the entire touchpad and control panel assembly might be defective. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced.
Touchpad If the display lights are flickering for no reason, the touchpad might need to be replaced. Sometimes when the touchpad is defective the display lights are flashing randomly.
Check Fault Codes If the display lights are flashing and there is an error code in the display window, check the Error Codes guide on our website to determine which component has failed or is failing
Oct 02, 2012 | Dishwashers
Dishwashers Logo
53 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
