Question about Canon MV630i Mini DV Digital Camcorder
Fast forward & reverse buttons don't work
Put camera into play VCR press focus button film comes on screen. stop film with the AE shift button, try to fast forward the film on the + button no good. try to reverse fast - button no good. have a remote control that works both buttons. please help if you can Joe.
  • 57 Answers
Well the foil contacts are shot but it has a lanc input to remotely control the camera from a external wired land controller if you can find one on e bay
Posted on Jun 02, 2014
sonysonyman
  • 68 Answers
SOURCE: Canon ZR300 record button no longer works
hi sir just two things to do first 1- restore to factory setings from the menu and check if it is solved 2- if not just try to see does the knub is in its reguler state if yes so you need to replace it
Posted on May 08, 2007
  • 883 Answers
SOURCE: Eating Tape when rewinding in vcr mode
look for a tiny pinhole and insert a pin while powered up to reset the device. if no-go, then the take-up reel needs attention...needs possibly a new or well-cleaned-with-alcohol-swab rubber belt
Posted on May 27, 2007
SOURCE: Canon XH-A1 Menu Button...
Just b f it....
Posted on Aug 19, 2008
Wolfman304
  • 720 Answers
SOURCE: Canon gl1 - no picture in the fold out lens
By placing the POWER switch into CAMERA mode, you will then be able to press the MENU button, and access all camera adjustments....including the LCD function.
Posted on Dec 03, 2009
SOURCE: When I turn on the camera, nothing happens and the
i know exactly whats wrong! the same thing happend to me.
1. turn off the gl1 2.look at the record button with the lock and standby switch 3.flip the switch all the way to standby because it might be stuck in the middle 4. turn on your camera
Posted on Feb 01, 2010
How get menu to show language option
Press the vcr button then press menu,press the play or stop button to select vcr set up,then press the fast forward button.Press play or stop button to select language,then press the fast forward button.Press the play or stop button to select English or Spanish.Then press the status exit button.Hope this helps.
Oct 11, 2014 | Philips VR620CAT VCR
How can I set the channel BACK to CH 3 from CH 4
1) Set your TV to channel 3.
2) Insert a pre-recorded tape into this unit.
3) Press the OUTPUT button on the DVD/VCR so that the VCR OUTPUT light is lit.
• If noise appears on the TV screen, press the VCR/TV button on the remote control.
4) Press the PLAY button once.
5) After a few seconds, press the PLAY button on the DVD/VCR for 3 seconds.
• The RF output channel will change to channel 3 from channel 4 and you will see a playback picture.
• When a picture does not appear on the TV screen, repeat step [4].
6) Press the STOP button to stop playback.
Nov 17, 2007 | Emerson EWD2004
How do you program into the dvd that you want it to fast forward quickly? There is a way but am not sure how it is done.
You don't, you just press the FORWARD button on remote during DVD playback to 'fast forward' (pressing this button a second time during playback increases forward scan speed). The forward and reverse buttons have 'SLOW/SEARCH' printed above them on the remote. The other buttons next to them are the PREV/NEXT buttons (SKIP/INDEX).
DVD playback speed/skip/search is mostly a manual user function; it cannot be auto set.
May 16, 2011 | Panasonic DMR-EZ47V DVD Recorder/VCR
Hi , I have a Canon AE-1 camera and I'm haviving a problem with the film advance lever . It seems to be stuck . It will not advance. Have you ever come across this problem before? Thanks ,John.
Canon AE-1 35mm SLR is a manual focus camera EOS is Canon's designation of auto focus EOS stands for Electro-Optical System. The problem you are experiencing is caused by several little things that throws the camera, wind and cocking leaver out of synchronization or simply come to the end of the roll. There is a frame counter window just to the left of the shutter release behind the shutter speed dial. Also if you have just loaded film in the camera it may not be seated correctly check by releasing the rewind button, wind the film back but not all the way and open the camera to restart the film.
Diagram
Mar 03, 2011 | Canon EOS-AE-1 35mm SLR Camera
Operating instructions for dsr pd177p sony video camera. I am not in postion to operate the camera, please guide how to operate the camera.
It is not very easy to say few lines to tutor ,but learn to use only by experience.Put the battery on for charging.Once fully charged slide the power switch to camera.Open the lens cap ,open the view finder display.Now you can see the picture on your screen.Set the camera to auto focus.show the camera to a white screen so as to white balance the camera.Now point at an object and do a trial Zooming using the auto zoom with your finger.The image will come closer and you can draw it to white screen.Having an object in view on the white screen,press the record button.Slowly move the zoom forward to get the right frame of the object.Press reccording button once again to stop.Repeat the process on different scenes.
Now shift the mode switch to play and rewind and play the reccorded portion.Practice.
Sep 02, 2010 | Sony Dvcam DSR-PD150 DV Digital Camcorder
How can i watch video from Samsung s1050 in my computer?
Hi, Here is the procedure on how to play the video clip on your camera. Play mode If you have turned on the camera by pressing the POWER button, you can press the PLAY MODE button once to switch to Play mode and press it again to switch to Recording mode. You can turn the power on with the play mode button. The camera is turned on in play mode. Press the play mode button again and the camera will be turned off. You can set up the PLAY mode function by using the camera buttons and LCD
monitor. Playing back a still image
1. Select the PLAY mode by pressing the play mode button.
2. The last image stored on the memory is displayed on the LCD monitor.
3. Select the recorded movie clip and press the Play & Pause button to play back.
- To pause a movie clip file while playing it back, press the play & pause button again. ac0dd93.png
- Pressing the play & pause button again will cause the movie clip file restart.
- To rewind the movie clip while it is playing, press the LEFT button. To fast forward the movie clip, press the RIGHT button.
- To stop playback of the movie clip, press the play & pause button, and then press the LEFT or RIGHT button. 0e83d9c.png
Apr 13, 2010 | Samsung S1050 Digital Camera
How do I use the index mark function?
Index marks work when the record function is activated, it puts a signal at the start of the recording. So when you put several tv shows on one tape, you can find them. Most video's have a scan button or index button, sometimes it's on a menu. When activated the video will go into fast forward or reverse till it finds an index mark. It will then go into play mode. Some videos will stop playing after a short period and the start searching again, unless you press play. Others have index numbers so you can search for the third recording for example. Commercial videos films etc do not have index marks on.
Feb 24, 2010 | Samsung Televison & Video
VIDEO STARTED PLAYING BACK ONLY IN HIGH SPEED W/O VOLUME,,,,,,,CHANGED SPEED OUT OF NOWHERE.....PLZ HELP! I'M USING CANON G9
I EASILY FIX'D THIS PROBLEM & FOUND OUT I CAN DO SOOOOO MUCH WITH SHOOTING VIDEO'S! I DID A GOOGLE SEARCH & CAME ACROSS THIS ADVICE.......TURN THE TOP DIAL ONTO VIDEO ON TOP OF CAMERA. THEN TURN DIAL ON RIGHT SIDE & YOU WILL SEE DIFFERENT SCREENS SUCH AS BLK & WHITE, VIVID COLORS, FAST OR SLOW SPEED; I TURNED MINE TO AUTO & PRESSED FUNC BUTTON IN CENTER OF WHEEL & I WAS BACK TO SHOOTING IN NO TIME........HOPE THIS HELPS!!
Jun 20, 2009 | Canon PowerShot G9 Digital Camera
Remote problem
Hi There,
On the front panel:
REV Button (DVD)
Press to view the DVD picture in fast reverse motion
or to reverse playback of an Audio CD.
Press to skip Chapters or Tracks.
FWD Button (DVD)
Press to fast forward the Disc. Press PAUSE, then
press this button to begin slow motion playback.
Press this button repeatedly to change the forward
speed of slow motion.
I hope this helps,.
If not, feel free to conact me.
Thanks,
Mike
Nov 03, 2008 | Emerson EWD2203 DVD Player/VCR
Canon MV630i Mini DV Digital Camcorder Logo
42 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
