Question about Measuring Tools & Sensors
2002 ford windstar
This light just came on what does it mean?
    Problem Solver:
  • 5 Answers
Theres a light burnt out on the old vanborghini like a headlight or brake light
Posted on Mar 19, 2014
Ford windstar 2002 problems
that could mean that your water pump impeller is broken. when you press the gas the remaining piece of the impeller is pushing the water and it actually makes it to the heater core. at idle it isn't spinning fast enough. ask a local autoparts store if the impeller is made of plastic.
Apr 02, 2014 | 2002 Ford Windstar Cargo
Dashboard light
It means one or more of your tires have low air pressure!
Check and adjust pressure.
Some cars (like mine) have the spare tire connected to the system also, so check all five.
Aug 06, 2013 | Cars & Trucks
CHUGGING ALONG WITH FLASHING CHECK ENGINE LIGHT....???? 2002 FORD WINDSTAR WHERE TO BEGIN
A flashing Check Engine light means you have a ignition Misfire, start by replacing the spark plugs and spark plug wires, one or more is defective. If you have a electronic engine control fault code reader the cylinder or cylinders that are misfiring will set a fault code, the codes are P0300-P0306, the last number being the number of the cylinder ( cylinders 1-6) the computer has detected a misfire in.
Apr 18, 2011 | 2002 Ford Windstar Cargo
Why does the abs light and brake light come on randomly on my 2002 ford windstar
In my windstar i had the same poblem, it was a broken wire by the front wheel, for the wheel speed sensor, mine was on the pas side, but either one could do it, just remove the tire and inspect the wires to the wheelbearing
I hope this helps you, please help me by leaving feedback, thank you
Oct 27, 2010 | 2002 Ford Windstar Cargo
2002 windstar dash lights dim temp and info.
poor battery connection or poor voltage output from alternator. many stock and rebuilt alternators for this model have defective voltage regulators. I have replaced 15 this year alone :)
May 12, 2010 | 2001 Ford Windstar
I HAVE A 2002 FORD WINDSTAR AND THE CHECK CHARGING SYSTEM LIGHT CAME ON. WILL THIS BE A MAJOR REPAIR? WHAT DOES THIS MEAN. HELP
alternator brushes have worn out and possibly the commutator as well,just renew with an exchange unit
Dec 27, 2009 | 1998 Ford Windstar
How to reset oil for ford windstar 2002
I am assuming you mean the dash oil light symbol? this can be reset by a mechanic with a code reader, he can check and reset them for you, most don't charge just to have a look and he can tell you why it came on too. Good luck
Nov 20, 2009 | 2002 Ford Windstar Cargo
2002 ford windstar lx front passenger window does not work. Checked fuse 106, not blown, what next?
Turn on interior lamps and watch lamps while working switch, if lamps dim and no noise is heard in door ( like crunching sound) you need to replace window motor, if noise is heard you have a failed window regulator.Lights do not dim you may have a bad switch. You can also try to hit in center of door panel to see if window will start working which also means bad motor. Hope this helps.
Jul 26, 2009 | 2002 Ford Windstar Cargo
2002 windstar with po133 and po153 codes
do you have the meaning for the codes? if you do please descrive it, it will help a lot
May 30, 2008 | 2000 Ford Windstar
Measuring Tools & Sensors Logo
571 people viewed this question
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
