Solaris 9 I use an HP750C running from a Sun Microsystem Sparc station with Solaris 9. The plotter is tired and needs replacing. As the HP T520 is reasonably priced and uses the same HP-GL/2 language as the old unit, do you think there will be problems doing the swap. I am not at all proficient in the use of Unix code.
  • 3,320 Answers
The only question is if your software runs on the HP.
Posted on Mar 21, 2014
Adobe acrobat distriller 3.0
SYSTEM REQUIREMENTS
Perl 4 or later installed on any of the following systems:
IBM AIX 4.2 or 4.3 with IBM?s Y2K patch installed
HP UNIX 10.x or 11.x with HP?s Y2K patch installed
Sun 5.4/Solaris 2.4 with Sun?s Y2K patch installed
Sun 5.5/Solaris 2.5 with Sun?s Y2K patch installed
Sun 5.6/Solaris 2.6 with Sun?s Y2K patch installed
Sun 5.7/Solaris 2.7
18 MB of hard disk space for Acrobat Distiller
32 MB RAM
INSTALLATION INSTRUCTIONS
The Acrobat Distiller 3.02 for UNIX Y2K Patch consists of two files:
-the distill file, which is the Distiller startup script.
-the distill.y2kfix.pl file, which is a Perl script that is invoked by the Distiller startup script.
To install the Acrobat Distiller 3.0.2 Y2K Update:
1.Make a backup copy of the distill file, which is located in the Distiller 3.02 installation directory. For example: cp distill distill.bak
2.Copy the distill file and the distill.y2kfix.pl file included in the archive to the Distiller 3.02 installation directory.
3.Make sure that the distill.y2kfix.pl file has execute permissions. For example:
chmod a+x distill.y2kfix.pl
4.Modify line 1 of the distill.y2kfix.pl file so that it contains the pathname to the Perl interpreter installed on your system.
5.Modify line 16 of the distill file so that the "install_dir" contains the pathname to the Acrobat Distiller 3.02 installation directory.
Oct 29, 2014 | Adobe PageMaker 7.0 for PC
Does ColdFusion 11 have 64-bit support?
Yes. ColdFusion 11 can run as a 64-bit application on the 64-bit versions of Microsoft Windows, Sun Solaris, Linux, and Mac OS.
Oct 09, 2014 | Adobe ColdFusion 9 Standard Full Version...
Good day. Need a driver for SMC Sun PCI Quad Fast
Please be informed that any Driver Software depends upon its Hardware make and Operating System support. You need to know all these information to get started working with that particular hardware. You can find the driver software inside the disc provided to you at the time of purchase.
As per your query i have checked a lot of technical sites and even Sun microsystems,but I found that this network device can not be installed in a windows platform as this only supports Solaris Operating System.Please find the detail here http://docs.oracle.com/cd/E19113-01/quad.fast.sbus/804-6116-10/804-6116-10.pdf
The Sun Quad FastEthernet SBus adapter is supported on systems running the Solaris operating environment, versions 2.4, 2.5, 2.5.1, 2.5.1 Hardware releases, and 2.6. The Sun Quad FastEthernet PCI adapter is only supported on systems running the Solaris 2.5.1 Hardware releases and Solaris 2.6.
Nov 24, 2011 | SMC Sun PCI Quad Fast Ethernet Card (p/n...
Hello sir, my problem is i want install windowxp window7 and sun solaris 10 use kinston pan drive but i am trying after i have failed please tell me, how can i do and please complete solusion, ...
Hello sir, to install window xp and 7 using a kinston pen drive you will to have a software called win to flash. Its a software that allows you to install window 7 and xp from a pen drive and for the sun solaris you also need a software called unetbootin that allows you to install solaris using a pen drive. You can google these softwares to download them for free. I hope this solution is helpful. Have a wonderful day.
Oct 23, 2010 | Computers & Internet
How do I install sun solaris from a grub prompt when I boot off the setup cd
A grub prompt is most likely coming off the hard disk where you're attempting to boot.
Restart the machine and adjust the bios settings so that the PC will attempt to boot from the CD or DVD drive before attempting to use the hard disk.
It's possible that you may need to burn a new image of the sun solaris ISO. That may be where you need to get help, if your system doesn't seem to be able to boot from this CD but CAN boot from others.
Jan 23, 2010 | Sun Solaris 10 3/05 (SOLZ910AC9A7M)
Which intel Mboard DG31PR or DG41RQ is compatible with solaris10
As long as it's either Intel or SPARC (Intel in your case), Solaris will install just fine as long as you meet the minimum requirements.
Aug 01, 2009 | Intel DG31PR Motherboard
Solaris 9 SPARC doesn't work with Maxoptix T4-2600 disks
You must using solaris format utility to label thies T4-2600 drive. And you must put 512byte/sector MO disk into drive. for example:
1.$ su - root ;Become root user
2. # format ; identified disk
3. choose disk
4. label disk
5. if type unknow please input : type
6. choose T4-2600
7. label
8. modify disk partition
9. newfs ; ex: newfs /dev/dsk/c1t0d0s0
10. mount disk
11. using MO disk like HDD
Mar 26, 2009 | Computers & Internet
Redhat es5
This model was found not to be 64bit but 32bit.
May 18, 2008 | HP Compaq ProLiant DL380 G4 Server
Computers & Internet Logo
14 people viewed this question
David Payne
David Payne
