Cant get child lock off beko wm5100w
No response from bu ttons..think lock is on but do't know how to turn it off
SOURCE: beko wma 765s 7kg 16000 rpm
Press quick wash and anti creas at the same time. This should unlock it
Posted on Feb 03, 2008
SOURCE: BEKO WM5100W The pre wash light is flashing
hi - mine's just done this too; press and hold the two buttons above the padlock symbol until the light goes out. voila! that cost me 35 quid to an engineer but it's free to you... cheers!
good luck
Posted on Apr 29, 2010
Testimonial: "Thanks"
  • 327 Answers
SOURCE: cant get child lock off
Hello,look for a button with possibly a lock emblem beside it ..usually has to be held down 3-5 sec to unlock.
Thanks
Posted on May 23, 2010
blueextc3221
  • 15935 Answers
SOURCE: i have got a beko
This advise is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
This may or may not be an indication of a serious problem. In the majority of the cases, this is a simple operator error. Nearly all these model appliances have some sort of Control Lock feature on the front panel now. This is a designed safety feature that is used to prevent small children from manipulating the controls. The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
These instructions may not be all inclusive for all Kenmore and Whirlpool models, but they are the most common. Chances are, if you have a Control Lock feature, the instructions will be printed on the front panel adjacent to the button that is required to lock or unlock the controls.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Fridgidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your sepcific model.
If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 14, 2010
SOURCE: i have a beko wm5100w
Hi, I have just come back from holiday. I turned on my beko washing machine,power comes on and when it starts it switches off the main electric box.before i went away i turned off the main electric box. Is the machine broken and if so expensive job?
Posted on Dec 11, 2010
Forty cycle takes some water in then stops
Beko WM5100W Washing machine wash/spin problem ...
? 3:59
https://www.youtube.com/watch?v=rih6H1cpu9Q
Jun 12, 2012 - Uploaded by ilona ilona
problem in washing cycle. fast spin for few seconds and cut off .... I have same machine, it starts up fills half way with water then stops :'.
Washing machine stops mid cycle - White Goods Help
www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
Jan 10, 2016 | Beko Wm & Wma Models Washing Machine Motor...
I have beko 91442 lx and can get it to start. All lights etc on. Thought it might be child lock but can seem to get it on or off. What can I do please
i think it refers to elec-card
1- first unplug the machine for about 10 min
2- plug the machine and start short program
if led are on please specifies which led are lighting !!
thank you
Nov 21, 2014 | Beko Wm & Wma Models Washing Machine Motor...
Beko washing machine
Try letting the program run through
and see if that clears the problem sometime it will if not holding the power button for a wile should re set it
Jan 23, 2014 | Washing Machines
BEKO WM5100W , DRUM NOT SPINNING DURING WASH CYCLE
It could be carbon brushes or electronic fault.
Do you have ability to check carbon brushes?
Feel free to ask if you dont know how to do it.
Apr 07, 2013 | Beko Washing Machines
Hello, I have a beko wm5100w and it seems to be stuck trying to pump out water. I have cleared the filter and pipes, but now I need to reset the machine. I have done the "switch off, turn to 90...
It could be a faulty thermistor (showing high temperature)
or water sensor fault that is causing the pump to run.
Just try and unplug it for 3-4 hours, and see if it resets itself,
if not replace sensors, and if that does not work, replace the main board.
Here is the manual:
http://laundry.manualsonline.com/manuals/mfg/beko/wm5100_1.html?p=21
This is the actual reset/diagnostic mode
https://www.youtube.com/watch?v=8C4J3leArY0
https://www.how-to-repair.com/help/beko-wm5100w-wm5100s-test-mode-and-error-codes/
Sep 05, 2017 | Zanussi F1045W Front Load Washer
I have a beko wm5100w washing machine and it keeps tripping the electricity
Nov 25, 2010 | Washing Machines
Beko WMA 510 stuck on cycle
Hi if your beko WMA 510 washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
Also check all waste pipes are clear and inspect the pump I have included this video below.
At our website I am doing self diagnostic videos on these beko's as we speak so all tutorials will be in this link below
How to replace Beko Washing Machine Motor Carbon Brushes
you might find this test video helpful but only do it if you have checked the motor
Sep 05, 2008 | Indesit W 123 Front Load Washer
Washing Machines Logo
19 people viewed this question
Top Washing Machines Experts
