Question about Confidence Gtr Power Pro Motorised Treadmill
Where can I get a manual?
Received confidence gtr pro motorized treadmill today, open it, no instruction manual came with it.
Display is showing 3 dash marks. the treadmill will not come on at all. please help
You may have a control board failure, it must be checked by a repair tech.
Aug 31, 2016 | Confidence Gtr Power Pro Motorised...
We started hearing a clicking or ticking noise from the motor
Did you ever get an answer back for your question? I just received my 9700 Pro in late March 2015. After only 4 times using it I also have the clicking coming from the drive motor. It sounds like the motor bearings.
Mar 28, 2015 | Nordic Track Elite 9700 Pro Treadmill
How to tighten drive belt
Hi. The only way i can see is to adjust the roller screw on the opposite side of the main belt. Rubbish design. Then when motor belt is tight enough adjust main belt to run straight. Mine ended up running diagonal to stop the motor belt slipping. :(
Apr 07, 2014 | Confidence Gtr Power Pro Motorised...
Comment regler la distance
go to the MENU, read your owner manual or download from
www.fitness.manualsonline.com
God bless you
Oct 23, 2013 | Confidence Power Plus Motorized Electric...
How to incline
download your owner manual free go to www.fitness.manualsonline.comGod bless you
Apr 02, 2013 | Confidence Power Plus Motorized Electric...
My a2350 treadmill just stopped working - console and motor stopped
plealse LUBE the deck belt + rollers bearing too . you must do it after 150 miles aprox.
2) adjust the REED switch see the diagram, clean it, test for open or faulty. Tight the connector very well.
Jan 25, 2013 | Nordic Track NordicTrack A2350 Pro...
What does code 22 mean?
Error 22 - No Motor Pulses at Start Up
Description
Error 22 indicates that the drive motor (running belt) has been instructed to start, by either
manual or program control, and the monitoring system has not received any response from the
speed sensing system indicating that the drive motor has started.
Possible Causes
1. The treadmill utilizes an optical (infrared) speed sensor and the line of sight between the
speed sensor and the speed sensor target is obstructed.
2. Drive motor brushes are bad.
3. The speed sensor position relative to the speed sensor target is incorrect.
4. The speed sensor potentiometer adjustment is incorrect (when equipped).
5. The speed sensor is inoperative.
6. The lower PCA is bad.
7. The lower PCA to upper PCA interconnect cable is bad.
8. The upper PCA is bad
Jan 18, 2010 | Precor 9.21 Treadmill
Looking for instructions to remove belt from J8 pro-form treadmil
I have a proform j8li treadmill. What size allen wrench to I need to adjust the belts?
Danielg@jcnj.org
Thanks
May 03, 2009 | Exercise & Fitness
Confidence Gtr Power Pro Motorised Treadmill Logo
49 people viewed this question
Top Confidence Exercise & Fitness Experts
ray gallant
Electro Med Services...
Are you a Confidence Exercise and Fitnes Expert? Answer questions, earn points and help others
