Question about Konica Minolta bizhub C250 All-In-One Laser Printer
Colour shifting error p21
Colour shifing images registrations problem
  • 20 Answers
Color registration patterns not read correctly by sensors
Posted on Apr 01, 2014
How do i solve a p9 and p21 error code
You remove the PRINT HEAD????? DID YOU FOLLOW THE Service manual????????? Well you caused your own problem now you need to do a alignment. of the colors. you also might check the ribbon cable you removed and all the connectors you played with and check each one is secured. Recommend you don't ever remove the print head which houses the LASER unless you follow the service manual. Well you need to get to service mode and run registration procedures. try this site for a service manual or better yey have tech come out and run the required checks.
Service manuals electronic components datasheets and equipment schematics...
Apr 28, 2016 | Konica Minolta Bizhub C550
P 21 ERROR SOLV THIS PROBLEMS
replace the black image unit and run registration procedure
Feb 23, 2015 | Konica Minolta Bizhub C451...
Hi piz Error code P9 and P21 appears on screen and
check The Transfer Belt or it can be the Black Image Unit . (P9 & P21 normally: black Imaging unit) but P21 can also be refered to Transfer Belt). ..
Aug 08, 2014 | Konica Minolta bizhub C250 All-In-One...
C244e prblem for p 21 errof code
Replace the black drum and black developer unit P-9 Black drum issue and P21 registration issue since black is used as the reference for registration of colors can see a P-9 and P-21 code combo. Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Jun 13, 2014 | Konica Minolta Minolta Bizhub C253 Copier
Iam getting p21 error what can i do?
Sir/ Mam,
The P- codes in general are giving you a heads up that something is going to go soon. Most time you can live with them.This code deals with the registration of colors on the transfer belt. The belt put image on the paper and rides above the drums shine item when you open the right side door paper goes between it and the sponge looking roller.Registration is like cyan on top of magenta for purple if not you get to see both colors. Any way to get to the sensors that monitor registration requires removing the transfer belt then opening the sensor covers to expose the sensors and clean them NO LIQUIDS. Mite want a tech to come out and do this
Apr 24, 2014 | Konica Minolta Compatible Bizhub C452 C552...
Error p21
as I said before Color registration is off check the sensor under the transfer belt and mite want to have e tech run color registration procedure. black is the reference for the color registration having developer problems with black drum does not help
Apr 24, 2014 | Konica Minolta Office Equipment & Supplies
Colour shift p21
registration have tech come out unless you know your way around a konica minolta machine need to check the sensor under the transfer belt
Mar 18, 2014 | Konica Minolta bizhub C250 All-In-One...
8650 p21 p6
p 6 cyan image unit replace
p 21 Color registration problem is P 21. Need to do a color registration procedure.
Jan 24, 2014 | Konica Minolta Office Equipment & Supplies
Error code p21
P21 is a colour registration test pattern failure - check transfer belt for damage and or dirt, clean if dirty if damaged replace unit, or possible print head fault
May 03, 2013 | Konica Minolta bizhub Office Equipment &...
Define 54.18 ERROR code on a Hp Laserjet 5500
According to the HP Service manual, there is no 54.18 error.
The listed errors are:
54.1 Temperature error
Check the fuser. See 50.X fuser error.
54.3 Image density sensor error
Check the connections. Replace the color registration detection assembly.
54.5 Colour registration sensor error
54.6 Image density error
54.7(Y), 54.8(M), 54.9(C), or 54.10(K) Drum phase sensor error
Check the connections. Replace the drum phase sensor for the indicated color.
54.11(K), 54.12(C), 54.13(M), or 54.14(Y) Toner sensor error
Check the connections. Check the cartridge and replace it if necessary.
54.19 Transfer Belt error
Check the ETB connection. Replace the ETB. Replace the DC controller.
It is most likely that you have a faulty Toner Cartridge.
Jun 21, 2010 | HP Color LaserJet 5500 Printer
Konica Minolta bizhub C250 All-In-One Laser Printer Logo
194 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
