After laptop has been in sleep mode for several hours I push the start button over and over before it wakes up, What is the correct way to start computer back up from sleep mode?
SOURCE: wont boot to start up windows
1. Disconnect the AC adapter from the laptop.
2. Remove the battery.
3. Press and hold the power button for about 30 seconds then release it. (You will not see anything happen)
4. Connect the AC Adapter to the laptop. Make sure the AC Adapter is plugged in.
5. Turn the computer on as normal.
6. Once Windows boots, insert the battery.
If the notebook still does not power on, we recommend the notebook be serviced by our authorized repair depot. You can set this up for service yourself by going to www.acerpanam.com; click on the link for Depot Repair. If you are out of warranty, or you would rather do this via phone, please contact Acer Technical Support at 1-800-816-2237, Mon-Fri 7am-9pm CST and Sat-Sun 8am-5pm CST excluding holidays
SOURCE: computer won't wake after sleep mode
there is no other solution part from this..............all brand follos the same procedure to come out of the sleep mode do not worry.................................Sameeraryan
SOURCE: Can't wake up....gone into sleep mode...how do you wake it up
press and hold the power button down for about 5 secs. The computer will shut down. Restart it and right click on the desktop, go to properties then look for screensaver tab , then choose power options, click on hibernation tab at the top and uncheck enable hibernation. Or choose stanby options and choose a longer time before the computer goes to sleep.
SOURCE: Dell Inspiron B130 won't wake up after closing lid
Right Click on desktop--> Properties--> ScreenSaver-->Power--> Advanced
And from there U can set the things According to u
Hope It Solved Your Problem
Good Day
SOURCE: laptop doesnt wake up after sleep mode activation
sound slike hard drive is going ...go into settings and turn off sleep mode and also set it to hard drive NEVER shuts off
Sleep mode on a Windows 7 PC saves power without you having to turn your computer off and without losing any work.
This option cuts the power to your monitor, powers down the hard drive and pauses all functions until you awaken the computer from hibernation.
Whether you have a laptop, desktop or workstation, putting your computer into sleep mode will lower your electric bill and save money!
Click the "Start" button in the lower left corner of your desktop. In the lower right corner of the Start menu, next to the "Shut Down" button, is a button labeled with a small, right-pointing arrow. Mouse over the arrow.
The Shut Down menu appears.
Point at "Sleep" and click on this option.
Your Windows 7 computer goes into sleep mode.
Wake your computer from sleep mode by jiggling the mouse.
There may be a delay of a few seconds before your hardware powers on.
All of your open programs are still open and your work is intact, just as you left it before the computer entered sleep mode.
Configure your Windows 7 PC to go into sleep mode automatically when it is not used for a certain amount of time.
Click "Start" and select "Control Panel." Click "System and Security."
Click "Power Options."
A menu opens.
Click on "Choose when the computer sleeps" and select the number of minutes of inactivity. You can also set a separate time interval to put your monitor into sleep mode.
If you set both to 10 minutes, then your PC and monitor will automatically go into sleep mode after 10 minutes of inactivity
Your Computer in sleep mode
First, save all of your work. Information in computer memory is not saved while your computer is on standby.
From the Start menu, select Settings, then Control Panel, then Power Management.
Click Standby Beside When I Push the Power Button.
Push the Power button.
Automatically Putting Your Computer on Standby
Save all work before leaving your computer.
From the Start menu, select Settings, then Control Panel.
Double-click Power Management.
Set the times that you want your system to go on standby, to shut off the monitor and to shut off the hard disks.
Click OK. Your computer will go on standby according to the schedule you have entered.
Putting Your Computer in Hibernation
Double-click Power Settings.
Click on the Advanced tab.
At the When I Push the Power Button On My Computer screen, click Hibernate.
Click the Power button.
Hope this helps.
