Question about Saeco 762111651808 Espresso Machine
Water leak everytime I make a cup of espresso the machine leaks a least 3 ounces from the bottom all over the counter. How can I stop this leak?
  • Tom Pessemier Jan 06, 2008
    I'm having the same problem. I've taken the machine apart as much as I can get to, and it looks like the leak is coming from the hose that goes to the steam/froth wand. Also, my machine is now lacking power enough to froth a pitcher of milk. Any ideas? Thank you!
  • 515 Answers
I think your steam valve have to be replaced.
Posted on Jul 12, 2008
Leaking water onto counter
When my coffe maker does that I have found i needed to remove (if possible) and clean the coffee filter housing, mine has a spring loaded valve that lets you get a cup halfway though the perk and it had gotten plugged up with grounds, and was overflowing.
Just rinse it out top and bottom and you should be good.
If you cant remove it, be sure to unplug the electrical first :)
May 23, 2016 | Coffee Makers & Espresso Machines
Water leaks out of machine
Return for a replacement. Fiexed in 2014, but that is a long time apart.
Jan 02, 2012 | Keurig B66 3-Cup Coffee Maker
My Gaggia Titanium Plus is leaking water. Can I fix this or is this something that merits me mailing it back to the seller for service? About 2-4 ounces of water puddles underneath the machine each...
I fixed mine.  Sounds like you have a leaking steam valve.  I purchased a new valve from wholelattelove.com for under $25 with shipping.  Techs were great, I called twice and got quick answers.
Feb 23, 2010 | Gaggia Titanium Espresso Machine
Leaking black and decker under counter coffee pot
the 90 degree red elbow has worn away of hot water temps and will leak some but all hot water to the bottom of machine. needs to be replaced or retrofit one
Jan 03, 2010 | Black & Decker SpaceMaker ODC440B 12-Cup...
Bunn coffee maker leaks all over the counter. What
there's probably a 'silicon rubber' hose that feeds hot water to the 'grounds basket'- it may be loose, or damaged. is it leaking water, or coffee?? we have a bunn 8-cup, which has a pre-heated water tank that brews a pot in about 3 min. energy waster, but when you need coffee, you need coffee!!! is your filter holder properly centered? is the carafe lid hole clean and un-obstructed?
if it's leaking water, and not too costly to replace- you may consider replacing it with a new one!
good luck!
Oct 09, 2009 | Bunn GRX-B Original 10-Cup Home Coffee...
Excessive water poured through shot
its possible someone held the buttons down to long enabling program mode.
Go to your local market and purchase a 3 ounce measuring glass. Place it where you place your coffee cup and hold down the small button, it should enable program mode. Stop it once it reaches 1 ounce or your desired amount.
Do the same for the large.
Sep 03, 2009 | Saeco Royal Professional Espresso Machine
Small leak from the bottom right side (when looking at the machine) of my Saeco Incanto Sirius Espresso Machine when being operated. After two or three cups of coffe are made, need to move machine to the...
I have the same problem. To day I opened the Saeco and discovered that the unit attached to the knob at the right side of the machine must be replaced. Water came out in two places. I dont know where to buy this part.
Per
Oct 13, 2008 | Saeco Incanto Classic Espresso Machine
Machine stopped working
This machine is piece of s... I replaced two of them so far and experienced same problem.:
Machine works fine couple days
...than it start dispensing less water into the cup.
...than it stop dispensing water into cup completely and instead all water goes into the tray.
..The pump also starts occasionaly to make interrupted repetative sound.
Did anybody get it fixed?
Jan 05, 2008 | Krups XP2070 10 cup Coffee Maker/15 bar...
LEAKING WATER
I had the same with a Saeco it was caused by a leaky boiler, after replacement, it was fine...
Aug 08, 2006 | Waring Pro WC1000 Coffee Maker
Saeco 762111651808 Espresso Machine Logo
142 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
