Sharp AR-M455N Copier Logo
Chris Beckrich Posted on Mar 18, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
SHARP M455N PRINTING LIGHT
We have a Sharp AR-M455N printer and a few days ago it stated that the toner needed to be replaced. We put a new toner in and it started printing dark lines all over the documents. After that we cleaned and all was good. Then 1 more day later no matter how dark you put the exposure setting it keeps getting lighter and lighter. HELP!!!
Chi Chu
Level 3:
  • Sharp Master 8,457 Answers
  • Posted on Mar 18, 2014
Chi Chu
Sharp Master
Level 3:
Answers
8457
Questions
0
Helped
2822935
Points
26282
The ink toner is is now infected by foriegn matters by effecting the printer laser head.Tries air compressor machine blow out the ink toner print head ink injector and laser printer print head.Wait about and hour reinstall the the ink toner to the printer,the toner should work find again.Not the ink toner is not saveable,must have be replace for normal operation again.
5 Related Answers
Cogz
Chris Coughlin
  • 1326 Answers
  • Posted on May 21, 2008
SOURCE: Black Lines
Do the black lines only show up when useing the adf???? Or do they show up on both the adf and the copyboard glass??? If it is only when using the adf...... The fix is easy.... you have to clean the smaller piece of glass that is to the left of the copyboard glass with windex or rubbing alchola. If it is with both you may need a new drum and blade or a new ufr... Good Luck
Bubbabear64
Tim Babcock
  • 2794 Answers
  • Posted on Jul 20, 2008
SOURCE: my Sharp Copier AR-5320 print black and white horizontal parallel lines on the documents.
Check for scratches on the drum surface. If you have ran a lot of copies on there, its a good time to get it serviced. It could be the cleaning blade on the drum as well.
Everett Lin
  • 990 Answers
  • Posted on Dec 20, 2008
SOURCE: how to fix a sharp ar-m455n error code u2-81
Dear sir; This error code means "scannor memory" problem, don't worry, we can reset it, the procedure as follow;
1, make sure you are in copy mode , then press "p", "*", "clear", "*".
2, enter 16 press start.
3, press "CA" to end simulation.
that's easy, if you need more help, just let me know, good luck.
HAVE A HAPPY HOLIDAY !!!
Anonymous
  • 3 Answers
  • Posted on May 23, 2009
SOURCE: a new sharp ar 5316e photocopy machine photocopy blank
change the main charger because based on my experienced it has an arching problem
Anonymous
  • Posted on Jul 17, 2010
SOURCE: SHARP AR 5012 developer reset
i have a sharp sf 1025 , and i want to reset developer conter? can u help me pls
Have a weird problem on a Sharp AR m455n the screen stuck on the sharp logo any ideas?
Sometimes this would happen when a bad print job got sent to the machine. I'd make sure to delete all of the print jobs in everyone's print queue on their computer then reboot the machine to see if it comes back up.
Copier Collin Houston TX Copier and Imaging Expert
4helpful
2answers
Sharp AR 5316 Maching Toner LED Light 3 Min. Blinking, and them start. Please Toner Curm reseting code.
Have you tried to replace the toner???? Are you sure the light that is blinking for the toner?????
9helpful
2answers
Que significa el codigo f2-02 de una copiadora sharp ar-m25
me marca codigo f2-02 copiadora sharp AR M455N
ke puedo hacer sera que es le chip o el cartucho.
SHARP PRINTER AR-M455N ERROR CODE H5-01 RESET
you probably got alot of jamming on the left side around the fuser. you will need to clear it in service mode. simulation 14. i believe it is c - * - p - * buttons you have to push then enter 14, start key, then follow directions
Need to download latest printer drivers for Sharp copier AR-M455N
Copy this link to download the driver needed
http://www.driverwizard.org/wizard/w?ms.driversfor.wizard
7helpful
2answers
I need a printer driver for Sharp ARM455N
Hi david...
Sharp AR-M455N printer drivers can be found at driverupdate us (xp/vista/7/8/mac).
It will take 2 mins from you to install... after updating, go to word and try to print something
I hope I have helped you...
enjoy
My SHARP AR-168D is not recognizing a new toner cartridge.
Make sure what you've got is Sharp's AR168NT and not AR152NT. Sharp mades changes about a year ago to their toner and the chip on an AR152NT will not work with an AR-168D model.
2answers
Problem with sharp ar168d
If you do not have developer in the machine it will not print. let me know if you have it or not.
AR-M455 Printing Blank Pages
hi im jules_09.try checking the transfer roller or the drum charge roller or charge wire both of this unit are responsible for blank copy.either there id a current leak on those parts or your drum and transfer power pack is deffective.is the opc drum not expose to light morethan 8minutes?just check the transfer unit then the drum charge wire or roller
Top Sharp Office Equipment & Supplies Experts
k24674
ZJ Limited
ZJ Limited
Norman Weimar
Norman Weimar
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
