Question about Whirlpool DU1301XTV Builtin Dishwasher
Du1301xtv only washes on light cycle
Will start on normal but will not progress through cycle, not letting more water into washer
  • 1,511 Answers
The electronic component called a Solenoid may be stuck or partially clogged. This can happen when the water has an abundant amount of minerals and deposits. Often where the water sources are located in sandy communities. Also, these devices can over heat or malfunction over time from general use.
Posted on Mar 18, 2014
4 Suggested Answers
  • 185 Answers
SOURCE: Whirpool 1100TXP Dishwasher.
is your water temp set at 120 degrees
Posted on Apr 08, 2008
blueextc3221
  • 15935 Answers
SOURCE: Initially It started washing, completed the entire
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question(*&^%$#
Posted on Oct 01, 2010
Daniel S
  • 4323 Answers
SOURCE: I have a Whirlpool Gold
Hi
You have to check the float switch assembly and try to clean it, it might be going bad or needs cleaning. Check this video to locate the float switch assembly:
Hope this helps...please post back for further assistance.
Daniel
Posted on Jun 08, 2011
My f&p gw611 Fills up but then wont wash.the 2nd
Most possibly be Error code 56,
Is common in 11 series machines & early series 12.
Is your machine beeping & showing a weird pattern of lights on the wash cycle, It is displaying an error code,
To read this error code you start at the red spin light & work to the left only add up the lights that are on. Red spin light = 1 2nd rinse light =2 1st rinse light =4 last wash light=8 4th wash light=16 3rd wash light=32 2nd wash light=64 1st wash light=128
j8paojvh5jrgaaaaabjru5erkjggg==
Let me know your error code tour getting
Oct 20, 2013 | Fisher and Paykel GWL11 Top Load Washer
Won't progress beyond wash cycle -- start light is flashing. Cannot switch from "normal" to delicate or any other choice. Maytag Neptune TL FAV6800AW
So I understand the issue. Does the wash cycle start up? By that I mean if you release the washer top from the base do the tumblers turn once the water fill cycle is complete?
If you don't have the FAV6800A/FAV9800A Service Manual (you can't get it on line anymore) see this post Clutch Fix I describe how to release the washer top from the base to observe the wash basket. Don't raise during the water fill cycle wait till that completes.
Does the key pad beep as you press the other cycle select key pads?
This could be a Control Board issue...........Rich
Oct 16, 2010 | Maytag Neptune FAV6800AW Top Load Washer
F&P GW512 compact wont spin
Hi just read your posting.Does your machine drain the water out?Starting from left to right what lights were lit on the progress bar when it started to beep?Was it the 2nd and 5th or 3rd and 7th---etc---?Please reply with additional information on the questions and I am sure I can help you rectify this fault.
Jul 09, 2010 | Fisher and Paykel GWL11 Top Load Washer
Agitator will not work on wash but works on pre wash and rince.
Hello, welcome to Fixya.
It sounds like you may have a broken belt based on your description,
"it starts up fine and then is silent and motionless through the entire wash cycle. this is true in normal, permanent press, and delicate cycles"
Does the timer advance if left alone after filling ?
Have you access the back panel ( removed it ) and visually inspect the washer drive system ( belt, pulley, motor ) ?
You could also have a faulty motor, although that typically manifest's in only rotating in one direction and not the other so you would see some action.
Have you tried the washer in a spin cycle ?
Let me know how far you've progressed in the diagnosis and I'll watch for your reply and assist you further if necessary.
macmarkus :)
Jun 26, 2010 | Asko 8005 Front Load Washing Machine
Top loader MW511 will not start. Wash Progress (where you select wash type eg long or short) is the only display with lights showing, and I cannot change anything despite pressing the button to do so. No...
Hi just read your posting.Now on that wash progress line of lights there are 8 lights in total.Starting from the far right what lights are lit up?Is it the 2nd and 5th or the 4th and 8th--etc---?With this additional information I can work out the error code and advise you how to repair this fault.Please reply for further help.
Jun 20, 2010 | Fisher and Paykel GWL11 Top Load Washer
Turn washer to normal or gentle cycle water will
add a pail of water if it starts adjust level control
Aug 11, 2009 | Washing Machines
Does not heat water
the heater element has probably gone faulty or the thermostst is faulty, they sould come as one replacement.
Apr 05, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Have a ge washer, filss then does not progress to
May be a bad water level switch.
Open the control panel, with a full tub of water bump the water level switch with your hand. If it starts to agitate, replace the water level switch.
Mar 20, 2009 | Maytag Performa PAV2200
Whirlpool Washer will not progress to the rince cycle.
that is either a problem with the timer , or with the cold water hose at the back of the machine, see the following:
I quote from : The cycle doesn't advance
The cycle doesn't advanceWhen the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It'sthe timer, if your washing machine fills with water and beginsagitating, but the timer never advances--or if the washer is in a spincycle and the timer won't advance. Then you need to replace the timer.
  • Itmay be a cold-water supply problem, if the washing machine fills withwater, agitates, drains, and spins, but then doesn't fill with rinsewater. See There's no cold water.
  • Nov 20, 2008 | Washing Machines
    Whirlpool DU1301XTV Builtin Dishwasher Logo
    46 people viewed this question
    Top Whirlpool Dishwashers Experts
    Oloyede Monsuru
    Mike
    Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
