Question about John Deere 420,1020,2010,2020,2510,2520 Tractor Float
Shuts down when i take brake/clutch off - John Deere 420,1020,2010,2020,2510,2520 Tractor Float
  • 3 Answers
Sounds like your safty switch is bad our you have one unpluged some where under neath
Posted on Mar 18, 2014
While I was cutting grass the Engine shut down. Pulled the brake up. Push the PTO back down to shut the blades down. I started the engine, engine runs perfect.
try replacing the battery most with an electric clutch PTO have to have a really strong battery as the alternator system is not strong enough by itself
Jun 16, 2015 | Garden
Why does my engine shut off after running for awhile with PTO engaged; will restart with PTO disengaged, but shuts off when i attempt to engage PTO?
Does this only happen when the engine is warm or at operating temperature or all the time even when cold? In older engines, a 'bad ignition coil' would fail when the engine warmed up and would not start again until cool or at ambient temperature.
Apr 27, 2014 | Garden
Engine revs but no acceleration
Clutch plate and pressure plate seem to be too weak to pull the car. Or one of the CV joints is detached from the gear box. To test the clutch plate, park the car on flat surface. Pull the hand brake up, start the car, depress the foot brake pedal, depress the clutch pedal, put the car in 1st gear, press the gas pedal and leave the clutch pedal at once, while keeping the brake pedal depressed.
Follow one of the two following statements:
1. Engine does not shut down and remain start. (Clutch plate, pressure plate and clutch bearing defective - Replace all as a set)
2. Engine shuts down. (Clutch system is OK and does not require any repair).
May 22, 2013 | Honda Civic Cars & Trucks
Car will not accelerate when gas pushed
Clutch plate and pressure plate seem to be too weak to pull the car. To test the clutch plate, park the car on flat surface. Pull the hand brake up, start the car, depress the foot brake pedal, depress the clutch pedal, put the car in 1st gear, press the gas pedal and leave the clutch pedal at once, while keeping the brake pedal depressed.
My clutch won't engage 1997 Honda civic
Apr 06, 2013 | 1997 Honda Civic
After starting mower and releasing brake it shuts down
check the safety switch on the clutch/brake pedal most are duel switches
Jul 28, 2012 | Cub Cadet Garden
Need instructions to replace main drive & transmission belts. Mower will not go forward or backwards. MTD model # 13AN601H729
Before you go trying to replace the belts, did you shut it down the last time you used it while the transmission was in a HIGH range?
If you did, restart it, put your speed lever back in the same or higher position with the F& R shifter in neutral, let out on the clutch/brake pedal until it takes up the slack, then pull the speed lever back into lowest speed, push in the clutch/brake and put it in PARK. Shut of the engine and then restart, it should be back to normal operation now
Sep 07, 2009 | Mtd Garden
John Deere 420,1020,2010,2020,2510,2520 Tractor Float Logo
48 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
