Question about Canon Office Equipment & Supplies
Ir adv 8105 eooo4 0102
Error code e0004 0102 and 0102 keeps coming up. Have replaced the IH Power Supply FM4-1092 and it still does not work.
checkitright
  • 1362 Answers
SOURCE: E0004 on Canon NP6050
it is a SSR,heater 1 or 2 ,or thermal switch error.   Try to reset,        follow this procedure. SERVICE MODE E004 SSR O FUSER WON´T SHUT OFF
To reset this code use simulation 401
SERVICE MODE: Open front door and cheat door switch.Using an allan key of 2mm, insert it through the hole in the inner front panel and actuate service switch 850. Display will show "1". Press the mode 4 you want to use. then press "ok" . It will read 401 press "ok" use number key a change the value if "1" change to "0" press "ok" . press "clear" takes you out of particular mode turn off the machine. good luck     CE MODE: Open front door and cheat door switch.Using an allan key of 2mm, insert it through the hole in the inner front panel and actuate service switch 850. Display will show "1". Press the mode 4 you want to use. then press "ok" . It will read 401 press "ok" use number key a change the value if "1" change to "0" press "ok" . press "clear" takes you out of particular mode turn off the machine. good luck
Posted on Oct 24, 2007
  • 199 Answers
SOURCE: I am getting an error code E0004 on my np8530 copier
there are a motor sensor does not work properly
Posted on May 22, 2009
spinal
  • 287 Answers
SOURCE: canon ir 6570 E0004-106
Hello Raj, The code means that the fuser (the assembly near the paper exit area that provides the extreme heat and pressure required to bond the toner to the paper for your finished document) has detected a problem within itself. From the service manual it means "THe IH voltage is too low". IH means inductive heater which is the unique method the Canon IR6570 uses to generate the heat required th melt and bake the toner to the paper. All copier manufactures realize how important it is to closely monitor this extreme temp (192 degrees celcius) as to not cause a fire.So any and all deviations in temperature or voltage in the fuser area will cause the device to shut down (and there are MANY codes) for safety reasons even if the problem is momentary. You can reset the code and give the device an opportunity to recover in the event you perhaps had a power surge in your environment. At the control panel follow this sequence. Press the additional functions button, next depress the numbers 2 and 8 at the same time, next press additional functions again. This will summon the service mode. Select "COPIER" from the menu.Then select FUNCTION from the tabs at the top. Then select CLEAR from the menu.Then select ERR.Once selected, press the "OK" button located at the lower right corner of the screen.Then unplug the device for 5 seconds. plug it back in and the device will attempt to return to a ready condition.If it was a temporary problem then it will indeed recover.If the code immediately returns then you have a problem that WILL require a service tech Best of luck ! :-)
Posted on Apr 03, 2010
babaprithi
  • 372 Answers
SOURCE: CANON IR 1600 COPIER IT WENT OFF AFTER REPLACING
the counter PCB or the serial no. PCB is not matching.Did u got the main board with the counter pcb attached.if not then u have to get the counter pcb of the same board or attach the serial no pcb and the counter pcb of the old board . u will get it if ur a rep .if not then u have to consult one
Posted on Jun 30, 2011
bmbarto
SOURCE: canon ir 5570 e0004-0010
Try pressing Additional Functions then 2 and 8 simultaneously then Additional Functions again. Select Copier > Function > Clear > Err press ok. If the problem persists it will need parts. Error means that there is a problem with the IH power supply.
Posted on May 31, 2012
How do I remedy error SC 552?
change the main motor or clear the eroor
Sep 10, 2015 | Ricoh Aficio SP C811DN Laser Printer
Konica Minolta C552 error code C-B02
Replace the IH Power supply, it will solve your problem... Page 71 Item 5 from the parts manual.
Jul 17, 2015 | Konica Minolta Bizhub C552 Copier
Ir 6570 error code e0004 e00103
E004-0103 The IH power supply is faulty/the IH control mechanism is faulty. After correcting the fault, be sure to reset the error. (COPIER>FUNCTION>CLEAR>ERR)
The IH current is faulty. (no current) - Check the connector for any fault in connection. - Replace the fixing heater power supply. - Replace the DC controller PCB.
This link also offers a down loadable pdf service manual.http://printcopy.info/?l=en&mod=free&chap=erc&brand=Canon&model=iR6570
Apr 15, 2015 | Office Equipment & Supplies
ERROR CODE C-3B08
Code
C3B08
Description
IH input voltage error • While the IH heater was ON, input power was at the high voltage detection value or over for more than the predetermined period of time. • While the IH heater was ON, input voltage was at the low power detection value or under for more than the predetermined period of time
Causes
• IH coil unit (IHC) • IH power supply (IHPU) • Noise filter (NF1) • Printer control board (PRCB)
Remedy
1 Check the connection of the fusing unit. 2 Check the fusing unit, IHC, IHPU, NF1 and PRCB for proper connection and correct or change as necessary. 3 Check the marketing area of the fusing unit. If the marketing area is incorrect, replace the fusing unit for proper marketing area. 4 Check the marketing area of IHPU. If the marketing area is incorrect, replace IHPU for proper marketing area. 5 Replace IHC 6 Replace IHPU 7 Replace PRCB 8 Replace NF1
Jun 29, 2012 | Konica Minolta Office Equipment & Supplies
Error code c440. call for service toshiba studio 352
Fuser unit error code, need to replace fuser unit
BR
Feb 11, 2011 | Toshiba Estudio 200L Copier
I got a C440 error code sub code "7" with Toshiba E-Studio 352 copier. I tried to reset using 0/8- 400 but still the error code appears. what is the possible defective parts?
Hi how are you this is jack ...(jack_pak@hotmail.com)..
Dear follow the procedure
[C440] Fuser abnormality after abnormality judment.
When this code not cleat 08-400 then check these all thengs..
1.Check the thermistors
(1) Check if the connectors are disconnected.
(2) Check if the main and edge thermistors are in contact with the surface of the fuser roller properly?
(3) Check if the harnesses of the main and edge thermistors are open circuited.
2. Check the IH board and IH coil
(1) Check if the IH coil is broken.
(2) Check if the connector of the IH coil is disconnected.
(3) Check if the thermostat is blown.
(4) Check if the connectors on the IH board are disconnected (AC input connector and LGC I/F connector
CN455/456).
(5) Check if the IH board or the switching power supply unit are abnormal.
• Replace the IH control board.
3. Check the LGC board
(1) Check if the connectors CN316 are disconnected.
(2) Check if the conductor pattern on the LGC board is short circuited or open circuited.
(3) Replace the LGC board.
please vote me.
Thanks
Best Regards,
Jun 08, 2010 | Toshiba Office Equipment & Supplies
Toshiba 160 error code
For error code C44, it indicates Heater abnormality.
If 1st time occur, u can just go to 08-400, reset the value to "0" then restart the machine.
If happen again, then u need to check the thermistor. Replace it if necessary. If themistor replaced but still happen again, then u need to proceed to check themostat--> heater-->Mainboard-->Switching regulator.
Mar 09, 2009 | Toshiba E-Studio167 Copier
Canon ir 6570 error
Im new to this forum. I have an IR6570 giving me an error code E808-001, please help,
May 15, 2008 | Canon imageRUNNER 5570 Copier
old marine
old marine
