Question about Chevrolet 2005 Chevrolet Silverado 2500HD Work Truck
Chevy fault code p0303, p0300, p0306
Showing the above given faults
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 56 Answers
Egr system malfunction. check for plugged pcv. If diesel id need more info to help.
Posted on Mar 24, 2014
97 chevy 1500 sputters at idle in gear can feel it a little while driving no cat. past 2 years run bank1 lean code plugs clean HELP
If the engine is misfiring the check engine light would be on and blinking and the engine control module (PCM) would store a fault code or codes for the cylinders that are misfiring. A lean code will not cause a misfire unless the engine has a vacuum leak most often at the intake manifold gaskets. A misfire code looks like this:
P0300-P0306 for 6 cylinder and P0300-P0308 for a V8.
P0300 indicated a random engine misfire, this can be caused by all kinds of issues.
Feb 24, 2017 | Cars & Trucks
2013 BMW X5 replaced the spark plugs coils still have the p0301 p0306 codes
Trouble shooting a misfire, Code P0300, P0301 ... - YouTube
? 23:39
https://www.youtube.com/watch?v=G_grIaTgdRI
Oct 26, 2013 - Uploaded by Robert DIY
Trouble shooting a misfire, Code P0300, P0301, P0302, P0303, P0304, P0305, ... How to Diagnose Codes P0301 - P0310 - Cylinder Misfires ...
Diagnose and Repair Misfire Diagnostic Codes P0301 ...
? 9:22
https://www.youtube.com/watch?v=yK7v11ASVgI
May 6, 2014 - Uploaded by JamieJones TheCarMan
Diagnose and Repair Misfire Diagnostic Codes P0301,P0302, P0303,P0304,P0305,P0306 On A Hyundai ..... P0303 Honda cylinder 3 misfire detected code - Change spark plug - ELM327 OBDII reader with Torque - Duration: ...
? 15:59
https://www.youtube.com/watch?v=Sg7iFytxfzQ
Feb 16, 2014 - Uploaded by Robert DIY
Misfire Trouble Shooting: 30 to 60 minutes ($50 / $75 / $120) If your car is ... Diagnostic Codes P0301,P0302, P0303,P0304,P0305,P0306 On A ...
Dec 08, 2015 | BMW 2013 X5 xDrive35i
Codes po303, po171, po137. po420
2000 Toyota Corolla, P0171 & P0420 codes - YouTube
? 5:43
https://www.youtube.com/watch?v=ahJnJ19-vwY
Jun 13, 2011 - Uploaded by StandardBrandParts
Standard Motor Products presents: Technician's Toolbox "2000Toyota Corolla, P0171 & P0420 codes"
Smoke testing for codes P0171 P0174 - YouTube
? 5:48
https://www.youtube.com/watch?v=kZsqEfP-5zM
Jan 18, 2011 - Uploaded by realfixesrealfast
These two codes mean a V style engine is running lean on both banks. So you have to be thinking - what can ...
How to repair fault code P0171 and reset warning light ...
? 26:31
https://www.youtube.com/watch?v=Y8FBGrCT3rM
Nov 27, 2014 - Uploaded by Peter Finn
How to repair and fix fault or error code P0171 and reset warning light Toyota Corolla VVT-i engine. ... Also how to find fault codeusing OBD scanner. ... Trouble shooting a misfire, Code P0300, P0301, P0302, P0303, P0304, P0305, P0306, ... 2000 Toyota Corolla, P0171 & P0420 codes - Duration: 5:43. by ...
Dec 02, 2015 | 2005 Toyota Corolla
Reason for fault p0303, p0306.
cylinder 3 and 6 misfire thanks for all the info really helps me help you lol
could be plugs coil injector pcm cylinder dmg wiring etc
start by swappin coils n see if problem follows coil or stays in same cylinder
Mar 19, 2014 | 2005 Chevrolet Silverado 2500HD 2WD
Fault p0303, p0300, p0306
Those codes are all misfire codes. you have misfires in cyl 3 and 6. the 300 means multiple cylinder misfire. Id first start by checking your coils plugs and wires.
Mar 18, 2014 | Kia Amanti Cars & Trucks
White smoke
P0300'Random/Multiple Cylinder Misfire Detected
P0306'Cylinder 6 Misfire Detected
P0303'Cylinder 3 Misfire Detected
http://tinyurl.com/qbg9dbs
Mar 18, 2014 | Chevrolet 2005 Chevrolet Silverado 2500HD...
I have a 2007 ford taurus with p0300-p0303, p0306, p0316, p2195 and p2196. engine doesnt start anymore but battery is fine.
The old give me money for nothing statement from a mechanic instead of knowing how to fix it.
code p0300 refers to random/ multiple cylinder/s misfire detected===causes--spark plug/s---HT lead/s---injector/s---ignition coil/s--low compression--wiring
code po303 refers to cylinder 3 misfire detected--- engine mechanical fault---wiring---ignition/ fuel system---injector --ECT/MAF sensor --- ECM
code p0306 refers to cylinder 6 misfire detected===causes --engine mechanical fault---wiring---ignition / fuel system---injector ---ECT/MAF sensor---ECM
code po316 refers to misfire detected during start up--first 1000 revs==causes--engine mechanical fault---wiring---ignition /fuel system---injector
code po2195 refers to heated oxygen sensor (HO2S) 1 bank 1 signal stuck lean===cayses ---HO2S---fuel pressure---injectors---intake leak
it also refers to O2S sensor 1 bank 1 same causes and also refers to HO2S 1 bank 1 implausible signal===causes --- short to positive---short to ground---Ho2S ---ECM
code po2196 refers to the same items as 2195 . some causes are also air intake restricted
Have a compression test done some where else and it will indicate the condition of the motor. The rest is sensors and wiring problems.
Jan 05, 2014 | Cars & Trucks
Codes:p1346/p1349/p1354/p0446/p0300/p0301/p0303/p0305/p0307/ p0430/car runs rough when idling/lexus gs 400 1998
P0301 Cylinder No. 1 Misfire Detected
P0302 Cylinder No. 2 Misfire Detected
P0303 Cylinder No. 3 Misfire Detected
P0304 Cylinder No. 4 Misfire Detected
P0305 Cylinder No. 5 Misfire Detected
P0306 Cylinder No. 6 Misfire Detected
P1346 Variable Valve Timing (VVT) Circuit Range/Performance Fault
P1349 Variable Valve Timing (VVT) System Malfunction
P0330 Knock Sensor
P0446 EVAP Vent Control Fault
P0430 Catalyst System
Stop driving immediately.....
You defiantly skipped on your timing........
Feb 14, 2011 | 1998 Lexus Gs 400
Chevrolet 2005 Chevrolet Silverado 2500HD Work Truck Logo
74 people viewed this question
Top Chevrolet Audio Players & Recorders Experts
CrisO
Lawrence Oravetz
Are you a Chevrolet Audio Player and Recorder Expert? Answer questions, earn points and help others
