Question about Savin Office Equipment & Supplies
Black streaks at bottom of page after printing
When copying or printing I get about an inch of black streaks at the bottom of the page
    Habit-Forming:
  • 11 Answers
Okay Grehner, I suggest you to perform a complete alignment and cleaning/maintenance-service for this printer.ASAP...this will help you out with this particular problem during printing.
Blessings.
Gladmar.
Posted on Mar 18, 2014
DJYar
  • 41 Answers
SOURCE: black streaks on printout page
It sounds like excess toner has built up in or around the imaging drum. I would *carefully* remove the toner and drum (can be messy) and use some canned air to clean the inside out. If you are still getting these streaks, it might be time to get a new drum (DR 400) as you are supposed to replace the drum every 6 to 8 times you change the toner cartridge.
Posted on Aug 23, 2007
Cogz
  • 1326 Answers
SOURCE: HP Officejet 6300 All-in-one machine makes black streaks
The problem is that that there a small piece of glass that the doc feeder use's to scan the orginal. You will have to clean the small glass it's about a half of a inch piece and is normally under the doc feeder unit. It will either be to the right side of the main copy board glass or it is under the doc feed unit where the paper goes down through the feeder. It is mostly some white out on the glass, just clean with a dam cloth with water or windex..... Good Luck
Posted on Nov 16, 2008
SOURCE: My drum is at 40%. I have black vertical streaks
I was going crazy! Had a tech come in and look at the machine - needless to say he did NOTHING! A friend came over and was trying different things. It was that the "rack" that the toner cartridges sit in was not fully seated - once he pushed down a little and heard it "click" I had no more black streaks. AMAZING
Posted on Mar 31, 2009
  • 990 Answers
SOURCE: Copier, Printer black streaks on copy or all black page
Hello sir; Either drum cleaning blade or drum cartridge needto replace.
Posted on Aug 21, 2009
  • 39 Answers
SOURCE: streaks and black spots on printed pages
Try cleaning the laser lens using the laser lens cleaning wand. However, it is likely that your black cartridge needs to be replaced based on the troubleshooting from the Minolta manual. Sorry,
Posted on Apr 29, 2010
Canon NP6221 makes copies black and white with black streak down middle. How can it be fixed--works well otherwise.
They are manny cause of black copy.
1.over tone.
2.arching on main charger or dirt on main charger.
In Case You Still face Problem and Need Online Assistance Then Please Follow Us For On : Brother Printer Support
Feb 16, 2014 | Canon NP6221 Fuser Thermofuse
My brother MFC 8500 is receiving alright but everything I send out has a big black streak going down the right side of the page. Confirmation page also has big black streak.
Let me see if I got this right.
The received fax is clean but when you send one out it has a black streak on it.
Cool! So far so good.
Makes sense because for sending, the fax scans the original document and parts of the scanning area could be dirty and so on. Therefore a black streak may appear.
The same black streak would also appear when you make a copy, because the original document must also be scanned.
Logical!
However for receiving faxes, the machine uses the internal memory and the print engine only, and the same applies to printing the transaction report, which comes from inside via the print engine.
The scanner has no rol in either situation.
Now I'm lost!
May 31, 2011 | Brother Office Equipment & Supplies
Aug 20, 2009 | Brother Office Equipment & Supplies
Black lines or smudge marks\running down the prints
Hello sir;The streak line from printing also should be from copy, because the line come from imaging unit, check the meter count if close to or over 50,000 then replace drum and drum blade, it will take care the problem.
The brother printer you need to replace imaging unit( drum unit).
Jun 01, 2009 | Brother Office Equipment & Supplies
ADF copy with black streaks?
lift up your adf and locate the thin piece of glass, about an 1' wide, and clean real good with rag and windex. probably white out or some foreign material on that glass.
hth,
razors
Feb 27, 2009 | Brother MultiFunction Center MFC-440CN...
Nov 15, 2008 | HP 190 Copier
Xerox xc 830
pls check ur machine ros assembly unit. i think the ros assay geting dust or its geting failed.
Jul 23, 2008 | Xerox Office Equipment & Supplies
What is causing black streak
You should try changing the toner cartridges first. There may be something stuck in it causing the noise and streaking
Apr 14, 2008 | Canon imageCLASS D661 Digital Printer
Minolta 2300DL Printer - black streaks
Hey Chuck, Any chance you can post a scan of one of the faulty pages ? This will make it easier to assess the fault. Print off about 10 pages of a page that is affected by the lines. Look at each page and see if you can detect a recurring pattern over any of the pages. If there is a pattern, chances are it is probably the PCU that is marked.
May 20, 2007 | Minolta magicolor 2300W Laser Printer
you will have to check the Minolta web tech support team for this one.
May 20, 2007 | Minolta QMS 2200DL Laser Printer
80 people viewed this question
Top Savin Office Equipment & Supplies Experts
CheckitRight
CheckitRight
George Mclaughlin
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Savin Office Equipment and Supply Expert? Answer questions, earn points and help others
