Question about Sony Hi8 CCD-TRV138 Camcorder
Not recording I have a sony video camera recorder ccd-trv138 ntsc hi8 it does not record. It was stored for for a few months with a cassette inside because I lost the charger and the battery was dead. Now I have a new charger and every thing works except record.Please help. Bernard
  • Bernard Bernard
    Bernard Bernard Mar 26, 2014
    The camera turns on and plays , cassetts can eject but if i install a new cassett and try to record it will not record.
  • Bernard Bernard
    The camera will turn on and play previously recorded tapes but it will not record any thing new
4 Suggested Answers
AlmostBob
  • 550 Answers
SOURCE: problems with playing cassettes recorded on a hi8 camera
DCR TRV140E is a Digital8 camera
CCD TRV87E is a Hi8 camera,
(Hi8 is an analog format)
the tapes are the same size, wont help, the recording systems are not compatible
send them to a lab service ?maybe if there are only a few
or ebay a Hi8 camera and transcode them yourself
its not a solution, at least it clarifies the problem
Posted on Oct 23, 2008
SOURCE: Sony Handycam Video Hi8 - TRV138- cassette - will not play -please reinsert
Hello Everyone!
My Handy Cam CCD TRV-138 was have a malfunction error by stopping and beeping and telling me to reinsert cassette.
HERE IS HOW YOU GET IT TO WORK.....
Let me first tell you that you need to call the Sony Service Hotline at 1-800-488-7669.
They will have their service tech help you to reset the camera, STEP by STEP and it will work fine after that.
You have to do several things in the right sequence in order for the reset to work. You can't just press the reset button and make it reset.
It doesn't cost anything to have Sony help you over the phone. They are all too happy to make sure that you are satisfied with their product and want to help you.
Mine was out of Warranty by 4 years and they still helped me without charging me.
I followed their steps and it worked. She had me first remove the cassette tape from the camera, turn off camera, remove the battery, then she had me turn the camera back on, then she had me take a pen or pencil and push the reset button, that is below the volume buttons (inside the view finder area). Release the pen then turn camera off again, then unplug the cord and wait 60 seconds so that the residule electric current can completely drain from the Camcorder. After 60 seconds, power on the camera and before you do anything else *YOU MUST RE-ENTER AND SET THE YEAR, DATE, TIME before you go any further. This is crucial to your camera working properly. Then power off again. Power up one more time and this time try to record and playback and see if everything works ok.
Mine worked fine. If this does not work for you it may be because you own a different model and you will need to have Sony give you specific instructions for your model.
Good Luck and let me know on this blog if it works.
Posted on Apr 22, 2009
welcomejee
  • 10594 Answers
SOURCE: Hello,
CCD-TRV308 is analog camcorder that can not be hooked directly with computer because computer needs digital format signal to save it on hard disk that will be used to burn dvd disc.
Easiest way is to connect this camcorder with stand alone dvd recorder, it will convert analog video-audio signal into digital format then record/ burn it on dvd disc at same time, once dvd disc is ready then you can copy it in computer for further editing as per requirement to make another dvd disc.
Next option is to install mpeg card in computer that will get analog signal from camcorder to convert it into digital format then it will be saved on computer hard disk for further editing etc to make dvd disc.
Hope these info will help you, I would recommend to have dvd recorder to record your Video-8 tapes on dvd disc quickly without too much trouble.
Thanks.
Posted on Dec 04, 2010
How to repair hi8 video as only sound works on tape
From the description it is the record head, and probably intermittent you get sound and video issues, there is no easy fix, if sony still supports it not worth the repair cost.
Feb 26, 2012 | Sony Hi8 CCD-TRV138 Camcorder
REINSERT CASSETTE MESSAGE ON Sony Handycam TRV138- Hi8
I bet it has been in a cupboard and not used for a long time. The camcorder has a "Mechacon Fault". Maybe electronic, (component failure) or electrical, (switches tarnished contacts).
Jul 14, 2017 | Sony CCD-TRV238 Camcorder
Problem with Sony CCD TRV138 camcorder
Symptom shows bad CCD IMAGER in camera and requires replacement. (IC951 on CD-465 board, mounted at end of lens mechanism).
Nice to know that you are tech person so buy CCD IMAGER from any part store under following part number..
A-7013-219-A CCD BLOCK ASSY (CCD IMAGER) (TRV138/TRV338)
Good luck.
Mar 15, 2009 | Sony Hi8 CCD-TRV138 Camcorder
Problems with playing cassettes recorded on a hi8 camera
Oct 23, 2008 | Sony Handycam DCR-TRV140E Digital...
Sony Hi8
If you see the line while in the camera mode (actually recording a scene), then the line will be on the recording most likely. Check your tape for damage by lifting open the front of the cassette (tab on left side of tape), pull tab back while opening cover and inspect for creases or damage. Either of these cases will be non-repairable (bad recording). If the tape path is out of line the then it may be possible to have a tech realign the tape path to correct problem.
Apr 23, 2008 | Sony Hi8 CCD-TRV138 Camcorder
HELP
the heads could be dirty or the tape path could be out of alignment.
Mar 16, 2008 | Sony Hi8 CCD-TRV138 Camcorder
Connect Sony TRV138 Hi8 to PC
dazzle capture device or buy and dvd recorder no other real options
Mar 05, 2008 | Sony Hi8 CCD-TRV138 Camcorder
Play back problem
Your camera playback heads appear to be dirty. You can purchase a head cleaner cassette from an electronics store or take it to a service centre where they will clean the heads.
Check that the tape itself is not damaged, as this can cause the same symptoms.
Jan 03, 2008 | Sony Hi8 CCD-TRV138 Camcorder
Cassette load issue
reel table on the right ( take - up ) if has low tension ? will slow down or stop , giving reinsert error : stretching spring ( inside reel table ) will fix problem , as well as to order and replace reel table .
Aug 07, 2007 | Sony Hi8 CCD-TRV138 Camcorder
Sony Hi8 CCD-TRV138 Camcorder Logo
26 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
