Question about Neff U1421 Double circotherm Electric Oven
I need to replace the element on the bottom oven. I have removed the back plate and the scews holding the element in place however I am unable to remove one screw as the screw head is blocked by the fan blade. Do I have to remove the fan and if so how do I do this
  • Neff Master
  • 3,463 Answers
Hi. Hold the fan with your hand, and unscrew center nut, N.B It is a left hand thread, so unscrew it clockwise as though you were tightening it the conventional way, and vice versa for tightening it up.
Please `rate my solution.
Thanks.
P.S. You can bend the fan blade if needed.
Posted on Jul 19, 2009
Flavel cascade 100 fan oven not heating, but fan still going. Grill and other oven still work. Is the oven lamp in the circuit? That has blown so just wondered if the two things are linked?
Heating element has blown IRCA Type RL6 1800W Remove back panel unscrew 2 screws remove the 3 conected cables open oven door remove 2 screws at rear of oven that holds faceplate in place remove face plate and take old element out and replace with a new element
Oct 08, 2013 | Ovens
Flavel milano e60 how to fit new fan oven element that is riveted
That is complete RUBBISH the screws are accessible from the rear of the oven. At the back remove the screws holding the plate and you will see the element housing. Remove the two screws and the spade connections. Get someone to hold the new element in place for you and attached the screws. Fiddly job so be patient. Connect the spade connections and replace all plates front and rear. Should be the job!!! Someone hold the element in the cooker whilst someone connects at the back. Whatever you do, DON'T TAKE A DRILL TO YOUR COOKER!!
Dec 13, 2012 | Ovens
How do i replace the heating element in a diplomat aca3200 oven?
make sure the oven is switched off.remove all trays etc from oven,remove 2 posidrive screws from bottom of fan plate,remove fan plate,the element is around the fan,remove 2 posi screws from where the element goes through the side of oven and the one screw that holds the top of the element to the back of the oven.slowly pull the element out and remove the 2 poz and neg spade connectors.refit as removed.
Dec 30, 2010 | Ovens
Bread (biscuits/rolls) burn on top and raw on bottom.
there are two elements in the oven one on top..one on bottom...the top one is also used for broil functions...the lower element may have burned out...to remove it there will be a screw holding a plate with the lower element attached to it...you may also need to turn the oven around and in the back there may be a cover where the electrical connections are...you may need to unscreww 2 screws to remove the element...if you have a multitester or can get one ..you'll want to check the resistance of the element..it will be a low value(not sure what value exactly). If it won't give a reading or shows nothing on the meter then you'll need to replace the element...you can get elements at appliance parts stores or on the internet..you can even try an appliance repair shop for parts.
Dec 22, 2010 | Whirlpool RBS245PDS Electric Single Oven
How do I remove the oven element on our Belling Synergie XOU252? I have located it no problem but cant work out how to remove? Is it held in place with 2 very very small bolts?
It all depends on whether the scew heads are flat, or have slots for a screwdriver.
If no slots , then you are going to have to access the heater from the rear of the outer rear cover of the oven.
If the screws can be undone from inside, then simply unscrew them, and pull the element out towards you.
Hope this helps.
Dec 27, 2009 | Belling XOU252 Electric Single Oven
We have a hotpoint cooker UY46, our electric tripped the cooker off and , now the nob and grill works but the bottem/main oven is turning on and the fan is circulating but not getting hot ? please help ;(
You need to replace the element. Very easy job remove the back plate from inside the oven (4 screws) and you will see a circular element held in place by one screw in the centre of the fixing plate. Remove the fixing screw then remove two wires and refit new element job done.
Regards Neville
Jul 16, 2009 | Neff U1721 Double circotherm Electric Oven
Problems with the fan on neff b1641 oven
Hi, from what you describing it can only be either the oven element (located behind the back plate inside the oven, hold by 6 screws, 2 at the top, 2 at the bottom and 2 on the sides). Switch off the cooker, remove this panel and have a look at the element, looking for unsual bends, corrosion, or burn marks. The other possibility is the safety stat located near the element connections at the back of the oven. Pull the oven out, remove the back chassis panel and inspect the stat.
Cheers
Feb 19, 2009 | Neff B1641 Single circotherm super...
Replacing the element in a diplomat 5706 cooker
Hi.
You will probably have to remove the rear panel of the oven, this is on the outside that I am referring to, and you will see the 2 securing scews for the element, you might have to push the insulation to one side to see the screws.
This should solve your problem.
Please good feedback if this helps.
Thanks.
Nov 30, 2008 | Jenn-Air JJW8530C Expressions Collection...
Bake element does not heat
After removing the racks, rack rails and the back plate I removed the 2 screws the hold the bake element. Lifting the front of the bake element up and carefully pulling the element out and gently moving the element so the connector clear the hole I was able to disconnect the wire. After testing for continuity with an ohm meter (non found) I determined the element need to be replaced. $37 and 45 minutes total.
May 28, 2008 | Thermador SC272T Electric Double Oven
Neff U1421 Double circotherm Electric Oven Logo
228 people viewed this question
Top Neff Ovens Experts
Hjalmer Lamminen
Hjalmer Lamminen
Samyfam
Samyfam
xxxxxx xxx
Are you a Neff Oven Expert? Answer questions, earn points and help others
