Question about Pulaski Bardot Wine Chest
How do I remove the lightbulb for the Bardot wine chest?
I can't figure out how to remove the light bulb fixture
Why does only one socket in my ceiling light work?
Bad socket. Replace the light fixture part on the ceiling fan.
Sep 01, 2014 | Cars & Trucks
Can't figure out how to change the light bulb in my Wine Cooler? Can't get the plastic cover off? help!
Hello there,
How many techies does it take to change a light bulb (without a hammer)?
There is a tiny screw holding the lens cover in place. Once removed, the lens will come off and you can access the bulb.
Hope this helped
Thanks for using FixYa
Mike
Jul 24, 2008 | Magic Chef MCWC30MCG Compact Wine Cooler
How do I change the lightbulb on my lantern-style carriage house exterior fixture? It is wired flush to the wall and has a decorative filament on the top. Beneath that are two little knobs that appear to...
problem with most outside lights are, they tend to get hard to open because they are outside, without being there to look at it, i would say that you need to get a ladder and look at the light and see if you can see the threads on any of the knobs, then if you do gently use a pair of plyers to remove the knobs, hope this helps
Dec 03, 2011 | Home
Lightbulb has boken off in socket trying to remove it from ceiling fan light fixture
try this. turn off electricity, take a raw potato and push it up into the socket, then use the potato to unscrew the bulb, no kidding , this has worked.
Nov 10, 2009 | Hampton Bay 24002 Ceiling Fan
How to change the low beam lightbulb. I figured out where it is... but need to remove the whole fixture.. how do it do it?
Look it over, get involved and remove whatever screws hold it to the body/fender etc. Most screws are Torx type fastners. No torx sockets or driver bits, your done before you start. Torx have been on veh for 25 years.
Sep 26, 2009 | 2007 GMC Acadia SLE
Tradewind range hood- model PSL736: both lights out, fan works
The screws by the lights probably only hold the fixture in place. If you took the screws out you would only get access to the fixture and maybe some wiring. If you have already replaced the lights you can assume its not the fixtures. Not likely both fixtures failed at the same time. The common problems would be the light switch. You would need to gain access to the switch and then check that for power.
You already know house power is good because the fan is working, But since both lights failed and new bulbs don't fix the problem it would most likely be a switch.
According to their website it looks like that whole front panel should come off including the fixtures and the switches.
MAKE SURE THE POWER IS TURNED OFF......REMEMBER THE FAN WON'T WORK IF THE POWER IS OFF.
Once you remove that you can check the wiring harness for the lights. You may also see wire nuts on the harness double check those as well.
Jul 05, 2009 | Kenmore 51840 Kitchen Hood
Hampton Bay Ceiling Fan Plastic Burning Smell
I think you have already figured out what the problem most likely is; 60 watt bulbs. Down-size the wattage or install 'energy saver' bulbs if they will fit the application. Instead of counting on these units for extra lighting, perhaps think about Track lighting to fill in those ares that need more but subtle light.
Good luck. :)
Apr 09, 2009 | Hampton Bay 46056 Callaway II Ceiling Fan
Need to change lightbulb of Zephyr Savona Zsa-m90s
I'm not sure if my Savona is the same one, but on mine, just remove the filter and you can see the base of the light bulb up above the fan base. You can see where the bulb screws into the fixture. Grab the ceramic portion of the bulb, and turn that part. You may want to steady the socket with your other hand because it is very flimsy.
Dec 12, 2008 | Zephyr Savona ZSA-M90S Kitchen Hood
Pulaski Bardot Wine Chest Logo
79 people viewed this question
Top Pulaski Home Experts
Donni Steen
Tom Chichester
Are you a Pulaski Home Expert? Answer questions, earn points and help others
