Question about Denon DBP-1611UD REGION FREE 3-D BLU RAY PLAYER 100240V 50/60HZ. REGION ABC
Replacement disc tray needed
My BD player is rattling while Blueray disk is loading and playing. I was told by Service that laser unit is wrong and whole tray unit has to be replaced. I am curious if someone may have that spare tray unit available...
    Sergeant:
    Champion:
  • 266 Answers
That is the (costly) heart and soul of the dvd player! Only chance, go to dvd players throughout Craigslists USA and find a used one.
Here are 8 from Craigslist DFW, going for around $15-25 each. Not Denon but its a start!
Call Andy 972-358-0662
Posted on Mar 18, 2014
My blue ray player changes from Blue Ray player to Network when loading a Universal movie.
follow this steps and fix it. God bless you
Does not play disc
  1. No disc. - Load a disc into the tray.
  2. Disc has been loaded upside down. Place the disc with the label side up.
  3. Disc region code does not match region code of the player.
  4. Disc type is not the correct type to play.
  5. Disc is damaged or dirty. Clean the disc or try another.
  6. Moisture may be condensed inside the unit. Remove the disc and the leave the power on for one or two hours.
Nov 06, 2013 | Samsung BD-D5700 WiFi blueray disk player
Put my p-1500 in our RV. Tested with a blueray disk and worked just fine. Wanted to show wife, but it would not play any blueray. but will play standard hi-def. Any ideas?disks. Any ideas
see the cause and remedies:
Does not play disc
Finally the OPU, optical pickup unit contain lasser bean NOT reading the TOC disk +Syscon can be defective, you must go to the repair shop TV for fix it
Jul 16, 2012 | Samsung BD-P1500 Blu-Ray Player
I put a disk in and there was already one in now it wont eject
The disc tray does not eject when the OPEN/CLOSE button is pressed. Solution
sp.gif sp.gif Follow the steps below to troubleshoot this issue.
    IMPORTANT: The disc tray will not open while a disc is loading; this is normal operation. If this is the case, wait until the disc is finished loading before pressing the OPEN/CLOSE button to open the disc tray.
  1. Make sure the disc tray is not locked; if necessary,
  2. Perform a power reset.
    1. Press and hold the POWER button for 10 seconds until the BD player turns off.
    2. After the BD player turns off, press the POWER button again to turn it back on.
  3. Attempt to open the disc tray by pressing the OPEN/CLOSE button on the front of the BD player.
  4. If the disc tray still does not open and a disc is stuck inside, follow the steps below to force the disc tray to eject:
    1. Turn off the BD player.
    2. Turn the BD player back on.
    3. Immediately after POWER ON is displayed, press the STOP button on the front of the player. IMPORTANT: Only use the STOP button on the front of the BD player. The remote control cannot be used for this operation.
      NOTES:
      • The disc tray should eject and the BD player will turn off. If it does not eject, repeat steps A-C.
      • It may be necessary to press the STOP button in step C two or three times.
If the issue is still unresolved, service may be required
Sep 15, 2011 | Sony BDP-S300 Blu-Ray Disc Player
When I put in any DVD Disc, you can hear the disc spin. I opened the unit and put a disc in and could see it spin and you can see the laser light come on to try and read the disc. After about 10 sec or...
Is this a blueray player? If it is, the disc you put in probably isn't formatted to the blueray. If it is a standard dvd player there is probably something wrong with the player. You have two options. One, to take it in for service or two, to get another dvd player. If you have another dvd player in your home, try the disc you can't play from the one player and put it into the working player. If that works, then something is wrong with the dvd player you are having issues with.
Apr 03, 2011 | Televison & Video
When tv is wired to media center and then to blueray dvd , disc will not play. Non blueray disc will play. When tv wired directly to blueray player, blueray disc runs fine. Cables are hdmi
Hi.
When you say disk will not play I assume the BRD player does not start playing.
If the Blue ray unit does not start at all and stays in stand by , then the HDMI cable you are using to connect to TV, or HDMI port on TV may be defective.
Try replacing cable and swapping HDMI ports.
Oct 24, 2009 | Bose Audio Players & Recorders
Problem w/Samsung BD-P1200 Blue Ray Disk Player
Hello mljackson197,
This indicates a problem with the pickup head. First I would suggest cleaning the laser head with a disk made for that purpose. If this does not work, then I would suggest (if you have a background in electronics) taking the cover off and checking the bias voltages on the laser pick head (comparring them to the schematic values). What I believe is happening is just a dust problem, however if it is a circuitry problem, contact the manufacture or use the schematic/service manual to locat OEM parts.
I would, however try to clean the pickup head first.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Mar 23, 2009 | Samsung BD-P1200 Blu-Ray Disc Player
LG RH278 HDD/DVD Recorder
I have an LG RH278 HDD/DVD Recorder, which was suffering from the problem that it could not play any bought DVD movies, which were previously working fine in that same player. It would however play svcd and DVD+R/-R movie discs.
The solution was to replace the laser tray. I found a new LG DVD BD lens LPC-815 laser tray here: http://www.laser-xh.com/en/?act=showproduct&proid=1147
I bought two for $5.50 each. Shipping was $32 (DHL), all together $45.10 (PayPal fees included). Delivery was fast and accurate within 3 working days (China - Sweden).
Feb 03, 2009 | LG DR787T DVD Recorder
Blueray player bdp1500--won't play disc it should play??
Hmmm, thats annoying and you say that you have tried this as two differenct discs, you can region free your dvd player here
http://www.videohelp.com/dvdhacks/samsung-bd-p1500/9441
See if that helps, other than that mate I am lost to why it will not play the disc. Does it have any scratches?
Jan 11, 2009 | Televison & Video
Denon DBP-1611UD REGION FREE 3-D BLU RAY PLAYER 100240V 50/60HZ. REGION ABC Logo
51 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
