Hand heavy clock
I have a large chime clock which is quite heavy. It is not a stand alone chiming clock. It has one tiny hole in the back to which it is hung, too dangerous, too lightweight. I don't want it to fall off the wall. Probably weighs 40 lbs.
    Sergeant:
    Champion:
  • 266 Answers
You will need a stud finder, and brackets to fasten it securely. This requires a little expertise.
Is there a Mr Mcneill??
Posted on Mar 18, 2014
How do I make my clock chime the correct number of times?
whenever the battery is weak the chime changes....whenever you change battery the clock chimes to the last time it chimed so...try setting your clock to next hour of chime n then move the hands of clock to next hour n your clock will chime accordingly.....
in this way waiting for chime to finish ...set to clock to present time ....waiting for it to chime every time the minute hand passes 12
Dec 09, 2015 | Home
How can I get my clock to chime the right time? It is always one hour too much.
  • First see if changing the time with the battery out changes the time without changing the cycle on the chime - I could just imagine somebody adjusting the clock for daylight savings and the clock doesn't change it's chime cycle correctly with the battery a certain way - in or out - maybe it's the opposite and you have to take the battery out and somebody didn't now you have to leave it in.
  • Check the internet for the original manual if you know the model.
  • Look for clues to setting the chime on the back? is there a separate knob - are the batteries both good?
Still not working after playing with it? Here is the mechanical way to fix it:
Sounds great, but it still is chiming the wrong time after playing with it? This will fix it:
  • Set the clock for exactly at the chime - I suggest 3 o'clock chime - the hands will be wrong (2 or 4 or whatever)
  • Remove the battery(s) - I do custom imprinted clock faces and it seems to me that 3 o'clock is the easy place for me to put the hands back.
  • Take the clock apart - usually it is tiny screws on the back, or you will see 3 or 4 v shaped wires. push the v wire out of one side - they are springs that some clocks use to hold the rim instead of the screws - they are easier than they look - just pull one side and remove.
  • Gently pull up each hand off the shaft. I hope you have fingernails.
  • Replace the hands back at exactly the time that they are supposed to be (3 o'clock in my example) - you start with the hour hand and gently push on the spindle make it look level and all the way on - then the minute hand at 12 also level
    • Remember to play with the time first so you'll be happy that you put the hands exactly where the chime should start.
    • Remember to make that time be exactly on the hour with the small hand and exactly on the 12 with the big hand so the hands line up correctly.
Nov 09, 2015 | La Crosse Technology Radio Controlled Post...
The chime of my Howard Miller mantle clock are not w/the actual hour set.How can I reset the chimes? Daylight Savings time has messed me up.
The next time it chimes multiple times turn the hour hand clockwise until it is pointing at the number of times it gonged. Next take off the dial nut off (make sure to put it in a plastic bag because they can be hard to replace) and turn the minute hand until it chimes signaling 15 minutes after. Now put the minute hand back on pointing to 3 o'clock and replace your dial nut and you are all set.
Fix Clock That Gongs Wrong
Nov 06, 2011 | Seiko Mantel Clock
Mantel Clock With Westminster/Whittington Chime: How to set the chime properly...
Pressing the red button advances the chime count by one. Continue to advanced the chime count until it matched the hour shown on the clock face.
May 18, 2010 | Seiko Mantel Clock
The time and chimes are out of sync for our tempus fugit wall clock by 4 chimes does any know how to adjust it
Turn the minute hand until the 16 westminster chime operate and then the hour strikes. Remove the minute hand and simple put it back on at the 12 o-clock position. The chimes should now be in sync.
Fred
Apr 24, 2010 | Seiko Mantel Clock
I NEED THE INSTRUCTIONS FOR SETTING THE CHIMES/TIME ON MY WESTMINSTER LINDEN MANTEL CHIME CLOCK
Manually turn the minute hand forward until the 16 westminster chimes sound and then the hour strikes. Then remove the minute hand (it will go on in four positions) and put it back on at the 12 o'clock position. The chimes should now be back into sync.
Fred
Apr 05, 2010 | Seiko Mantel Clock
My new wall clock chimes 2 minutes BEFORE the
You will need to do a mechanical adjustment to the hand.
Loosen the hand nut and adjust the hand the tighten.
Hope this tip helps to solve your problems
R/
David
Mar 19, 2010 | Watches
Strausbourg Manor Wall Clock chime adjustment
It is normal for the average wall clock. Of course, this can be adjusted, but without watch/clockmaking knowledge it is impossible, because first you need to find out which part of the movement is causing early chiming - and there are plenty of them.
Super fine adjustment can be found only in top of the range clocks. Hundreds of hours of craftsmenship are spent to adjust and fine tune them. That's why they cost a fortune.
If you can not live with that early chiming, you have to bring your clock down to the watch/clock repair shop and ask for help. Be ready to pay quite a money, as this job takes the skill and a lot of time.
Rate me, please.
Jul 29, 2009 | Seiko Mantel Clock
Chimes are nine minutes slow
Take the minute hand off and turn hand over. There is a brass bushing that attaches to the aluminum hand. Take a small screw driver and place in the square hole of the brass bushing. Turn either direction and test on the minute post of the clock. Keep adjusting until the clock chimes right on the 1/4 hour position. Make sure to put the hand back on the right 1/4 hour.
Nov 15, 2008 | Seiko Mantel Clock
Problems with Howard Miller dual chime dual west and Beeth movement clock
If you manually set the time, the chimes will be off unless you wait for the chiming to finish before continuing to turn the hands.
Press the TEST button to get the correct number of chimes in synch with the actual time.
Jun 21, 2008 | Audio Players & Recorders
Computers & Internet Logo
David Payne
David Payne
