Question about Capital Cooking Performance Series PSQ30ZRBI (LP) Grill
Looking for reasonably priced replacement "W" shaped burner for Capital Grill model #PSQ30ZRBI
I need replacement burner:(25,000 BTU "W" shaped). Price from dealer where I bought grill is outrageous...looking for better price on part.
I have a weber gas grill, it's about ten years old and I need new burners, I cant find any model #s on it. Where do I look?
The easiest thing to do would look at the design type of burner that you have. Then search with keyword terms such as "Weber gas/propane grill burner" and eventually you will find a compatible match. Most of them are universal, and labeled designs such as an H burner...for it's shape.
Make sure however that if you decide on a non-weber built burner that it is in fact listed in it's details to fit on a weber grill, as some manufacturers may have a certain proprietary design difference that only their components will work with.
Aug 20, 2011 | Grilling
I have to replace parts for my patio classic NZ400 4 burner grill. I heard the company went out of business, did anyone purchase the grill division? Is it possible to find replacement parts? I need to...
The original company was sold in 2004 and remained in business out of Louisville, KY until 2007. Then, for whatever reason, they closed their doors and have not been heard from since. Unfortunately, there no replacement parts left around for their gas grill line. If you really want to repair your grill, get the dimensions of the burners & their shape, as well as the dimensions of the 2 racks and do a little research online, at some of the grill parts dealers. Many grill parts are interchangeable from one manufacturer to another.
Here are a couple of places you can start with. http://www.appliancefactoryparts.com/ and
http://www1.inetba.com/allparts/
Good luck & Happy Grilling!!
Jul 18, 2011 | Patio Classic NZ-300-SMT Grill
I need replacement parts for the oval double holed piece that heats the food for my fiesta classic grill. What a terrible description right? where can I get them, in Massachusetts preferrably?
The part you're looking for is the 'burner". You'll find what you need at the link below. But, you must have the Model Number of your Fiesta Grill to get the correct oval burner. There are several.
http://www.appliancefactoryparts.com/gasgrillparts/brands/fiesta/fiesta-burners.html
Hope this helped you. Please let me know. Thanks.
May 09, 2011 | Fiesta Classic 26,000 BTU Grill
Have had the grill for over tens years; need to rebuild burner,hoses,etc. can I increase the btu out put? John
John, increasing the Btu output would present a safety hazard. As the grill was built, tested and approved for exactly what the maximum Btu output is now. I wouldn't recommend doing it.
Apr 05, 2011 | Char-Broil Patio Caddie 4654870 (LP) Grill
Need photo of how to replace the 5 "V" shaped
The 'V' shaped metal bars are the flavorizer, flame tamer or whatever Weber wants to cal them. They go over top of each burner from front to rear, setting on the ledge of the interior of the grill, just above the burners. make sure that cover each burner equally. Now's a good time to clean them if they have a lot of grease on them.
Since the grill was blown off your deck ... make sure all the burners are intact are not damage and there are no gas leaks from tank to the grill.
Feb 11, 2011 | Weber Spirit? E-310 Propane Grill
Can i drill out LP hole in cap for NG
Yes you can, but only if you know the BTU rating of the burners. Then you need to know what size drill bit to use to drill each orifice. Plus you will need to eliminate the LP regulator when you hook it up to your house's already regulated natural gas line. When you hook up any gas appliance, it needs to have it's own shut off valve installed on the gas line. I also like to install a quick-disconnect adapter after the shut off so I can release the hose from the grill and put the grill away when it's not in use. I have LP/Nat gas conversion charts available to look up drill sizes if you need to know more details. Keep in mind, that if the grill does not state the individual burner BTU ratings, but only the total BTU rating, you will have to divide that rating by the number of burners. Douglas
Sep 05, 2010 | Weber Genesis Silver C Grill
Converting Thermos Stainless Grill to natural gas
You have to install a conversion kit for it to work the way you want. The reason is because the orifice in either the valves or the main "jet" that feeds the burner tube has to be changed. Natural gas is really not as efficient as lp gas (propane) because it takes more natural gas to create the same btu output as propane.
In short, your grill will not work if you do not do the conversion. I am including a link that lists the conversion kit for your grill, you can order it there and you can download the assembly manual as well.
Here is the link: http://www.charbroil.com/Consumer/product_detail_e.aspx?ProductID=1723&CategoryID=25
Nov 20, 2009 | Thermos Stainless Steel Gas Grill
Can grill be safely converted to griddle on Thermador PRG486GLUS?
http://www.instawares.com/add-griddle-top-2.133-1002.0.7.htm
try this.
If it doesnt fit your specs. then i would suggest u find a thermador parts place and begin to buy the parts for the griddle as replacement parts. find a model of the stove set up that you want and make a list of all the parts that go to the griddle attachment.
My guess is that the reason for the flat "No" on the retrofit was that griddles require a thermostat similar to the one on the oven and broilers do not. So if their is no room behind the face plate where the knob would go then you can't put in a griddle. The other issue might be that the burners for the griddle wont line up with the brackets that are holding up all the broiler burners now. The griddle burner looks exactly like the one from the over only smaller so it has to line up strait where a regular front and back burner have to line up offset. maybe since you have the broiler already that should not be an issue? Then the problem is finding the griddle top it self that is going to be spendy. I think the link i gave at the top is your best bet. good luck.
Leslie
Mar 19, 2009 | Thermador PRG484GGUS Gas Kitchen Range
H Burner replacement
There are aftermarket cast iron burners available for approx $64.95. Otherwise, the OEM burner is a Dynachrome which is a chrome plated cast iron that is almost $300. I do not believe that the cast stainless is still available.
Jul 26, 2017 | Dynasty Grilling
Capital Cooking Performance Series PSQ30ZRBI (LP) Grill Logo
Top Capital Cooking Grilling Experts
paulcarew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Capital Cooking Grilling Expert? Answer questions, earn points and help others
