Question about Canon Imagerunner 1025IF Grayscale Copier
Line on copies
How to do printer head realignment
How do I make new cartridge print?
remove the cartridge and check that you have removed the tape across the print head
insert and press black button on the printer or next on the printer screen it should go to print test page which you then have to photo copy back into the printer so that it can realign the printer head .
Sep 06, 2015 | HP OfficeJet Pro K8600 Printer
Keep getting blue lines through the image. i have cleaned heads and realigned and nozzle checked several times
Hey dude,
It's the problem with the printer head.Replacing cartridges and allignment won't help.Try to replace the printer head.it's the only possiblity.
Mar 06, 2011 | Epson Stylus Photo 1290 InkJet Printer
Laserjet printer black lines in copies
printer heads need realigning.
run the diagnostic that is provided in the cd.
or install the full software and then run that, also clean the printer heads following the instructions that are in the manual accompanied in the cd rom drive
Oct 15, 2010 | Lexmark C533DN InkJet Printer
I have a canon 1200s printer that has new canon cartridges, ALTHOUGHI'vw clEANED THE PRINTHEAD IT STILL PRINTS ONLY PATCHY, FADED COPY WITH LINES RUNNING THROUGH IT. ANY IDEAS? THANK YOU C
Run a a deep cleaning cycle then run the alignment test and realign the head correctly. Then print the test sheet again. It sometimes takes a few cleaning cycles to get the ink flowing correctly especially if the prinetr is in a warm environment and has not been used for a while.
Oct 05, 2009 | Office Equipment & Supplies
Epson Stylus r220 prints with white lines... i installed a CIS and it worked fine for about 6 months, now i'm getting prints with white lines (or fine spots) i tried nozzle check, which comes out good......
Nozzle check must perfect for perfect output. There are tranversal lines at vertical straight lines that represent same point of head micro piezo. If tranversal lines no clog at all, but vertical straight lines not perfectly straight, the result not good (like horizontal white banding). Check it? Head aligment is for vertical banding. If your result is horizontal banding, you don't need to realign head. It's caused by some residual at the output of head sprayer. So, the spray of ink not straight to paper. Try to print with photo/best photo.
Jul 18, 2009 | Epson Stylus Photo R220 InkJet Printer
Pale margin on copy
flat spot on your fusing pressure roller
Jan 28, 2009 | Office Equipment & Supplies
Black not printing about every 3rd line
http://www.hp.com/#Support this link could solve your problem. also make sure you are using good quality ink for your printers. I use to have many problems with my printers and then i started purchasing my ink from www.yahootoners.com , you could not find a better price quality product anywhere else. trust me its worth it.
Nov 23, 2008 | Epson Stylus C86 InkJet Printer
Bad print quality
what you need to do is run your disk and it will print off a paper that you put in your scanner and it sets the alignment. Will you please send me a copy of your disk as that is what i need. matt.griffin80@o2.co.uk
Apr 07, 2008 | Epson Stylus DX4200 All-In-One InkJet...
Canon Imagerunner 1025IF Grayscale Copier Logo
56 people viewed this question
old marine
old marine
