Question about LG DLEX3470 Electric Dryers
Dlex3470 display error
At end of cycle display led goes in a circle and dryer does not chime when "wrinkle care" option is selected.
How do I turn on bell on my dryer
From the Whirlpool user manual:
(OPTIONAL) Your dryer may have an End Of Cycle Signal. The
signal is helpful when drying items that should be removed
from the dryer as soon as it stops.
On some models, the End of Cycle Signal is fixed.
On other models, the End of Cycle signal is part of the
Start button and is selectable. Turn the PUSH TO START
button to ON or OFF. The signal will sound only if the
selector is set to On.
Jan 22, 2016 | Dryers
MY DRYER DOES NOT STOP AT THE END OF THE CYCLE, THE BELL GOES OFF BUT DOES NOT STOP
if you have selected wrinkle release thats normal it will keep on going on just air not to let the clothing sit and get wrinkled
Jan 20, 2015 | Samsung DV431AE 7.4 cu. ft. Electric Steam...
Samsung front loading dryer the display shows rotating circle rather than time remaining
Rotating blinking lights in the display is probably an indication that the Wrinkle Prevent option has been selected. Wrinkle Prevent will continue to tumble the dryer without heat after the cycle has ended to help prevent wrinkles from setting in. When this option is selected by pressing the Wrinkle Prevent button on the control panel, the display will count down the estimated cycle time; when the cycle ends, the display will show lights blinking in a circular (or actually rectangular) motion.
To deactivate, simply press the Wrinkle Prevent button again so the light is not illuminated.
Jul 28, 2014 | Washing Machines
E15 error code on hoover tumble dryer
Controls
  • The control unit on the tumble dryer will vary among different makes and models. The main purpose of the controls is to allow the user to select the drying cycle. You can choose the time and temperature setting on most units, while others allow custom settings such as moisture sensors and end-of-cycle alert signals. The controls may include a dial or a touch panel and LED screen display. Some tumble dryers allow you to independently select the appropriate time for the load you are drying and separate programs for temperature.
Motor
  • The motor inside the tumble dryer spins the basket to allow the clothes to tumble while being dried. The tumbling action allows the air to pass through the clothing to dry them faster. Heating laundry that is stagnant will likely dry the clothing on the outside while leaving damp clothing inside the pile. The constant motion, along with the heat and steam created by heating the clothing, reduces wrinkles. The motor also powers the fan that delivers the heated air to the basket of laundry. The heater can be an electrical element or gas powered.
Jan 15, 2013 | Dryers
How do i do drying only
From the document I see, it is only a matter of pressing the "Dry" button. This is from the manual, available at http://www.lg.com/us/appliances/washer-dryer-combos/LG-WM3431HW.jsp and selecting the "Support" tab. On the right, there will be a "Washer/Dryer Combos Manual" link, which will download to your computer. Listed under "Dry" in Section 9 is the following.
• Drying options are easily selected with the Dry button. • For most even drying , make sure all articles in the clothes load are similar in material and thickness. • Do not overload dryer by stuffing too many articles into drum. Items must be able to tumble freely • If you open door and remove load before dryer has finished its cycle, remember to press the Start/Pause button. • By pressing the Dry button, you can select "Normal" - "More" - "Time" - "Off" - "Low Temp" - "Less" • Your dryer can handle a load of up to 9 lbs. (4 kg) dry weight of articles. • When drying cycle is completed, [Cd] (Cool Down) is displayed on the Multi display. • Cool Down is set automatically when the drying cycle is complete. • If clothes are not removed promptly when the drying cycle ends, wrinkles can form. • The Cool Down feature periodically tumbles, rearranges and fluffs the load to avoid wrinkles for up to 4 hours. • The message [Cd] will continue to display until the clothes are removed or the Start/Pause button is pressed
Hope this solves your problem. I highly recommend downloading the users manual, it is a wealth of information and will prove useful in many circumstances.
Please rate and comment Thank You Joe
Sep 06, 2011 | LG WM3431 Front Load Washer / Dryer
LED displaying cl
Hi nicciwonnaco,
The "CL" code is not an error! This means "Child Lock".
Try buttons "dry" & "spin" together for a few seconds. This is the child lock display.
Or press "end of cycle" for over 5 seconds.
Or press "options & select" till the light goes off.
Regards
R.K.
Oct 21, 2009 | LG Washing Machines
Kenmore dryer beeps constantly
End of Cycle Signal
The End of Cycle Signal produces an audible sound when the
drying cycle is finished. Promptly removing clothes at the end of
the cycle reduces wrinkling.
@ H_GH
@ LOW
@ OFF
END of CYCLE S_GNAL
Press END of CYCLE SIGNAL to adjust the sound level or turn off
the signal.
NOTE: When WRINKLE GUARD _ is selected and the End of
Cycle Signal is on, a tone sounds every 5 minutes until the
clothes are removed, or WRINKLE GUARD _ ends.
Sep 15, 2009 | Dryers
Magtag Dryer MDE2400 Dryer won't turn off
On our Maytag dryer, the looping marquee lights mean that the dryer is in "wrinkle" mode. This means that the wrinkle mode has been selected. In this mode, the dryer continues to rotate on and off after the heat cycle has ended. It does this to keep the clothes from wrinkling -- and it displays the looping lights.
Jul 24, 2009 | Maytag MDE2400A Electric Dryer
My LG dryer shuts itself off during the normal cycle and a dotted
OK, here's what it sounds like to me: The line going around the display should only be seen if you selected "Wrinkel Care" function for that cycle (and with the freshen up cycle, I beleive). With that option in use, after the dryer shuts off, if you do not open the door or turn off power to the dryer the dryer will display the moving rectangular segments and every 6 minutes the dryer will turn itself on and tumble for 10 seconds with no heat (to keep clothes fluffed up and prevent wrinkles from setting in) and will continue this cycle for up to three hours. The "Freshen Up" is the steam cycle used to remove wrinkles from 1 to 5 garments, like things that were all wrinkled up in your suitcase. Try drying with a normal or permanent press cycle, or a timed cycle. If you have additional questions or concerns, let me know.
Dec 06, 2008 | LG WM2077CW Laundry XL Front Load...
Problem when drying gets to 1 minute mark
This is happening when you selected the wrinkle prevent option or you set it to wrinkle release cycle.what it does is it is tumbling with no heat to release the wrinkle in the clothing. This is normal.It could also be normal part of drying in "regular" cycle
May 29, 2007 | Maytag Neptune MDE6700A Electric Dryer
LG DLEX3470 Electric Dryers Logo
21 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a LG Dryer Expert? Answer questions, earn points and help others
