Question about Jenn-Air JJW8230D Electric Double Oven
Jenn air double ovens
I have jenn air double ovens and in between the glass on the doors has dust and is dirty.  How can I clean between the glass?
  • vetewb Dec 26, 2008
    We have food between the glass panels and cannot remove them oven is built in and cannot find screws at the bottom?
  • Anonymous Mar 16, 2014
    calibrate jenn air oven thermostat
  • 833 Answers
First, with the door closed, find the screws at the bottom of the door and remove. With an assistant, open the door and remove any side and inside screws you find. The door will separate into two halves. Be aware that most glass is not clipped in...they can fall and break. Remove the front panel from the door...the door may try to slam shut. To clean the glass, use a blue cleaner and a scrubby or very fine steel wool rubbing gently. Scratches are not allowed! Take pictures of what you're doing so you can replace. Be careful of brittle door insulation.
Posted on Dec 07, 2007
My Jenn Air double oven giving error message saying low fan speed and will not work! Any suggestions?
It may be possible that the fan blades have built up grease and dust causing a drag on the blade. Clean the fan blade and see if it goes away.
Oct 02, 2014 | Jenn-Air Ovens
Broke Glass door for Jenn-Air 701642K
Hi, Go to and tyoe in the model # located on a tag either around the door opening or around the bottom drawer.
I hope this helps you.
Jul 11, 2009 | Jenn-Air 27 in. Electric Single Wall Oven...
Jenn-Air electric wall oven door opens slightly when in bake mode
you either have a bent door hinge or a broken door spring.
check the hinges by opening the door and see if it opens past 90 degrees. if it leans towards the floor then the hinges are bent.
if not then your door springs are broken off. you can check this by seeing if the door "feels" heavy when opening.
either way the door should close tight against the frame when up and the light should not come on without opening the door.
Jan 22, 2009 | Jenn-Air 27 in. Electric Single Wall Oven...
Oven door locked - jenn air
My Jenn-Air double oven locked after a clean cycle. My model (JJW8630) has a series of slots cut in the top of the door. Take a piece of stiff wire, coat hanger, and bend a right angle about 1/2 inch at the end, feed the wire into the 3rd or 4th slot from the center on the right hand side. Turn the wire so that the bent piece is on the top and push the wire so it engages the lever which latches the door shut, it is spring loaded and moves easily.
Once the door was opened, I removed the temperature sensor, held by 2 screws, from the top of the oven and eased the wire out to get to the connector. The faulty sensor was reading 4.2 k, at room temperature it should be just over 1k, while waiting for a new sensor to arrive I stuck in a 1k resistor, ex Radio Shack, so the fan stops running and the door latch can be retracted by closing the oven door, or press the switch on the top right of the door opening.
My replacement part was ordered on line for less than 1/2 the official quoted price.
Hope this helps.
Jul 18, 2008 | Jenn-Air JJW8430D Electric Double Oven
Cleaning Inside Glass Oven Door of KitchenAid KEMC308KSSO
To dismantle the kitchenaid pro line oven door: there is a lever over the hinges that attach a door to the oven. The lever is right on top of the hinge. Pull the lever up. When that lever is in the up position, you can pull the door out.
Jan 10, 2008 | KitchenAid Architect Series KEMC308KSS...
Dirty oven window
Try to remove the door. For the Kitchenaid, thereis a hinge on each side with a latch that flips up. Once the door is removed, remove all screws and you should be able to get at glass. Be very careful, the Kitchenaid had four panes of glass.
Jan 08, 2008 | Whirlpool GBD307PRS Stainless Steel...
Selfcleaning Jenn-Air electric oven
How do I clean my jenn-air double oven when I lock oven door and turn oven to clean mode set time to start I don't get anything. Also when I lock the oven door the oven lock light does not come on.
Dec 05, 2007 | Jenn-Air JJW8230D Electric Double Oven
Jenn-Air JJW8230D Electric Double Oven Logo
558 people viewed this question
Top Jenn-Air Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Craig Butler
Craig Butler
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
