Question about Asko D1996HNDL Built-in Dishwasher
Was dropped now will not load disc. Says loading on screen but never does.
Power works can use set up function and menu bottom work. Everything else seems to be ok just will not load disc.
  • 1,511 Answers
In some cases the manufactures have exact alignments whereby any changes to the factory specifications will render the device unless until it is set to factory specifications. You may need to rely on a professional service representative.
Posted on Mar 18, 2014
Doesn't anyone know what I can do to use AAA.com triptik My computer will not load it. everything else seems to work ok.
to create the menu tab on your homepage right click in the top toolbar you should see a number of toolbar options select the menu tab which will add File Edit View Favorites Tools and Help
click on the tools at the bottom of the drop down list will be internet options or
click start control panel internet options you will see a home page box To Create Page Tabs type
each adress on its own line (AAA.com) or your preferred home page and browser
below that will be change search defaults click on settings you will see all search providers you
hope this helps
Sep 21, 2012 | E-Machines eMachines Desktop PC
Bluray BD-6900 turns and is stuck on Load. No menu, nothing on screen, just the word LOAD displayed
Hello
Its laser pickup unit should be suspected. Just insert a lens cleaning disc and try to clean it. If it do not help you, the set need service
Mar 04, 2012 | Samsung BD-C6900 Blu-ray 3D Player
I can't open Windows when I start my Toshiba Satellite Pro. The Toshiba screen pops up and allows me to hit f2 or f12 for setup and boot manager, but nothing else. Once the Toshiba screen disappears...
Welcome to FixYa!
There are 2 process you could used when it come to cases like this:
1. If its the power settings causing this just follow this steps. Here are the steps:
  • Turn off your computer and unplugged all wires connected to it (including power).
  • Remove the battery from the bottom of the computer. There will be two tabs labeled 1 and 2.
  • Re-plug in the power wire. (the battery should not be in the computer) Turn the power on. The screen will work. Choose start windows normally. (if you get that screen).
  • Go to the start menu then click Control Panel -> (Mobile PC) -> Power Options -> Under Balanced choose change plan settings.
  • Choose Change advanced power settings.
  • Find Processor power management and change the minimum processor state from 5% to 100% for each On battery and Plugged in. Click Apply then OK.
  • Shut down the computer and removed the power cord.
  • Re-install the battery on the bottom of the laptop, plug in the power cord, and restart the computer.
2. If its the boot files being corrupted as the one causing this, you could used this as well.
First BACKED UP your files to an external hard drive using Puppy Linux. You could used this link: (http://www.puppylinux.org/)
Once you are done backing up your file then follow this:
  • Booted up the computer and pressed and held down F12 (boot)
  • Insert the Toshiba recovery disc (there should be a disc one and two).
  • Selected CD/DVD from boot menu
  • Go to Toshiba recovery wizard then go to the second option (format/delete everything off of hard drive)
  • Restart the computer
  • Re-load the disc
  • Select Toshiba recovery wizard and then select the first option.
  • Once the wizard began, wait until it asked you to insert disc two. Continue from there.
Hope this helps you. Have a nice day and thank you for using FixYa!
May 20, 2011 | Toshiba Satellite P205-S6287 Notebook PC
Machine won't recoginze disc from program function
As I understand it, the Load button loads designs that you have prepared earlier and saved within the Designer 1, not disks made and saved in your Husqvarna software. These are the .DHV files (this might not be quite the correct file format name - can't remember!) you might see when you look at a disk in your software.
When in Program mode, you need to use the Menu button to go right back to the first D1 opening screen, then choose the Disk icon, navigate through all that to find your design, choose it and it appears on your Program screen. The second time you hit Menu from inside the program screen, you get taken directly to where you were the first time so it is quicker. But first time, it is a long slow process.
Jan 30, 2010 | Sewing Machines
My PS2 is not loading Grand Turirsmo 4!
If your PS2 works fine with most of the games and won’t play a few..Then you should try this trick to play them too on your PS2:
  1. Turn on your PS2 without inserting any disc.
  2. Menu screen will appear like:6e4cb56.jpg
  3. Press the (triangle) Button to enter Version Information Menu that looks like9d90dc8.jpg
  4. Highlight the Play Station Driver as above and again press (triangle).
  6. Highlight the Disc Speed as above and press X button,to enter Disc Speed Menu
  7. And set it from Standard to "Fast".
  8. After you set Disc Speed to Fast, Press and Hold Reset Button to turn off your console.
  9. Then again Press and Hold Reset Button till the Blue Light turns on.
  10. Remove the Reset Button and Press it again.
Be patient and wait till the game loads itself. If your lens is in good condition then it will play game in first go else try again till it PLAY your game. If still your Grand Turismo 4 DVD wont work then you must clean your PS2 lens.Watch following video to learn about cleaning lens:
Thank you and Good Luck!
Dec 16, 2009 | Sony PlayStation 2 (PS2) Console
I have an asus z7100 laptop and just reloaded windowsxp... ever since then my screen goes dim then light then dim then light... can you give me any suggestions?? My power setting is at max level and either...
I would agree with clb199 mostly, I'd certainly try a different power supply before dropping any money on a repair. A lot of times a loose connection can cause the backlight to brighten and dim as it goes from AC to DC to AC again.. does it do this even when the AC adaptor is unplugged
Could also be the FL inverter going bad.. but usually the screen would go from lit to black (but you could see the display in bright light) if that were the case.
Try plugging in an external display and see if that display does the same thing.
Last but not least, boot your Windows XP (or any other bootable) disc. Does the screen still flicker when you are in the boot menu or does it only do it after Windows loads? If it only does it when logged into Windows then it is a software issue and we can troubleshoot further from there. (you can test this without a disc by rebooting your PC and loading the BIOS setup, usually the F2 key)
Keep us posted or PM me directly.
-spaz
www.leeds-pc.com
Nov 29, 2009 | ASUS m6n Notebook
My PS3 was loading discs just fine, but now it doesn't
Have you tried backing up the PS3 and Factory reseting it? To back up follow this guide: http://manuals.playstation.net/document/en/ps3/current/settings/backuputility.html
To factory reset:
http://www.tech-recipes.com/rx/2265/ps3_how_to_factory_hard_reset/
Aug 12, 2009 | Sony Playstation 3 (PS3) Console
Acer Aspire One Won't Load OS
If you set it up with a dual boot, I recommend dropping in your discs and doing a repair to your OS's. Try the Debian first. I have a couple multi boot systems that have acted similarly, and when I reload the Linux Kernal, it fixes the boot record and everything runs well. If you're getting to the point that your Kernals are loading, your BIOS is fine and you're computer is passing it's POST test so the hardware is checking out. Another thing that it could easily be is your power supply. I NEVER recommend plugging in your laptop without the battery installed. Many laptops run off the battery at all times, the power supply is just continually recharging them as it's used. Giving the computer power without the battery plugged in could/would overload the circuits and voltage regulators all over the motherboard and you could EASILY damage your computer. Try swapping out your power supply with another one to make sure that isn't the issue. If neither of these attempts work (reloading the OS's/changing out the Power supply) then I recommend returning it for a warranty repair. (P.S. If you've dropped it or banged it around at all and have a traditional hard disk drive, they damage rather easily. You'll find out about that though when trying to reload the OS's. They'll tell you if it's not running properly.)
Jun 08, 2009 | Acer Aspire One PC Notebook
I got a missil gl-1502 for xmas,the manual isn't that good.It doesn't te me how to load music on to it.I have been trying to load for acouple of days.I have music loaded on to my computer but can't get it...
These made in China MP4 players are quite budget ... however,I've managed to get mine working just fine. Just follow these steps:
1.Charge the unit. (These things come with a dead power supply, soyou'llhave to to charge it with the provided USB cable... or any cable such asone that works with a camera. you'll not be able to load it orturn iton until this has been done. 3 hours later your computer willdetect newhardware (USB mass storage device) and install the appropriate drivers.
2. Loading MP3's... there are 2 ways to go about this...
a) If you have the latest Windows media player click on the SYNC tab and follow the directions.
b)Open "My Computer" you should be able to see a new drive (probably E: F:or G:) double click to expand it, you should see a bunch of folders,simply drag and drop your MP3s to the Music folder.
3.Converting and Loading Video: The included program that comes withthesecheap-*** players is a bag of $#@! so dont even bother with it.
The best program to convert videos to work on this thing can be found HERE
-Pick the first one (note:this file is zipped so will need to extract it),
pick up a trial version of WinRar HERE
-Once extracted, go ahead and run the program...click ADD
Choose your input file, and output path,
Youwill need to know the resolution of your screen. Under Playertype,choose SUNPLUS AVI and select the video resolution of your Missil, 30frames/sec and the best sound/video quality and hit start.
- this process takes a while (30-60 min) depending on file size.
- Once complete, simply drag and drop (cut and paste) the converted file to to the VIDEO folder on the players drive.
3.Finally disconnect the player from the computer, it will say"pleasewait.. building playlist" once this is done you're good to go
I hope this has been helpful... and please... dont forget to rate this solution.
Jermzii
Jan 03, 2009 | Audio Players & Recorders
My Samsung BD-P1400 is frozen on "load" and disc tray won't open
My player worked fine couple of days ago, then last night when powered up, message was "load" and it stayed like this forever, and tray open would not work. Tried everything, nothing worked. Left unplugged from power for 24 hrs and bingo everything worked as should. I suspect that the unit is still trying to load info from last disc which I stopped in the middle of some bonus material, even though the disc was no longer in the tray.
Dec 26, 2008 | Samsung BD-P1400 Blu-Ray Player
Asko D1996HNDL Built-in Dishwasher Logo
26 people viewed this question
Top Asko Dishwashers Experts
Owen Barnes
John Tripp
John Tripp
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
