Question about Sony 42 inch KLV-42EX410 Multi System LED TV
SIR, I M NOT GETTING PICTURE BUT TV GLOWS ON SWITCHING ON. INITIALLY I HEARD SOUND BUT LATER THAT ALSO DISAPPEARED WHILE RESETTING AS NOTHING WAS VISIBLE. PLS HELP..
MY TV IS 2 YEARS OLD AND I HAV INVERTER IN MY HOME WHICH TAKES OVER WHEN MAIN SUPPLY FAILS IN 3 SEC. SO TV SWITCHES OFF AND THEN SWITCHES ON AUTOMATICALLY DURING CHANGEOVER. PLS HELP
welcomejee
  • 10594 Answers
SOURCE: Sony KDL40S2010 Bravia LCD TV... turns off / on on it's own
If TV does not remain in standby and turns on itself then power switch on top of it could be defective and power supply board is also suspected. Take off its back cover and unplug top switch connector just to confirm is that cause of On-Off its own. If problem still exist then power supply board has problem and will be replaced. Let me know the results to move forward.
Posted on Jun 13, 2009
SOURCE: rainbow vertical lines on screen
THAT HAPPENS WHEN IT GETS TOO HOT, MAYBE YOU HAVE TOO MANY THINGS PLUGGED INTO THE SAME OUTLET
Posted on Apr 20, 2009
SOURCE: tv comes on and goes right back off
IT GAVE OUT A LOUD BANG AND NOW I HAVE NO PICTURE OR... Mosfet Transistor blow out.  Transistor K3316 or replace the Power unit supply. This problem was caused by a low power voltage. SONY SONY KE-42TS2U
Posted on May 29, 2009
SOURCE: Sony KDL-32S3000 32in LCD TV.
Hi Chris,
I used to have the same issues with my 32S3000 but I've managed to fix it by factory reset.
It's described in a different post here:
http://www.fixya.com/support/t2222933-complete_factory_reset_sony_bravia_kdl
Good luck.
Rob
Posted on Dec 18, 2009
SOURCE: sony bravia
HI I HAVE A SONY BRAVIA 55 INCH REAR PROJECTION TV MODEL NUM: KF-55E200A. 1 DAY IT JUST MADE A POP NOISE AND THE SCREEN WENT BLACK,NOW WHEN I TURN IT ON IT MAKES A BUZZING SORT OF NOISE,THE SCREEN IS BLACK AND A RED LIGHT FLASHES? WHAT DO I DO
Posted on Oct 01, 2010
Samsung ps42a457 picture disappeared whilst watching,sound still present
Change input device to some other like a DVD player and see.
Switch off TV, switch off power, remove plug and wait for 48 hours and retry.
If problem persists, call in a qualified service technician.
Aug 06, 2012 | Televison & Video
I cant open or send texts from my samsung star.. when i click on the widget or the icon in the menu it says "initializing" and disappears... all my other widgets and apps are working fine
I got the same problem. :))
you must reset your phone.
here is the code ..
*2767*3855# but it will delete your contacts and other files. :))
Dec 08, 2009 | Samsung Star GT-S5233 Cell Phone
No picture on my philips 42PF7321D/37
Bad caps in the power supply must be replaced .
Jul 21, 2009 | Philips 42PF7320A 42 in. Plasma HDTV
Front panel blocked or locked
RCA Entertainment Series 32" Plus Gold, GEMSTAR, xbox ready has been in the shop twice so far. Transformer replaced and 6 months later the picture suddenly had horizontal white lines that gradually spaced apart more from top to bottom and it had a gray hue and fuzzy, but I still watched it for 3 months that way. Today I turned it on and about a minute later I heard a loud crackling sound coming from the back and the picture disappeared, screen went black. Is it worth fixing again? Please contact me at ninalashua@yahoo.com
Jul 09, 2009 | RCA 32F531T 32" TV
How do you change the output setting from hdmi to the rca cable setings? I have no picture screen on my crt tv.
you have to reset the ps3 because you have it with hdmi before and the ps3 is looking for an hdmi connection is very easy and there is nothing wrong with your ps3 ok so do the follow
turn the power switch off on the back of the unit then put your finger in the on/off switch now turn the main switch on the back of the unit you will heard a first bip sound this is when your ps3 turns on ok keep your finger there in the on/off switch until you heard another bip sound now remove your finger from the on/off switch and bingo this will reset your video settings now you can see picture again using regular av and every time you use hdmi you have to do this again
Jun 05, 2009 | Sony PlayStationĀ® 3 (80GB) Console
Sony tv wont turn on, standby light just flashes
check for an open resistor on the power supply, it is actually a fusible resistor, (white) if open, then check the converter, some sets have two separate and some have it as one. it will be on a heat sink on the power supply. if shorted then check for a shorted horizontal output transistor and repair cold solder joints on the horizintal drive transformer which is the real cause of this problem
Jan 07, 2009 | Sony KV-27S46 27" TV
Picture flashing on and off
Press Display / Info button on "TV original remote", such display will disappear.
Nov 17, 2008 | Sony KP-61HS10 61" Rear Projection...
Akai 32" lcd
The sound is a failing relay. It seems you have an issue with the power board. You may have to swap out the board to get this rectified. I recommend contacting a local service center to get this repaired.
Jul 02, 2008 | Televison & Video
Sound/ no picture
dats dfine...switch off ur tv...instead of surfing u go dierctly to an electrician and get it repaired..delay makes u loss nt more than dat....
Jan 08, 2008 | Maxent MX-42HPM20 42 in. Plasma HDTV
Picture disappearance & tv turns off
It sure sounds like you have a classic case of bad solder joints. Resolder all the connections on all boards.
May 31, 2006 | Toshiba 36A43 36" TV
Sony 42 inch KLV-42EX410 Multi System LED TV Logo
19 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
