Question about Panasonic As 300NN A Commercial Grade Electric Stapler with Adjustable Margin and Status Light
Reversing the stapler plate
How do I reverse the stapler plate for the Panasonic AS-300NN, to make a temporary staple?
  • 1 more comment
  • Leo Zimmer
    Leo Zimmer Mar 20, 2014
    To attach a temporary staple, the strike plate is rotated. The ends of the staple typically flair outwards, making the staple very easy to remove and less likely to tear sheets.
  • Leo Zimmer
    I am asking how do I rotate this strike plate on this model?
  • Leo Zimmer
    See: From:http://en.wikipedia.org/wiki/Stapler
2 Suggested Answers
  • 2072 Answers
SOURCE: AS 300 electric stapler--pulled out
What has most likely happened is part of a staple is stuck in the front portion of the stapler where it forms the staple and presses it into the stapler.
You would most likely have to remove the stapler, and remove the binding staple from the stapler head.
Posted on Sep 28, 2008
The spring that loads the staples for stapling broke in half where can I buy a new or used one
  1. Panasonic AS-300NN-A Panasonic Commercial Electric ...
    electricandbatteryofficestaplers.julietshop.tk/panasonic-as-300nn-a-panas...Mar 19, 2015 - Commercial-grade electric stapler with 25-sheet capacity features jam-free operation, auto-reverse, adjustable stapling position and LED status ...
Jul 11, 2015 | Panasonic As 300NN A Commercial Grade...
Stapler malfunction
I don't know, but check how frequently the stapler jams.
Dec 10, 2013 | Panasonic AS-302NN Electric Stapler Heavy...
Refill staples impega hd111
Place the stapler horizontally in front of you, as though you were going to feed in paper from the right-hand side.
On the left of the stapler you will find the staple strip - the metalic box with two small holes in the top. Push the stable strip to the right and tilt upwards to release it. You should now be able to pull it out to the left.
Remove the staple strip completely, and place the new staples onto the track above the spring.
Re-attach the staple strip by reversing what you did to take it out. The end of the staple strip should sit across the track in the same way as the staples. Be aware that this time there will be more resistance as the staples push against the spring in the staple strip.
Jan 22, 2013 | Office Equipment & Supplies
How to load staples into rexel easy touch stapler
If you imagine that the end that the staples come out of is the front, then the back is where you load the staples. Your picture shows a small black bit at the very back of the stapler. You have to remove this, usually by pushing it in and lifting it up. Once loosened, it should pull out from the back of the stapler. You should then be able to reload. Finishing is the reverse process.
Nov 05, 2012 | Tools & Hardware - Others
How do I open the staple compartment? Already tried the back button
Pushing the button should eject the staple compartment from the front of the unit. It sounds as if the stapler compartment is jammed or corroded.
While pushing the button, attempt to pull the compartment from the front of the stapler. It should slide out like a drawer. Try pulling on the front of the compartment while applying a little pressure in different directions.
You may have to use a small tool to grab the compartment if you can't get a good grip. You may have to use some force. Use only as much pressure as you're comfortable with.
When you do open the compartment, inspect all moving parts and bearing points to be sure nothing is jammed, bent, corroded or seeing excess wear. Remove a jam with small pliers, being sure to get the entire staple. Use fine sand paper on corrosion and then treat with a bit of oil.
Sep 08, 2011 | Panasonic As 300NN A Commercial Grade...
Do not know how to put staples in my powershot pro
Howdy, on that model, you withdraw the plunger and turn the stapler upside down and lay the staples on the track (on the botton of stapler, not in the back) with the points facing up. When you replace the plunger, it holds them in place. I really like the reverse stapling action on that model, easier on my wrist. Hope this helps some:)
Farmerbear
Aug 30, 2010 | Powershot Tool Company Cobra 8000 Forward...
The stapler is fixing two staples instead of one at a time.what can be the defect and how to correct it?
First check and make sure the proper staples are in the gun. Also check and make sure the stapler is clear and no jammed or broken staples are in the gun. If this is a desk stapler make sure the plate is locked in for the staple to hit and bend the ends out or in. if all this is working the driver or the piece of metal that pushes the staple out may be bent. If the stapler is new take it back if it is not a minor problem and get a new one.
Jul 01, 2010 | Tools & Hardware - Others
Staples are stuck inside the stapler and will not come out
Typically you do not open these up.
Makes it difficult to remove stuck or wrong staples.
I have had good luck removing the staple ram rod and rapping firmly on the **** of the stapler against a wooden table. The idea is jolting the stuck staples into reverse out the way they went in. Tedious process but usually works. Removing the jammed staples in the nose at the striker plate requires using needle nose pliers and a sharp awl or small screw driver used on very small screws.
My T50 Arrow stapler is over 20 years old.
Still works great. Sometimes I slide in the wrong size staples by mistake. The process above usually works.
May 26, 2010 | Arrow T50P ARROW STAPLE GUN
AS 300 electric stapler--pulled out jammed staples but even though it staples, it won't grab the staples (staples as though empty)
Sep 28, 2008 | Panasonic Office Equipment & Supplies
Panasonic As 300NN A Commercial Grade Electric Stapler with Adjustable Margin and Status Light Logo
52 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
