Question about Hitachi Gst Hitachi L37X01A 37 inch Full HD 1080p Multi-System LCD TV
Power goes down suddenly
After 4 years, the power of the TV longs no more tan 20 or 30 minutes. Then the ligth turn off (no color) and I need to wait for at least 1 hour to turn on again.
    New Friend:
    Problem Solver:
  • 13 Answers
If it is out of warranty, write down the model of boards inside
replace the power board, once installed power it up, and see if this
does solved your previous issues, good luck
Posted on Feb 03, 2015
Will not stay up and running
what brand and model number if DLP TV # BAD LAMP IF LAMP IT'S 3 YEARS OR MORE #2 BAN LAMP FAN # 3 BAD BALLAST (power supply to lamp) # bad color wheel lose connector
Apr 03, 2014 | Televison & Video
Smart T.V Sumsung Got Stuck
It sounds that your TVs' timer function is set to 'ON' for 15 minutes time. Check it, and make it 'Off'. Refer its user manual for details.
Jul 21, 2013 | Samsung UN55ES6500 55 Inch 3D 1080p Smart...
When turning on tv. screen will display Bravia image & then go blank. red light flashes SIX times
Power off the television. Wait a few minutes, then power it back on. If this does not correct the issue leave the power on, point your remote control towards the Sony television and hold the down arrow button. While holding the down arrow button press the "Power" button. Release the down arrow button and the Sony TVicon1.png will reset itself to factory settings. Once the television performs a scan on itself your problem should be gone.
Good Luck Ed Pinero
Read more: How to Troubleshoot the Standby Indicator Flashing on a Sony TV ' eHow.com http://www.ehow.com/how_5925008_troubleshoot-indicator-flashing-sony-tv.html#ixzz2KBk1cWbu
Feb 02, 2013 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
The power steering isn't working. The reservoir was empty and I added power steering fluid and it still very hard to steer
YOU HAVE A RUPTURE PRESSURE LINE IF YOU HAVE NO POWER STEERING FLUID IN THE POWER STEERING RESERVOIR.LOCATE LEAK THEN BLEED POWER STEERING SYSTEM BY ADDING POWER STEERING TO RESERVOIR.DONT OVER FILL BY FULL COLD MARK ON POWER STEERING DIP STICK.ADD FLUID TO RESERVOIR WAIT A 2 MINUTES.CHECK FLUID LEVEL AGAIN.WHEN POWER STEERING FLUID LEVEL STOP DROPPING.START ENGINE LET IT RUN FOR 10 SECONDS.THEN TURN OFF ENGINE CHECK POWER STEERING FLUID ADD FLUID IF FLUID LEVEL DROPS. WHEN FLUID LEVEL STOP DROPPING.SAFELY RAISE SUPPORT VECHICLE FRONT WHEELS.START ENGINE.NOW TURN STEERING WHEEL GENTLY FROM STOP TO STOP MEANING LEFT TO RIGHT DONT HOLD IN POSITION.LET THE STOP TO STOP BE QUICK.CHECK POWER STEERING FLUID AFTER YOU HAVE TURN STEERING WHEEL ABOUT 7 STOP TO STOP.WHEN FLUID LEVEL STOP DROPPING YOU AT HOT MARK ON DIP STICK BLEEDING PROCESS COMPLETE.TURN OFF ENGINE LOWER VECHICLE BACK TO GROUND WAIT ABOUT 5 MINUTES CHECK YOUR FLUID LEVEL.IF FLUID LOOKS LIKE A TAN COLOR.YOUR POWER STEERING SYSTEM FULL OF AIR.TURN OFF VECHICLE LET VECHICLE SET A LONG WHILE TO AIR BUBBLES SETTLE DOWN LOOK FOR LEAKS AROUND POWER STEERING PUMP FRONT SEAL AND CHECK FOR LEAKS AROUND POWER STEERING LINES.
Dec 01, 2010 | 1999 Oldsmobile Alero
TV goes to blank screen after turning it on (about 3 to 4 minutes) but I can still hear it fine. I turn it off and wait a few minutes(5) then turn it back on everything is normal then it goes back to blank...
This tv the LCD inverter board is dead,that why is not sustanning backlight for the LCD screen light to have the picture.Call Polaroid for warrenty repair,this tv under a year old.
Jun 07, 2010 | Polaroid TLA-01511C 15 in. LCD Television
Screen goes black, still have audio
I first changed the 220uf capacitor with no luck. I flipped the BURN switch to on and the set has been working great for a week now. Daughter left it on for about 20 hours overnight with no problem. Anybody have an idea what those 4 tiny switches are for? I have heard these type of switches called "dip switches". They are tiny white switches in a yellow block on the lower left side of the upper circuit board. The top one was labled 40", the next one down was labled 46", the 3rd one was 4 letters "EW" something I think, and then the bottom one was labled "BURN".
Jun 22, 2009 | Polaroid FLM-4201 42 in. LCD Television
OVERHEATED?
yes open it up get dust out run small fans in nit see how long it stays on
Sep 15, 2008 | RCA HD52W56 52" Rear Projection HDTV
Picture warped and colors not lining up
Good Day petepath7;
With separation of colors it sounds like the convergence IC's have failed., but first try unplugging TV from a/c power for 4-5 minutes then plug back in, if no fix see previous.l
Jun 21, 2008 | Sony KP-51WS510 51" Rear Projection...
Tv turns off after 15 minutes of use
For bobby11 and luis, it is the power supply. Part Number EAY34797001 in the 42" and EAY34796801 in the 32". This is a known problem, and somebody should start a Class Action against LG over this one. Part is available online and easy to swap out for anyone with the most basic knowledge.
Jan 16, 2008 | LG 42LC7D-UB Television
TV picture goes out
The tv is shutting down because of a power problem. It could be the power transformer or a color gun overheating. Expect at least a couple of hundred dollars to fix it. Some shops will do house calls for around $65 and can diagnose the problem and give you an estimate. Usually they can just remove the board, take it to the shop and repair it, then reinstall it.
Nov 03, 2007 | Televison & Video
Hitachi Gst Hitachi L37X01A 37 inch Full HD 1080p Multi-System LCD TV Logo
Top Hitachi Gst Televison & Video Experts
slammit
 Mikey
Mikey
ray gallant
Are you a Hitachi Gst Televison and Video Expert? Answer questions, earn points and help others
