Where is the filter located
I want to clean the filter but cant find it. Where is it and how do I get to it please
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 72 Answers
What make and model
Posted on Mar 18, 2014
I have bought a hotpoint washer dryer but with no instructions and i cant get the water to drain out can u help please ?
Remove rear cover of washer.
Locate and remove large black hose on bottom of drum, remove and clean filter inside hose.
Aug 06, 2010 | Hotpoint Aquarius WD63 Front Load...
The TV keeps shutting down due to over heating. Is there something that needs to be cleaned?
Yes you need to clean the AIR FILTER located in TV.
Please follow the steps below to clean it.
1. Turn the television off and unplug the AC cord.
2. Locate the dust filter on the left side panel of the TV.
3. Using a phillips screwdriver, remove the two screws that hold the dust filter cover in place.
4. Remove the filter cover, set it and the screws aside.
5. Carefully remove the filter from the TV.
6. Clean the filter material by dusting with a lint-free cloth.
7. If the filter is soiled, you can rinse it with water. Do not use detergents or soap on the filter.
8. Completely air dry the filter before placing it back into the TV.
9. Replace the filter cover and secure with the screws.
For showing location i have attached a image.
Thanx
Jul 25, 2010 | Mitsubishi WD-52525 52" Rear Projection...
I am installing a chip and cant located the IAT in my 2009 ford mustang. please help. if it was located somewhere else please describe in full where that is located too thanks!
INTAKE AIR TEMPERATURE SENSOR (IAT) is normally located at the engine air filter housing for old models but i think yours its incorporated with the mass air flow unit (assembly). Thats the sensor after the air filter
Feb 01, 2010 | 2008 Ford Mustang
Hi, My zanussi washing machine model z221w does not seem to be draining properly - any ideas? Also I want to check the filter at the bottom rhs of the machine but I cant seem to open it can you help? A...
If you have located the filter at bottom right front of washer, firmly grasp filter handle, and turn anti-clockwise to remove and clean. if it does not come out, then something is jammed in filter, so just keep trying to pull it out.
Please rate my solution.
Thanks.
Nov 06, 2009 | Washing Machines
Hi My Hotpoint WT761 is showing error code F05 which means a blocked pressure switch. I really havnt got a clue when it comes to washers but cant afford a call out - can you tell me how to check for...
If there is no filter at the front of washer, then remove the lower rear panel of washer, locate and remove the large black hose on bottom of drum, remove and clean filter inside hose.
please rate my solution.
Thanks.
Nov 03, 2009 | Washing Machines
Cant find filter to clean. not at the front bottom as usual. wma63 hotpoint. thanks
Remove lower panel at rear of washer, locate and remove large black hose fastened to bottom of drum.
Remove and clean plastic filter inside hose.
Thanks.
Oct 29, 2009 | Washing Machines
My aquarius wd640 is not emptying and is now leaking from the front and where you put the powder helppppppalso i cant find the filter
Remove lower rear cover of washer, locate and remove large black hose, remove and clean filter inside hose.
Thanks.
Jul 28, 2009 | Hotpoint Aquarius WD640 Front Load...
Cant locate ''pump'' on whirlpool awo/d 5556
Hi, Whirlpool manuals do say that but they only mean the filter not the pump as this is self cleaning!
Hope this helps.....
Feb 27, 2009 | Whirlpool Washing Machines
Where is filter
Filter is located in the large black hose attached to bottom of drum, remove hose and clean filter.
Access is by removing lower rear panel of washer.
Plz leave feed back for this solution.Thabnks.
Dec 18, 2008 | Creda W100FW Front Load Washer
Washing Machines Logo
16 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
