Question about Dishwashers
How to replace drain hose defy 3 157 ddw
The is perish
  • 1,511 Answers
The hose is usually connected with a clamp at the lower (underside) section of the washer. You will need to pull out the washer from the space it sits, being careful not to damage the insulation packing around the tub area. Follow the hose to the connecting point and remove the clamp. Turn and twist the hose until it releases from the attachment on the washer. Clean the port well before replacing with a new hose. Slip the new hose onto the port and turn as you put it on the connector. Reset the clamp and feed the other end of the hose back to the drain under your sink. Your done. (In some cases, if an old hose won't come off, you may need to slice it off by cutting with a blade along the axis of the hose and splitting it open, then remove it)
Posted on Mar 18, 2014
Tip
I have problem with DDW-081 recorder it doesn't read CD at all  it read DVD OK...
shove it We encourage you to use Tips and Tricks as a starting point for sharing your technical knowledge and know-how with other FixYa users.
on Aug 24, 2008 | Pioneer DVR-107D DVD±RW Burner
I need to know how to Divide $3,157.00 into 58%
$3157 divided by 58% = $3157 x .58 = $1831.06
Jan 06, 2015 | Office Equipment & Supplies
How do you fix Error Code OE on defy laundromaid electrologic 1300 ? Machine washes, but when it should start to spin, nothing happens - it's just making a noise for a while, no water releases and then...
If draining is not completed in a specified time limit the fault code OE will be displayed.
Check the drain hose is free (not kinked or deformed) and check there is no dirt in the drain filter.
The filter is located behind a cover on the kick-panel at the front of the machine.
May 01, 2014 | Washing Machines
Defy DDW 169 manual
My Defy DDW 169 Dishwasher won't go beyone draining on starting a wash cycle. What is the problem with the machine?
Dec 18, 2013 | Washing Machines
Defy DAW370
time to replace timer/electronic control board and fix it.
You can get part from www.repairclinic.com
God bless you
Jul 11, 2013 | Motorola Mobility Defy Cell Phone
My Powermate 5000 won't start and I suspect it is because it has sat around fully fueled for over a year. What do I need to do and how much should I expect it to cost?
Try the following, it should not cost you very much at all:-
Drain the fuel tank and rinse it out with fresh fuel
Remove the carb and strip it, clean all the metal parts with or in lacquer thinners
Inspect all the rubber parts for cracks or perishing, perhaps fit a new carb kit.
Make sure that all the fuel hoses are flexible, not perished and do not leak. Replace any suspect hoses.
Clean or replace the spark plug
Spray a little WD 40 or similar into the plug hole and turn the engine over several times by hand listening for anything strange.
Replace the re-assembled carb
Fill with fresh fuel and that should be it - you are ready to go.
Feb 28, 2011 | Coleman Powermate Powermate 5000W...
Our defy automaid 600 daw 322, will wash, but will not spin or rinse
My Defy Automaid 600 spin and drain without washing but only drain and do not spin with washing in (i have put only 1 t-shirt in - and still don't spin)
Jan 23, 2011 | Washing Machines
I need a power supply for a brand new lcd hd tv i purchased from coles and they lost it
A generic power supply from **** Smiths or Tandy will do the same thing. You will need to check the required voltage and current or watts on the back of the TV to ensure you get one that has enough power. They generally wouldn't cost you anymore than about AU$50.
Sep 30, 2009 | NuTech Nu Tech DDW-082B DVD+/-RW 8X...
Dishwasher stops after 10 minutes inlet/drain light flashing
1. Air gap / Drain hoses
If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
2. Broken belt
Some dishwasher models use a belt to drive the pump. Replace the belt if found broken.
Note: Sometimes the belt would just come off the pump. Even though it might not be broken, it is recommended that you replace the belt, because it is probably too stretched out.
3. Pump
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
4. Drain solenoid
Some models (for example most GE dishwashers) use a drain solenoid to drain water out. Sometimes the solenoid gets stuck, preventing the water from draining out. Try to free up the solenoid. If unsuccessful, you might have to replace the pump assembly.
5. Motor
If the motor is stuck, it is sometimes possible to free it up by manually spinning the motor.
Replace the motor if defective.
6. Timer
Replace if defective (note: uncommon problem).
May 31, 2009 | Miele 24 in. G646SC Plus Free-Standing...
Dishwashers Logo
51 people viewed this question
Top Dishwashers Experts
