Question about Alcatel Computers & Internet
Alcatel OneTouch Link Y800 don't have Wifi signal
The device just don't send wifi signals. I cannot access the dashboard through Wifi or direct USB connection. Please, help! :((
3 Suggested Answers
  • 44 Answers
SOURCE: cant maintain internet conntection simutaneously on my 3 devices
what is happening is ur voice frequency is bleeding in to the ur digital frequency
what u have to do is change channels of frequency on ur router
type 192.168.0.1 or 192.168.1.1 for most routers
in address bar and that should take u in to the interphase of router then go to wireless settings and change the channel that ur running on
rate my service pleas , July
Posted on Apr 11, 2009
SOURCE: Claro AlCATEL X030 HSDPA USB and a weak signal..
I want a driver for USB HSDPA X200 driver. No driver found at the alcatel site.
Posted on Apr 08, 2010
How do I use wifi on my Alcatel 392cc phone
Teresa, Instructions on connecting to WiFi, press options button, settings, wireless network, WiFi,WiFi settings, choose the network. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to connect to Wi Fi on my ALCATEL ONETOUCH Idol
How to set up Wi Fi on an Alcatel One Touch
Connect to Wi Fi
Aug 11, 2016 | Alcatel Cell Phones
Why can't I access internet?
Restart your device.
If it is your WiFi, unplug everything involved with it for 30 seconds and then plug it all back in.
Make sure wifi is turned on.
Make sure that you are trying to connect to a WiFi signal that you know you can connect to. Not all WiFi signals are ones we can connect to with our tablets, phones, and computers. Try connecting to another signal, or try having another device connect to the one you can't connect to to see if it is a device trouble, or an individual WiFi signal issue.
Nov 02, 2015 | Tablets & eReaders
I keep having to the was button to connect to the internet won't stay connecteded 2 my y800 WiFi device
Your Y800 device is a Wi-Fi router with a 4G connection on it.
It may be the 4G connection is intermittent, not the connection to the laptop.
You need to check with your mobile supplier that it supports LTE.
ALCATEL ONE TOUCH PRESENTS ITS LTE DEVICES FOR MOBILE CONNECTIVITY
Oct 15, 2014 | Computers & Internet
Can't find the wifi signal
Assuming that you are using Windows, the D-Link is properly installed, and that you can go to Start; Settings; Network Connections: and your D-Link appears as a wireless network and that when you double click on it you see a box that lists "wireless networks" that indicates either " no wireless networks in range, or there are some networks, but they are all encrypted, then you are not in range of a wifi hotspot or free wifi access point. If you live in a mobile home as I do you will find that the metal walls effectively block the signals.A simple device that you can use to increase your signal strength can be found if you google "Surf rider" when you are on the net. Find a friend with a laptop, go to a Mcdonalds or a Starbucks hotspot and test your D-Link to verify that it is working Dan
Apr 23, 2012 | D-Link AirPlus Xtreme G DWL-2100AP...
What is WiFi and what is it used for? i mean wifi in mobile phones.
Hey!
WIFI is Wireless Internet. It requires a router which sends a radio signal in which devices with WiFi capability can join the access point to start receiving the Internet on their mobile.
Hope this helped!
Dec 08, 2010 | Samsung Star GT-S5233 Cell Phone
Excellent signal low speed transfer
You can boost the signal range of a WiFi computer network in several ways: Answer:
  • reposition your router (or access point) to avoid obstructions and radio interference. Both reduce the range of WiFi network equipment. Common sources of interference in residences include brick or plaster walls, microwave ovens, and cordless phones. Additionally, consider changing the WiFi channel number on your equipment to avoid interference.
  • upgrade the antenna on your router (or access point). WiFi antennas on most wireless base stations can be removed and replaced with more powerful ones.
  • add another access point (or router). Large residences typically require no more than two APs, whereas businesses may employ dozens of APs. In a home, this option requires connecting your primary wireless router (access point) to the second one with Ethernet cable; home wireless routers and/or APs don't normally communicate with each other directly.
  • add a bi-directional WiFi signal amplifier to wireless devices as needed. A WiFi signal amplifier (sometimes called "signal booster") attaches to a router, access point or Wi-Fi client at the place where the antenna connects. Bi-directional antennas amplify the wireless signal in both transmit and receive directions. These should be used as WiFi transmissions are two-way radio communications.
  • add a WiFi repeater. A wireless repeater is a stand-alone unit positioned within range of a wireless router (access point). Repeaters (sometimes called "range expanders") serve as a two-way relay station for WiFi signals. Clients too far away from the original router / AP can instead associate with the WLAN through the repeater.
Nov 19, 2009 | Sony Computers & Internet
Want to increase my wifi signal
usb not bestto use need new wirless n linksys ok on sale 99 cc this week and n pcmia card to go in labtop up to 1000 ft away 5 bars ok
Feb 06, 2008 | Televison & Video
Computers & Internet Logo
162 people viewed this question
Top Alcatel Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you an Alcatel Computer and Internet Expert? Answer questions, earn points and help others
