Rapoo 1090P Interference-free 5.8Ghz Wireless Mouse, Grey Logo
M
Michael Ami Posted on Mar 18, 2014
Left click not working
1 out of two clocks left button does not click
Clock settings on clarion db346mp wont set time
See if this works for your item. It was posted in 2009:
Setting the Clock
1) Press and hold in the BAND button [4] then press the DISP button [9] to toggle the display to the clock mode.
2) Press and hold in the BAND button [4] then press and hold in the DISP button [9] for at least 2 seconds.
3) Select left or right to adjust the time using the a-selector
~Adjusting minutes
Each time you select right >> using the a-selector [3], the minutes increment up by one digit (0 to 59).
~Adjusting hours
Each time you select left << using the a-selector [3], the hours increment up by one digit (1 to 12).
*The clock only displays time in a 12-hour format.
There is no way to toggle the clock to a 24-hour format.
4) Press the BAND button [4] to set the clock into memory. This also resets the seconds counter to zero.
Note:
*The clock can only be set by turning power on to the unit and switching to the clock display mode. You cannot set the clock when it is displayed with only the igntion on. If you drain or remove the car's battery, the clock must be reset. While setting the clock, if another button or operation is selected, the clock set mode is canceled.
2helpful
I need the full instructions for the setting of my sunbeam Westminster quartz clock - model# 882-495
A similar question was asked on FIXYA a number of years ago, and may prove useful:
http://www.fixya.com/support/t476305-instructions_sunbeam_clock_model_882
Instructions for Sunbeam clock model # 882-495
Sunbeam Westminster Clock, model # 882-495. Clock was just given to me with no instructions. battery has been replaced and I'm trying to figure out if the clock is broken and no longer works or if I don't know how to properly set the time.
Posted by Anonymous on Mar 29, 2008
OldPoop55
Move the second button from the left to set, enter the time in 24 hour format via the HH and MM buttons, then move the button to start. The far left switch, on/auto.off is for the chime. Set to on for 24 hour alarms, set to auto for no chime from 11pm til 6am, set to off, to turn it off.
Posted on Jun 08, 2011
  • dan daniels
    I had to leave the far black left switch on or up,turn the white set /run switch to set..the far left hour is the 10 , the next hour is the 1, the next min is the 10, the far right is min 1.
    when you want to set tghe clock time .press the button and count the chirp for the time..for 10: 36 press the far left button 1 time.. do not touch the next 1 hour button..: touch the 10 min button 3 time or 3 chirps.. press the 1 min button 6 times or chirps.. then set the set switch up or run..the chime should chime every 15 min.. and the hour should chime for te hour on the hour..
    Posted on Apr 23, 2013
    • tlwhitley1
      YES! Like BA said, inside the clock are switches. Turn one to OFF. Move the other to SET. Then push the H button the # of the hour it is. There are one (far left) and two digit #s (far right). I'd tried to fix this clock we bought for my mom and dad some 15 years ago.....finally the clock works again! Thanks BA!!
      Posted on May 13, 2010
      • Anonymous
        JUST PRESS THE BUTTONS ON THE INSIDE OF THE CLOCK WHILE THE MAIN SWITCH WAS IN THE OFF POSTION. ONCE THE HOUR AND MINUTE WERE ADJUSTED, THE MAIN SWITCH WAS SET TO ON AND THE CLOCK WAS TICKING.
        THANKS.
        Posted on Mar 30, 2008
        • Luke Green Feb 01, 2014
          the clock has a set button,turn the clock on and turn the set button to set,then where the hour buttons are there are two,one on the left and one on the right.When you completed the steps above,Press thesecond button on the right side of the hour set,then for each time you press it,the clock will adjust per hour.So press itonce and then press test,it should give u one chime,press two and it should chime for two oclock,press three times and it should chime three time,usew this theroy and it should be all you need,ofcorse you will have to use common sence.Thanks and good luck
          remember for each time you do this u have to move the button from set to run for complete test.SO set to set then press one on the second button of hour,then turn it from set to start and then try it again.make sence?each time u adjust it you have to turn it from set to on then try the test after each adjustment.Good luck
Oct 05, 2019 • Home
6helpful
2answers
No name on the oven so presume it's a Europa same as the cooktop. It won't move off 0:00 with automatics on the lefthand side showing.
Hi -
I'm assuming this is an Omega/Creda Europa oven. All you need to do to make the oven work again is set the clock. The 0:00 and "AUTO" will stop flashing and the oven will work again. You didn't specify a model number, but you should be able to set the clock as follows:
1. Hold down the two buttons on the left-hand side under the clock display. One should have a symbol of a bell and the other, a symbol of a cookpot (not a cookpot and 'STOP').
2. While still holding both of these buttons, use the + and - buttons to set the clock to the correct time. The clock needs to be set in 24 hour format.
If this doesn't work, look for the buttons under the clock with the bell symbol and the cookpot symbol. Hold both of these buttons in and use the + and - buttons to set the clock.
If this doesn't work or your clock doesn't have these buttons, let me know and I'll check for other possible methods of setting the clock on Europa ovens. If you can find the model number it would assist me greatly. This should be on a sticker on the rim of the oven and can only be seen when the oven door is open - possibly at the bottom. The model number should be something like 40-1, 60-1 or 66-1.
If you can't find the model number, please let me know how many buttons there are in total below the clock and which symbols are written above each button and the order from left to right. I will then be able to provide the correct instructions for your oven.
Hope this helps.
Regards,
BElectric
Apr 18, 2011 • Ovens
How do I set the current time on the Woods Digital Timer Model#59203?
78a8604.jpgWoods 59301
Manual for 59301
http://waterheatertimer.org/pdf/Woods-59203.pdf
Plug timer in wall for 1-2 hours so rechargeable battery charges
If display does not show after 1-2 hours, the battery is dead and timer is no good
After 1-2 hours, you can remove timer from wall to program
Press reset (R) with paper clip to clear memory
Select format: Press and hold Clock button until 12 hour or 24 hour shows on display, then release
Press hour button to change display to 12H
press Clock button and display returns to normal
AM shows in upper left corner
Set current time:
Press and HOLD clock button
While holding clock button, press hour button and minute button until display shows current time
Release clock button
Press and HOLD days button until current day shows in display
Release days button
Further instructions to set ON-OFF times are in manual (click link shown above for manual)
If you have problems, re-post additional question.
How to set clock on clarion drx7375
Setting the clock
1. Press and hold ADJ button 4 for 1 second or
longer to switch to the adjustment selection
display.
2. Press the right or left side of SEARCH button
% to select “CLOCK”.
3. Press ENT button 2.
4. Press the right or left side of SEARCH button
% to select the hour or the minute.
5. Turn the Rotary knob & clockwise or
counterclockwise to set the correct time.
* The clock is displayed in 12-hour format.
6. Press ENT button 2 to store the time into memory.
7. Press ADJ button 4 to return to the previous mode.
Note:
• You cannot set the clock when it is displayed with
only the ignition on. If you drain or remove the car’s
battery or take out this unit, the clock is reset. While
3helpful
What buttons change time display
How do I set the clock?
A5
There are several methods to set the clock, depending on the model.
Method 1
Press and hold the BAND and DISPLAY buttons to display the clock
Press and hold the BAND and DISPLAY buttons until the time display flashes
SEARCH left to adjust the hours; right to adjust the minutes
Press BAND button to store the time
Method 2
Same as Method 1, except press DISP to store the time
Method 3
Press ADJ
SEARCH left or right to select clock and press ENT
SEARCH left or right to select the hour or minute
Turn rotary knob clockwise or counter-clockwise to set the correct time
Press enter to store the time
Press ADJ to return to the previous mode
Method 4
Press and hold the BAND and FUNCTION buttons to display the clock
Press and hold the BAND and FUNCTION buttons until the display flashes
Search left to adjust hours; right to adjust minutes
Method 5
While the display is showing the clock, press and hold the CLOCK knob until the minutes flash
Press the CLOCK knob to adjust the minutes
When the CLOCK knob is released for 5 seconds, the hours will flash
Press the CLOCK knob to adjust the hours
When the CLOCK knob is released for 5 seconds, the time will be stored
A5
Method 1
Method 2
Method 3
Press ADJ
Method 4
Method 5
A5
Method 1
Method 2
Method 3
Press ADJ
Method 4
Method 5
A5
Method 1
Method 2
Method 3
Press ADJ
Method 4
Method 5
A5
Method 1
Method 2
Method 3
Press ADJ
Method 4
Method 5
go to this web site for any thing about ur stereo
http://www.clarion.com/us/en/support/faq/Audio/index.html
Need instructions for my sr927w accurist watch
QUICKSTART - SET THE TIME
1. Push the bottom right hand button until the mode hand indicator points to TME.
2. Press and hold the upper left button for three
seconds. The hour and minute hand will retract to the 12
O’clock position.
3. Select the time zone on the digital display by pressing the
upper right button or the lower left button.
4. Pull the bottom right button out one click. The bottom part of
the digital display will start flashing. Press the
bottom left button to adjust for daylight saving time.
5. Press the upper right button. You will see the seconds
flashing on the lower half of the digital display. Press the lower
left button to reset the seconds to 00.
6. Press the upper right button. You will see the minutes
flashing. Press the lower left button to set the minutes to your
current time.
7. Press the upper right button. You will see the hours flashing.
Press the lower left button to set the hours to your current time.
8. Press the upper right button. You will see 12H or 24H
flashing. Press the lower left button to switch between 12 hour
and 24 hour.
9. Push the lower right button back in.
SET THE CALENDAR
indicator points to CAL.
2. Press and hold the upper left button for three seconds. The
hour and minute hand will retract to the 12 O’clock position.
4. Pull the bottom right button out one click. You will see the
month flashing on the digital display. Press the lower left button
to change the month.
5. Press the upper right button and the date will begin flashing.
Press the lower left button to change the date.
6. Press the upper right button. You will see the year flashing.
Press the lower left button to change the year.
7. Push the lower right button back in.
SET THE ALARMS
indicator points to AL1, AL2 or AL3.
4. Pull the lower right button out one click. You will see ON or
OF flashing on the digital display. Press the lower left button to
turn the alarm on or off.
5. Press the upper right button. You will see the hours flashing.
Press the lower left button to change the hour.
flashing. Press the lower left button to change the minutes.
SET THE TIMEZONE
1. Setting the time zones allows you to add or remove cities on
the digital display or switch between daylight saving and
standard time. Begin by pressing the lower right button to move
the mode hand indicator to SET mode on the bottom dial.
2. If the hour or minute hands are obscuring the digital display,
press and hold the upper left button for three seconds. This will
cause the hour and minute hand to retract to the 12 O’clock
position.
3. Now pull the lower right button out one click. You will see the
digital display flashing. Press the upper left button to select
SET to display the city or OFF to not display the city. Press the
lower left button to turn summer time on or off. Summer time is
indicated on the lower part of the digital display. Daylight
savings time must be manually set for each city.
4. Pressing the upper right button will allow you to scroll
through all the cities. After setting, push the lower right button
back in.
USING THE TIMER
1. Press the lower right button to move the mode hand
indicator to TMR mode on the mode dial.
position.
3. Pull the lower right button out one click. You will see the
minutes flashing in the digital display. Change the minutes by
pressing the lower left button. Once you have set the minutes
on the timer, push the lower right button back in.
4. Pressing the upper right button starts and stops the timer.
5. Press the lower left button when the timer is stopped to reset
the timer to its initial preset time.
USING THE CHRONOGRAPH
1. To use the chronograph press the lower right button to move
the mode indicator hand to CHR mode on the mode dial.
3 .To start or stop the chronograph press the upper right
button. If you press the lower left button it will display the split
time for 10 seconds.
4. When the chronograph is stopped press the lower left button
to reset back to zero.
SET THE TIME ZONE
the mode indicator hand to SET mode on the bottom dial.
savings time must be manually set for each city..
through all the cities. After setting, Push the lower right button
back in one click.
Hope this helps. =)
24helpful
Setting instruction for Accurist world time wrist watch
Same just happened to me, performthe following:
The analogue hands are not precisely synchronised with
the digital time?
1. Press the lower right button to move the mode indicator
hand to CHR.
2. Pull the lower right button out one click. The hour, minute
and UTC hands will retract towards the straight up 12 O’clock
position. You will see UTC on the top half of the digital display.
3. Press the upper right button to advance the hands to the
straight up 24-hour position. Use the lower left button to go in
reverse.
4. Press the upper left button. You will see HR on the top half
of the digital display. Press the upper right button to advance
the hour and 24-hour hand clockwise until they both point
straight up at the 24-hour position. Use the lower left button to
move the hand anti-clockwise.
5. Press the upper left button. You will see MIN on the top half
the minute hand clockwise or the lower left button to move
anti-clockwise until it is pointing straight up at the 12 O’clock
position.
6. Push the lower right button back in one click.
The watch malfunctions in some way and the above
procedures do not work.
1. Press the lower right button until the mode indicator hand
points to TME.
2. Pull the lower right button out one click. Press the other
three buttons down simultaneously for three seconds and
release. You will see 8’s on the digital display.
3. Press the upper left button. You will see UTC on the top half
the hands of the top dial to the straight up 24-hour position.
Use the lower left button to go in reverse.
position.
Jul 06, 2008 • Watches
24helpful
5answers
5helpful
9answers
Clock
Turn the system on and press the "Clock/Timer" button (located above the eject button for Deck 1). The clock will appear. To change the time, simply hold down either the < or > buttons (the ones you use to change radio stations and begin CD/tape playback). Press "Clock/Timer" again to lock in the time.
Top Rapoo Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Rapoo Computer and Internet Expert? Answer questions, earn points and help others
