Question about Amcor Aire AMS241HX Split System Air Conditioner
After a power surge, delonghi portable ac 100el won't power on
How do you disassemble a delonghi portable air conditioner to replace the plastic fan squirrel cage?
See if there is a youtube video available or go to delonghi's web site to get a diagram
Apr 09, 2015 | DeLonghi Heating & Cooling
How to remove water tank of delonghi P AC W130 portable air conditioner
OWNERS MANUAL for DELONHI
PAC W130
http://www.delonghi.com/Global/InstructionManuals/GB/GB-5751018800.pdf
Oct 29, 2013 | DeLonghi PAC W130 Portable Air Conditioner
Ok So We Bought This. But We Have A Problem Does It Take Water Or Not? Thats What I Need To Know! Please Help!
The DeLonghi PACA120E Portable Air Conditioner quickly cools rooms up to 400 square feet and comes equipped with several functions that make operation easy and low maintenance. Its 3 operating modes are supplemented with no-drip technology, an adjustable thermostat, 24-hour timer, and much more. This unit truly takes the work out of cooling medium- to large-sized spaces. Multiple Modes and Functions The DeLonghi A120E-also known as the Delonghi Pinguino PAC A120E-offers 3 operating modes and 3 additional operating functions that make this model versatile and energy efficient. Cool Mode: 12,000 BTUs of cooling power help cool large rooms, offices, or basements. Dry Mode: Reduce room humidity by removing excess moisture from the air. Fan Mode: Circulate air to keep your room comfortable without using a lot of energy. Low, medium, high, and an auto-speed are all included (auto speed selects a fan speed for you). Smart Function: Your AC uses Cool and Fan mode based on ambient room temperature. This function will also select your fan speed and keeps your room comfortable without wasting energy. Sleep Function: Using a low fan speed, the AC gradually reduces operation so your room remains comfortable but the AC runs more quietly and efficiently while you sleep. Boost Function: This function is ideal for the summer months and uses the maximum fan speed to rapidly reduce your room temperature. Useful Features Using DeLonghi's patented no-drip technology, this unit is "dripless" under normal conditions, meaning the AC will discharge all of the moisture collected from the air-so you typically won't have to worry about draining the water. When dehumidifying a lot of moisture in Dry mode, excess water may collect in the internal collection tank. Once the tank is full, the air conditioner will automatically turn off to avoid overflow damage. You can also use the included continuous drain hose as a no-fuss way to eliminate excess water as needed. An adjustable thermostat provides additional convenience by allowing you to set your room temperature. The DeLonghi portable AC will cycle on and off to eliminate over-cooling and maintain the set temperature. Additional Features Washable Air Filter: A washable air filter helps remove allergens and other particles from incoming air and saves you money on replacement filters. Quiet Operation: High efficiency compressor and components result in quiet performance. Electronic Controls: The LCD screen displays the timer and temperature settings, while intuitive indicator lights accompany each operating mode. 24-Hour Timer: This feature lets you program your AC to turn on or off up to 24 hours in advance, so it only runs when needed. Window Bracket: Double window bracket is included with purchase for flexible installation. Self-Diagnosis System: The unit includes a self-diagnostic maintenance system that identifies malfunctions should they occur. Remote Control: Use the full-featured remote control to change modes, set the timer, and select a fan speed up to 23 feet away from the receiver (on the front of the unit). Portability: Easy-roll casters and dual carrying handles make it simple to move this model from space to space.
Aug 06, 2012 | DeLonghi PAC A120E 12000 BTU Portable Air...
I am using Delonghi PAC A120E and there power surge which affected the Power Board. How can i get this fixed? Can i get the power board to buy and where? please i need your help now!!
To order a part from Delonghi, call their parts dept @ 1 (800) 865-6330.
To locate a service center near you go to the following link: http://delonghiusa.com/support/servicelocations
I hope this helps you and thanks for choosing FixYa.
Aug 23, 2011 | DeLonghi CF210 Portable Air Conditioner
How to power European version in the U.S.
No--The cycles are different so you need a transformer.
Apr 17, 2010 | DeLonghi EAM3500 Espresso Machine/Coffee...
When turn on display reads PF and no AC???
PROBE FAILURE -check their website for the list of error codes here
It says to contact repair department.
Mar 29, 2010 | DeLonghi Pinguino PACL90 Portable Air...
Delonghi AC problem
suspect a faulty running capacitor.
Apr 24, 2008 | DeLonghi Pinguino PACL90 Portable Air...
CF 210 Delonghi
i just found out that e3 means voltage problems. i plugged my into a place i knew would have enough voltage and it started right up with ac
Sep 10, 2007 | DeLonghi CF210 Portable Air Conditioner
Amcor Aire AMS241HX Split System Air Conditioner Logo
Top Amcor Heating & Cooling Experts
AJMAL KHAN
Donni Steen
Bill Long
Are you an Amcor Heating and Cooling Expert? Answer questions, earn points and help others
