Question about Sharp AR-5520N
Copy is lighter at one end
I have replaced tonner and developer but the copier copies lighter at one end compared to the other end
  • 4 Answers
SOURCE: Sharp copier sf 2530 developer reqired error code (ie indicator on)
It's hard to be sure because our model numbers are different but drum reset should be 24-7 and dev reset should be 24-6. Good luck
Posted on May 30, 2008
mickspaceNET
  • 115 Answers
SOURCE: white stripes on pages copied from ARM 205
If you changed your developer? Or did you change the Toner Cartridge?
White stripe? Check the charge on the drum, it might have a piece of dust on it.
take the charge out, (dont take it apart) hold it up to some light, you might see some dust particles hanging in the grid. If so, rub very lightly with finger, do not use a cloth to clean. Blow it with a can of air.
Clean the transfer charge as well
Usually replace those as it is such a pain to clean on the smaller machines.
if you need any further help let me know
Thanks
Posted on Nov 05, 2008
jonb3838
  • 237 Answers
SOURCE: SHARP AR201 COPIER
Hey Robert,
Sounds like it could be in need of a maintenece kit. The ghostinf is usually caused from the fuser or transfer roller. And that would also apply to the band down the page.
Posted on Feb 13, 2009
tehnik_bdg
  • 91 Answers
SOURCE: sharp al-1631 copier wont copy
It probably the toner cartrisge is empty or if there's an error code H4, the heater lamp is spoiled
Posted on Apr 03, 2009
  • 39 Answers
SOURCE: Copier lifetime copies
That's an interesting question with quite a range of answers, but in my opinion i'd say the range is anywheres up to 1,000,000 copies. I say that because the toner is good for about 25,000 / cartridge and it's built around a fairly robust box (unlike the picture posted here). But quite honestly most will die prematurely due to technical repair deficiences or time alone. If your copier technician is overly budget oriented (as we all are to some degree) then your copier will only recieve the parts that you scream for and this tends to cause customer dissatisfaction and therefore a copier upgrade( replacement) or the other senario is If you only run 1,000 prints/month the copier will never see 100,000 prints.
Posted on Dec 17, 2009
The copies on our Lanier/7313 come out zebra stripped. The copies appear to copy better if we change the copy darkness to a lighter color.
Zebra striping is typically caused by a bad development clutch. Most likely, the developer and the development clutch will need to be replaced, but the 7313 is so old you may have trouble finding parts, or finding a technician to work on the machine.
Sep 21, 2010 | Lanier 1205 Copier
Afficio 450e gray copy or lighter copy
Look into replacing the developer in your copier. It has to be replaced every 125,000 cycles.
Jan 14, 2009 | Office Equipment & Supplies
BizHub 250 Malfunction Code C2557 - HELP!
I can even reach the "service mode".
The screen shows the error (c2557) and I can not access to anyother function.
Nov 11, 2008 | Konica Minolta bizhub 250 All-In-One Laser...
Canon ir 400 copier
Check the scanner. If the lube has dried up it could be causing the scanner to vibrate slightly when reading the image.
Oct 14, 2008 | Canon imageRUNNER 400S Copier
Sharp ar-m237 copier
Direct light can effect the copies. Your unit may also need developer as well. If the developer is low or gone out of the unit, light copies will appear as well.
Jul 10, 2008 | Sharp AR-M237 Copier
Reset the developer by pressing C-CA-0-C - 83-5
May 16, 2008 | Office Equipment & Supplies
Sharp AL-1340
Try this: make a copy from the table and then one from the document feeder. compare the two. If the copy from the table looks good and the document feeder one is bad then clean the glass on the document feeder. If both are bad remove the top glass and clean the mirrors using rubbing alcohol and a lint free cloth. you can also clean the wheels on the feeder and in the tray with rubbing alcohol if you ever have feeding problems
Hope this helps
Apr 12, 2008 | Sharp AL-1641CS Laser Digital Copier
Sharp AR-5520N Logo
19 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
