Question about Toshiba Televison & Video
Back light problems
When i first put my Toshiba Tv 32AV615DB on the picture is blurry and all different colour lines go across the screen so it is unwatchable, but it takes a while till the picture comes back, any ideas what the problem can be ?
    Sergeant:
    Champion:
  • 266 Answers
This tv has far too many options. Toshiba like to make one set for all markets.
Here is the manual.
http://www.toshiba-om.net/PDF/English/Country_Specific/AV615-1922263237-English-Specific.pdf
Start over, as if from the box, and set everything to default
Posted on Mar 18, 2014
premtech
  • 934 Answers
SOURCE: please help
Either the logic board or the power supply have failed and in either event I would strongly urge that you not even attempt the repair and just go purchase another (BETTER) Tv... I don't often tell people this check my posts. But that unit is simply riddled with problems and VERY VERY difficult to get parts for.. Samsung or Hitachi have some good bottom end LCD's (we in the industry call throw-aways) comparable in price and FAR better Tv's than the one you have there...
Bill
Posted on Apr 23, 2008
  • 135 Answers
SOURCE: thin line of no picture across tv screen
this is a resistor gone on the board easily fixed
Posted on Jan 18, 2009
  • 718 Answers
SOURCE: insignia ns32lcd no picture just lots of vertical colored lines
Usually this problem is caused by the connections for the LCD Controller(TCON). If you disconnect and re-connect the cable until it works correctly it will usually solve this problem.
Posted on Feb 23, 2009
SOURCE: Vertical colour lines on whole screen
The problem is that the panel has failed. Apparently this is a common problem with LCD TV's between 18 mths and 3 yrs old. If it survives over 3 yrs it is likely to last for a few years longer. The cost of replacing the panel is more than a replacement TV!
Posted on May 26, 2009
heavyice
  • 374 Answers
SOURCE: hpr4262 samsung plasma picture problem
You need to call a technician.The problem lies in the board [internal].
Posted on Jun 25, 2009
I have a toshiba 32av615db tv. the picture has coloured barcode type lines when switched on, this las for up to 30 minutes. what is the problem?
The screen is faulty it will get worse, nothing you can do but replace screen which is not an economical repair
Jan 24, 2018 | Toshiba Televison & Video
Toshiba 50H81 very dark, blurry picture on all inputs.
check if the problem looks zig zag looking or it its not present in the PIP window. If so this may be an issue with the hypermodule - you can google TV repair Kits to find parts.
Mar 27, 2012 | Toshiba 50H81 50" Rear Projection...
I finally got my tv hooked up. but the color and the picture is blurry, mostly on the top. i have tried different things but no matter what it doesn't change the blurriness,and some lines come across...
Tv have a R,G,B colors lines misalignment,have picture shadows or 3D picture look alike?Yes,than tv have a problems known as a convergence problems,it is dead.The tv convergence board must be repair,by replacing like 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence picture problems.The shop will cost u like $300-350 for parts and labors.
Jun 13, 2011 | Toshiba 57H81 57" Rear Projection...
Have horizontal lines across the screen and some
Yeah we have the same exact problem here. Defective TV....ours would correct itself after 30 mins, but now it's blurry all the time. I'm never dropping 2K on a SONY tv again.
Aug 01, 2010 | Sony Bravia KDL-46VL130 TV
Do not have copy of owners manuals and user guides
Problem is likely with a setting at the picture source. Make sure you only have enabled the setting your TV is capable of (480i, 480p, 1080i, etc)
Apr 07, 2010 | RCA HD52W56 52" Rear Projection HDTV
Intense white & coloured horizontal line on black background on startup
I wouldn't attempt as the capacitors on a tv store around 25000 volts this is more than enough to kill you and they keep there charge even when the tv is off. Either take it to a repair shop or put that money towards buying a new tv - Do not even attempt to open the tv. (It sounds like maybe a tube has gone or the electromagnet that makes the beam move vertically is gone.
Sep 03, 2008 | Televison & Video
Dark Blurry Ink Line
When I print darker color images I get what I call Zebra stripes across the picture on a slant about 1/2 inch apart. Changed the toner and the drums are at 45% capacity. Any suggestions. Thank you.
Sep 03, 2008 | Konica Minolta magicolor 7450 Laser...
Fault on TV
something fried .. sounds like the vertical has gone ,
call a tech.
Mar 07, 2008 | Televison & Video
Color line across the center of a black screen
Hi. this is caused by dry solder joints on the frame o/p IC. Resolder all legs of frame chip. Should sort that out.
Sep 06, 2007 | Toshiba 32A60 32" TV
Televison & Video Logo
111 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
