Question about Garden
1999 Johnson 70hp 2 stroke outboard how can I disconnect the self mixing oil tank and premix oil and fuel myself?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 72 Answers
The self mixing use variable rate which is much better then mixing it yourself. why would you want to change it?
Posted on Mar 19, 2014
Editor925
  • 285 Answers
SOURCE: 2 cycle oil to gas mixture ratio
40:1 for a McCulloch 3214.
Posted on Jun 24, 2009
  • 4088 Answers
SOURCE: petrol and oil
If the saw in not over 30 years old, it should be safe to use 40:1 fuel to oil mix providing that you use a modern synthetic saw oil. Don't use boat motor oil or other petroleum based oils. Premix them very well in the saw's own fuel can and agitate the can before each use. Regular chain/bar oil is used in the oil tank. Good luck!
Posted on May 16, 2010
ftw1952
  • 10319 Answers
SOURCE: What is the correct oil/fuel mixture with non
40 to 1 is also out there
to get the correct mixture the name and model is needed
Posted on Aug 28, 2010
SOURCE: I HAVE A YAMAHA 20D
http://aquamarket.spb.ru/catalog_yamaha/OM/2/1B6L2300F1.PDF
manual at above link, not English, but still helpful?
http://www.myboatingshop.com/my-boat-show/new-outboard-motors/yamaha-outboards/two-stroke-20d-hp
Info in English re motor. above. Below is a service manual link, pay for.
http://www.amazon.co.uk/YAMAHA-MARINE-OUTBOARD-SERVICE-MANUAL/dp/B003IP4YBU
Posted on Jul 08, 2011
SOURCE: I need to know the
2-cycle engines use 40:1 ratio
Posted on Jul 12, 2011
Hi, my outboard stopped suddenly shows me warnings lack of 2 stroke oil.my system is premix is there any one can explains why? even i followed the strict measures!!
Hi, What model outboard? Make, hp, and year.
It sounds like your outboard was originally oil injected, having a separate oil tank that supplied the 2stroke oil to the motor,....but a lot of people disconnect the oil injection systems due to a fear of it failing (sometimes justified, mostly not).
When the oil injection is disabled/disconnected, all that happened was the separate oil tank and hoses were removed, and the oil instead simply added and mixed with the fuel at the nominal 50:1 ratio.
Your problem sounds like one of 2 warning systems that were part of the injection system, warnings intended to inform you that the oil tank level was getting critically low!
These need to be bypassed when an oil injection system is removed from an outboard. For example, many Mercury and Mariner outboards had a simple float switch in the oil reservoir located under the cowling next to the motor. If the level got low, the float dropped, and a magnetic reed switch closed, which operated the warning buzzer inside the control box. Loud as fark normally.
So if the engine has been fine, running premixed oil/fuel for years and just started showing these warnings, one of the bypassed level switches has been triggered, so if you can determine where it was connected on your motor, and how it was bypassed so to always give a "full" signal, it is likely that your problem will be very obvious to anybody remotely familiar with marine engines.
Feb 09, 2018 | Boating
Carbies on 50hp Johnson outboard fill with oil when left standing for extended times
2 stroke , excessive oil in mix and it is settling out after the fuel evaporates off
4 strokes the unit should be left in the drive position when not used
Dec 16, 2017 | Johnson Boating
What size and year is this E70 TLCCA
Douglas, Outboard appears to be 1988, 70 HP. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Find 1988 Evinrude E70TLCCA 70hp Outboard Motor Parts by Engine Section
Evinrude Johnson outboard parts Drawings How to videos
1988 Evinrude E70TLCCA 70hp Outboard Motor Google Search
Jul 03, 2016 | Clymer Evinrude/Johnson 2-70 HP Two-Stroke...
Do I use reg gas or a gas mix?
Matt, If engine is two stroke and not oil injected then yes you must mix 2 stroke oil and fuel. 4 stroke engine have a crank case which is filled to proper level with 4 stroke engine oil. Check the attached links,instruction and guides, Good luck
How to Decide Between Two or Four Stroke Outboard Boat Engine
4 Stroke Outboard Motor vs 2 Stroke Outboards
2 stroke outboard Vrs 4 stroke outboard
http://www.cottagetips.com/tips/boat-motor-gas-to-oil-ratios
Apr 15, 2016 | Boating
Fuel 2 oil mix on Johnson outboard 1964 -18h
50 to 1 all ways go for the higher as the oil is lube and a hot outboard needs it if you are wrong it will still run hard to push a boat home but in this case 50 to 1 is the one be safe on the water
Apr 06, 2015 | Trueshopping NEW 2 STROKE OIL FUEL PETROL...
I just bought a 1998 5hp 2-stroke Johnsons motor and was just wondering what's is the best mix for it?
While the two cycle oil has it on the back of the bottle but with my 1998 I would pure a bottle in it or depin on how much gas you got I like my gas kind of a blue tint
Feb 08, 2015 | Boating
Evinrude outboards
Johnson and Evinrude carbureted 2-stroke outboards since 1964 require a 50:1 fuel to oil mixture (2%) on engines without an automatic oiling system - 6 gallons of gas to 1 pint of outboard oil.
Aug 30, 2014 | Garden
Change oil
It is a 2 stroke there isn't any oil in your engine perse, basically your bike either runs premix fuel or it has a oil reservoir that injects oil in to the fuel mix. 2 strokes mix fuel and oil together in the crankcase, that is why 2 strokes are somewhat smokey. The oil that is injected or in the case of premix is what is used to lubricate the engines internals. So you won't be able to change the oil by draining it out of the engine block. If it has an oil reservoir you will need to top that up from time to time.
Oct 23, 2013 | 2005 Gilera Runner VX 125
18hp titan outboard 2 stroke with outside tank.its a 25ltr tank.want to know proper mix or if i use 5ltr fuel the proper mix
50 to 1 oil gas mix on 99% of all outboard engines. 1 pint to 6 gallons.
I like Quick Silver oil or Sierra oil. Hope this helps.
Oct 08, 2013 | Boating
Garden Logo
83 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
