Storejet 160gb my harddisk are contening the computer bt its not showing any disk,,,but power light is blinking.what is the problem.plz tell me
    Master:
  • 397 Answers
I have had just had this issue with one of my clients external drives. In most cases it will either be the outer shell/usb headers that are faulty or the hard disk itself is faulty.
The power light coming on, the drive spinning up, light blinking etc are good signs but by no means an indication the drive is in anyway working.
It is quite likely your drive has failed. To check this I would extract the drive from the external USB shell/caddie and connect the inner hard disk through other methods. For example another USB caddie. If you find the drives detects, installs and operates ok you can safely assume the previous shell/caddie was at fault. If you find the drive still does not work I would run a test with Seatools:
SeaTools Seagate
If the drive fails Seatools diagnostics or simply does not get detected by the system I would say the drive had failed and needs replacing.
You may want to recover your data if drive failure is the conclusion of testing, this free tool may be helpful to you in that case:
Recuva Undelete Unerase File and Disk Recovery Free Download
Alternatively data recovery specialists could be helpful to you, below is a link to a company I can recommend:
Fields Data Recovery
Posted on Mar 19, 2014
saqeb
  • 47 Answers
SOURCE: transcend storejet 25 mobile 160gb show error " usb device not re
Most probably your drive has been damaged. Try it on another system and if fails, no way
Posted on Jan 28, 2009
  • 34 Answers
SOURCE: Dropped StoreJet 2.5
Drives are very delicate. If it has been dropped, I'd copy everything off and bin it. You could buy a new drive itself and put it in the Transcend case - saves money :-) It sounds like the drive heads would have been damaged by the drop.
Posted on Aug 28, 2009
Testimonial: "Thanxs I had a feeling that this would be the case but wanted to try anyway."
SOURCE: hi there,
There are two options you can try.
First is that if it's a physical damage then it would take you more time to recover your data from it.
I will guide you with the data recovery step.
I am posting link for : GET DATABACK a recovery software.
1.http://rapidshare.com/files/341816190/gdbnt.zip.html7
1.a http://rapidshare.com/files/341816666/GetDataBack_for_NTFS_V2.25.txt.html
2.http://rapidshare.com/files/341817845/gdbfat32.zip.html
2.a http://rapidshare.com/files/341818103/GetDataBack_-_Data_Recovery_for_FAT_V2.25.txt.html
download it accordingly.
Choose accordingly upon your drive partition may be its a fat or ntfs one.
run the software and it will scan the unreadable partition on the Hard-disk.
After that, run disk management and try to format the Hard-disk there.
Try this and let me know
Any other help
I will be happy to assist you
ok
Cheers
Uttam
Posted on Jan 27, 2010
  • 297 Answers
SOURCE: Storejet problem
Good day!
1. Go to my computer and right click then click manage, go to disk management and see if your external harddisk is showed.If showed,then you can see the options there to manipulate your harddisk, either you format it or repartition.
2. You can use also a disk manager software to fully control the function.
Posted on Jul 06, 2010
cristi_mc
  • 55 Answers
SOURCE: hello, my storejet 160gb hard disk
There are 2 solutions for your problem, but both of them request advanced knowledge in hard drives arhitecture and computer operating. First solution works under windows and is called Victoria 4.3 for windows. It's a tools for diagnostic and repair at low level for hdd and you can find it free on the internet, for these method you can use your hdd conected to usb, second it'a also free and it's called MHDD and you can find it at www.hddguru.com, for these method you must remove hdd from the enclosure and connnect it directly to your computer motherboard and boot from the cd created with MHDD, but be very carefull, you can destroy your hdd permanently if you don't now what to do, and you can lose all your data, so if you have an IT specialist ask him to do it.
Posted on Mar 21, 2011
My netbook fell down n when I tried to start it a blue screen with setup utility comes n I tried changing options n restarting n the same screen keeps coming... Plz help..
The problem is the any hardware part is not it its proper position
Avinash it can be hard disk or even the ram
Please first try to open and see all this component are in the proper state and secondly it can also be hard disk failure you have to specify me that if the computer goes in blue screen does the hard disk light is still blinking and if you can go the bios option then its more better
when you power the device then click on the f2 or f1 it will show your bios option then scroll down and you will see hard disk please specify me that its showing anything on the harddisk i mean the vendor name or model no
please reply back
Nov 18, 2012 | Computers & Internet
I have my StoreJet 25M 640GB external HD. I was transferring files from mycomp to the StoreJet yesterday when suddenly the transfer stopped( I was transferring video files, it happened 30mins since I...
click start control panel administrive tools ,computer management ,device manager scroll down universal serial bus controllers you should see a yellow question mark?
right click to reinstall drivers
make sure the lead/s that attach to this drive have a secure seating and are not bad/faulty the light on only tells that its getting power it might not be getting enough power you might test the lead/s or
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again, sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
hope this helps
Apr 12, 2011 | Transcend StoreJet 2.5 (TS120GSJ25T) 120...
Hi my Transcend 320 GB harddisk is not getting detected. Storejet 320Gb
hello
connect the USB external hard disk to usb port by the way disconnect other working harddisks
available on the system, boot the system with bootable cd/floppy go to command prompt and run
chkdsk on this drive
Also download "mbrfix" connect all working harddisks along with the nondetecting harddisk and run mbrfix for the USB defective harddisk
Try using different USB data transfer cable, if power source adapter is used check for rated power output in multimeter for this adapter, if found defective replace it with new/good adapter with same
specifications
Bad luck if harddisk controller has failed you have to go in for new harddisk
GOOD LUCK ooo
Nov 10, 2010 | Transcend StoreJet 320 GB USB 20 Hard...
Storejet problem
Good day!
Jul 06, 2010 | Transcend StoreJet 2.5 (TS120GSJ25T) 120...
Transcend 160GB Portable Hard Disk is not recognized by computer
when you power up the computer press F2 or "del" key to enter in bios then go to usb option and enable usb 2.0 legacy. then save settings .
then check.
some times usb speed make issue so try this.
Also check your usb cable working fine try with other usb cable.
Also check harddisk jumper settings.
If still face problems then you need to repair it.
You shuold take it to service shop becasue you try with 10 computers and all gives same error then your harddisk has hardware issue.
try above solution .
Thanks for using fixya.
Please rate my solution if it helps you.
Jul 20, 2009 | Transcend USA 120GB Storejet 2.5" SATA -...
Maxtor basics 160gb portable hard drive is showing error performi
go to my computer p[roperty then hardware -> device amnager then uninstall usb drivers from it then install aagain.
then connect your harddisk then it found.
Jun 23, 2009 | Fantom Drives Titanium II (TFD160U2) 160...
Hard disk no open
Hello, may b your other harddisk mite hav sum errors in it. Hope its detected in windows, bt not accesable.
Try booting with any linux live CD (google "puppy linux", its just 90MB approx) and connect the harddisk. Now access ur harddisk from linux. If u still cant access it, then u should format it.
if it works in linux, then backup all ur improtant data and format it wit NTFS. Ur prob shud b solved!!
Jun 22, 2009 | Video Game Consoles & Games
Hard drive problem
It's possible that your computer's motherboard is "old", and it only supports a maximum of 32GB per disk-drive.
Buy a new 80GB or 160GB disk-drive, and copy all your files from the "old" disk to the "new" disk.
Apr 06, 2009 | HP HRD DRV-SEAGATE SAS 72GB 15K 2.5 SINGLE...
Cannot delete files from transcend storejet 2.5 160GB
Is there a physical lock on the device that needs to be switched?
Here are a few things to consider:
  • Only have one Explorer window open.
  • Have no other programs running that might be accessing the files.
  • Right-click the file, click Properties, and see if the write protection is on.
Oct 15, 2017 | Transcend StoreJet 2.5 (TS120GSJ25T) 120...
Hard disk space not found
The 19 missing gigabytes is probably being used by the operating system.
System restore will eat a lot of space after a while.
Also 160GB, all register as 149GB.
Aug 07, 2008 | Computers & Internet
Computers & Internet Logo
42 people viewed this question
David Payne
David Payne
