Question about Chapin 2 Gallon Spectracide Sprayer
Cracked 2 gl tank sprayer
Base opened up and cracked allowing fluid out, won't hold pressure
  • Jarhead Marine Mar 18, 2014
    in order to fix this issue, I used PVC glue and applyed it to the bottom 1st (outside), I let it set for an hr and then poured some on the inside, pumped it up a few time to hold pressure and if there was any leak the remaining glue would seep towards the crack...2 hrs later it worked awesomely!
2 Suggested Answers
  • 4 Answers
SOURCE: My ChapinSpray N Go sprayer won't build air
Sounds like a faulty seal to me. Submerge the container in water and pump, bubbles will rise from the seal. Easy to fix, I had a look and you can pick up a seal replacement kit for this model at Amazon.com for under $12.00. You should also find them at any reperitable hardware store. Hope this helps :)
Posted on Feb 03, 2011
How do you refill?
Remove all pressure by keeping the hose open until no pressure is left. place pump handle down toward tank. Turn count counter clock wise to unscrew. Take assembly out of tank then fill tank. Reinstall in reverse order.
https://www.chapinmfg.com/sprayers
May 24, 2014 | Chapin 2 Gallon Spectracide Sprayer
1997 Chevrolet camaro windshield sprayers won't
I would check the washer pump to see if it is working assuming the tank is full of fluid.
Aug 24, 2012 | Cars & Trucks
Lid does not seal---very loose
If sprayer doesnt seal against pressure, I suggest check cover gasket A (image 1). Check pump cylinder gasket B (image 2) and additionally, check the procedure if pump dont build pressure. on how to remoce pump cylinder on follow lines.
If pump doesnt build pressure... in most instances, failure of the pumo to build air pressure in the sprayer is due to dry or worm plunger cul leather. To work on cup leather, always remove plunger from pumo cylinder. Do not attempt to oil cup leather through breather hole in **** cap.
First, unthread pumo cap A (image 1). If cap is too tight, and if pumo will build even slight temporary pressure, pressurizing the tnak will make it easier to loosen cap. Once cap is lossened, release tank pressure. Hold pump cylinder by inserting hand through tank filler openning (image 2), and unscrew cap all the way. Pull plunger from cylinder, and remove cylinder from inside the tank.
Place a few drops of clea oil (not heavier than SAE 30) on leather, and massage into leather until it is soft. Replace plunger cup leather if damaged (image 3). to remove plunger leather assembly, use coin rather than screw driver in the slot of the plunger cup retainer. To reassemble, hold pump cylinder in tank openning, with squared edge of flange, at top of cylinder, toward tank wall.
Hope this helps to solve it.
Sep 17, 2011 | Chapin Industrial 3.5 Gallon Viton...
My sprayer is new, but does not keep the pressure, any idea's? It's a 2 gal, pump up type sprayer.
Check under the lid/cover for a rubber gasket. This may have gotten unseated when putting the sprayer top on. It must form a tight seal around the lip of the sprayer top in order to keep the pressure. Alternative: Put water in the sprayer leaving some air on top to build pressure. Put a few drops of dish soap inside and gently stir. Put the cover on, and tilt the sprayer to coat all areas at the top. Start pumping and see where the bubbles come out---there is your leak. If it is near where the sprayer hose enters, and it is a permanent mount, you may have a bad seal. If the sprayer hose unscrews, you may need a new rubber washer inside. If bubbles come out of the wand, or other plastic seams, you may have a crack in the plastic. Depending on the location, you could epoxy over the crack to seal it permanently. Good luck.
Aug 11, 2011 | Roundup 2 Gallon Pro Garden Poly Tank Pump...
The sprayer nozzle is stopped up, i have tried cleaning it out and it still won't spray.
Round up 1.33 Gal Spray can have a bad pump or a clogged filter or both.
Test pump: pump the handle, does it get harder to pump after 10-15 pumps, when you open the cap does air rush out? If yes, pump is good, if not, wear rubber gloves, remove pump/cap assembly, remove inner tube from cap, the handle\ pump plunger will remair with the cap. if the o ring is dry, wipe it clean, put a little petroleum jelly on the plunger o ring To Lubricate it and prevent o ring wear and helps it seal air tight so the pump will work correctly. reassemble handle\cap make sure the Black inner black plastic hose aligns with the white spray hose .
If your pump passed the pump test, lool inside tank at the chemical fluid clean or does the fluid look like it has lumpy white clumps in the fluid, if so, empty fluid in tank into a clean throw away container look at rinse the tank out with water, strain the clumps out with a paper towl draped over the tank opening inserted about 2 inches into tank opening then when you slowly pour the fluid back in hold both end of the paper towel so it does;nt fall in tank the clumps will remain on top of the paper towel , Then your ready to clean the filter in the cap. Remove the black plactic tube from the pump, remove the white out side hose(squeeze the black connector to unlock the white hose , Then look in the hole the the black tube was inserted into, look for clumps (looks like lint from a clothes dryer, about the size of cotton ball, ) in that hole, to clean the clogged filter,I used low pressure air from an air tank, Blown into the hole where the white discharge hose was mounted. The clog should fall out of the opposite hole where the black tubs mounts. Reassemble and test, Also, the white spray tip turns out to change from spray to stream. Wash Hands good the chemicals can soak into your skin, some people are very allergic to the fluid
Jul 11, 2011 | Roundup 2 Gallon Pro Garden Poly Tank Pump...
Windshield washer resorvor won't hold fluid
Check washer motor grommet/seal for leak, or rubber hose connection to sprayers at tank, or tank crack.
Dec 13, 2010 | 1995 GMC Jimmy
Windshield wiper sprayers
This could be 2 things.
First of all, check for any debris blocking the sprayer holes.
Secondly, open the hood and make sure the hose running from the washer fluid tank is connected to the bottom of the sprayer.
Feb 24, 2009 | 1997 Acura RL
Wiper nozel not spraying
Immediate pressure loss
your dip tube inside the tank has come loose or has a leak near the top. instead of fluid being pushed up the dip tube into the wand hose the air in the tank is just escaping. You will have to remove the wand hose and figure out where the leak is and fix the dip tube.
Nov 18, 2008 | H.D. Hudson 2g Yard N Garden Sprayer
Chapin 2 Gallon Spectracide Sprayer Logo
Top Chapin Garden Experts
Nick Olsen
Are you a Chapin Garden Expert? Answer questions, earn points and help others
