Question about Kitchen Ranges
After using a generator for power my buttons quit beeping, the lower burning barely heats but the broiler works. I have a Whirlpool electric oven.
Also the broiler came on so I put some food in it and then the thing locked like it was on a selfcleaning cycle. It was fine before we used the generator for three days. Can it be fixed and if so is it costly to fix? Thanks, Kristy
    Sergeant:
    Champion:
  • 266 Answers
Needs a qualified electrician because your generator didnt supply enough amps for an oven.
Hard to tell how wrecked it is.
Any licensed electrician will give you an estimate for free.
Posted on Mar 18, 2014
SOURCE: locked oven door
The Coat hanger is a great idea and it works. My oven was doing the same thing and I a female fixed it with the coat hanger. Thank you Thank you
Posted on Nov 04, 2006
SOURCE: electric oven does not heat up enough
I had the same problem before the warranty expired. The heating element had exploded and there was white powder all over the inside of the oven. They replaced the heating element and it works as it should, however, this oven has never baked right. It gets hotter on the right hand side than it does the left and I have to constantly watch whatever I bake. I'm not very happy with this oven.
Posted on Jan 18, 2009
Sea Breeze
  • 4654 Answers
SOURCE: GE XL44 gas: Stove works fine. Oven heater lite on but gas wont
Click on link below and go to page 46 on the Adobe PDF of your model and there are some trouble shooting tips. Thanks, Let me know if this helps, Sea Breeze
http://products.geappliances.com/ProdContent/Dispatcher?REQUEST=SKUOBJECTS&DOCUMENT=Installation%20Instructions&SKU=RGB745BEAAD
Posted on Feb 08, 2009
leroyal
  • 2120 Answers
SOURCE: Oven won't heat. No gas smell. Broiler and stove work.
Bad oven control circuit board. Look up on eBay
Posted on Feb 21, 2009
  • 5 Answers
SOURCE: Used the oven on Sunday night - on Monday it wouldn't work!
Check to see if the ignitor is coming on, you will see a bright orange glow in the burner area when you turn it on. If you don't, your ignitor is burned out. It is a fairly inexpensive item and fairly easy for the do it yourselfer. Just remember to unplug your oven before you replace the ignitor.
Posted on Mar 23, 2009
Whirlpool gbd307 why will The upper oven not work but the lower oven works
Have you checked the heating element supply voltage with a VOM? And have you checked for a popped/burned fuse to the bake element?
Aug 06, 2014 | Whirlpool GBD307PDS Electric Double Oven
Alright, heres my problem. My double oven quit working during a self clean cycle, I replace the fuse and the circuit board and it now has power to the circuit board but now the only burner that comes on is...
Cycling the power off and then on again will sometimes reset it...often you will have to call the customer service number to get the steps to take to unlock that...
Also check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Apr 24, 2010 | Whirlpool RBD305PD Electric Double Oven
I recently put my oven through the self clean cycle then the next day neither the oven element or the broiler element will heat up. There is power to the control panel.
Probably the Thermal Overload Sensor burned out from the excessive heat during the cleaning cycle. It Is located on back side of oven.
Sep 29, 2009 | Whirlpool RBS275PD Electric Single Oven
Kenmore oven lower element sporadically heating.
When the food you're baking is done on top but not on the bottom--or when baking just takes far too long to finish--the bake element may be burned out.
You may get fooled into thinking it's working, because the oven is hot inside. But many electric ovens use the broil element, too, during the preheat and bake cycles. So the food may be getting heated only by the broil element, which causes poor baking results.
If the bake element is burned out, replacing it should solve the problem. Otherwise, you need to further troubleshoot the oven's electrical system to locate the defective wire or component.
May 27, 2009 | Ovens
Oven won't heat
The only reason I know the answer to your question is because I am having the same problem. Our appliance quit working after we used the cleaning option. Both the bake and broiler quit at the same time. Our local repair man said that the problem is caused from a malfunctioning thermostat, which is about a $300 fix.
May 18, 2009 | Whirlpool RBS245PD Electric Single Oven
Whirlpool Gold Electric Oven F5 E1 code on bar code
For some reason I get the same error code every time we have a power outage. If you push and hold the "lower off" button for about ten or 15 seconds it will unlock and reset. Hope this helps.
Jan 26, 2009 | Whirlpool GBD307PDS Electric Double Oven
Heat elements in oven/broiler do not heat up
I would say to go and reset your curciut breaker first if this is a electric oven. needs 220 volts for both element to work
Jan 03, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Kitchen Ranges Logo
56 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
