Question about Ricoh Aficio MP6001 Copier
Code SC 390
The code SC390 occurs when power on the machine.
    Problem Solver:
  • 10 Answers
TD sensor error: Test value abnormal The TD sensor output voltage is less than 0.5V or more than 5.0V after 10 consecutive times during copying.
Insuficient toner in the developer/ developing unit
sc 390 can be turn off by turning off and on the copier machine.
Once it goes off.. u could make a test print. U cld try to add in toner manualy untill the copies turns good.
once the copies turns good.. u cld try to innitialize the developer one more time in the sp mode.
Posted on Feb 19, 2015
SC 390 is a TD sensor code try changing developer (Type 24) B0649645 if not that then maybe the TD sensor pn#B2475310,
Posted on Mar 18, 2014
Richo afico 5002 code sc 878
1. Improper firmware update.
2. SD Card size greater than 2 GB used.
3. Multiple ROM data folders in SD Card.
4. Improper Java firmware update.
5. Power failure during firmware update.
6. Power line issues on the outlet.
Replacement of the Controller Board is necessary in case SC Code 878 occurs.
Apr 11, 2017 | Ricoh Aficio Office Equipment & Supplies
Service code sc 390 RICO Aficio 1015 coppier
please refer to link below, it may or may not refer to a different machine but the meaning of the code should be the same
http://printcopy.info/?l=en&mod=free&chap=erc&brand=Ricoh&model=Aficio%20550&code=SC390
Jun 04, 2015 | Office Equipment & Supplies
RICOH MP4500 SC 390 DISPLAYS WHAT TO DO
Hello.
That error is related to TD sensor error.
I advise you to call a trained Technician
Mar 16, 2015 | Ricoh Savin Lanier Genuine Toner Type Mp...
Sc 390
SC390: TD sensor error
- Possible causes -
· TD sensor abnormal
· Poor connection of the PCU
Dec 30, 2010 | Ricoh Office Equipment & Supplies
Problem is sc390
SC390 TD sensor error The BICU detects the TD sensor outputting abnormal voltage (less than 0.2 V or more than 4.0 V) 10 times consecutively. • Defective TD sensor • Loose connection of the PCU
you may need a new PCU unit
Feb 13, 2010 | Ricoh Aficio 1515MF All-In-One Laser...
Code shows SC 548 how do I clear this
SC548: Fusing unit installation error - Definition - [A]
The machine cannot detect the fusing unit when the front cover and right cover
are closed.
- Possible causes -· Fusing unit is not installed
· Poor fusing unit connection
check the 2 sensors on the left hand side of the copier (as you look at where the fuser is located). These get knocked & moved out of postion,
this sc 548 usually happens when paper jam occurs and user does not properly fit the fuser... also not fiitted properly due to some foreign object in between fusing belt and the sensor...
Enter SP 5810 (SC code reset), select “Execute”, select “close”, exit SP mode then turn main power switch off and on.
to enter SP mode press yellow C button press 1 0 7 on numeric keypad and then hold down the orange C button from the menu select copier SP then type in 5801 and press # selest execute then power off and back on. Your machine should now be working. Hope this helps. if this doesnt solve ur problem then try contacting ur ricoh service tech
good luck
Aug 09, 2009 | Ricoh Aficio CL3500N Laser Printer
LANIER 5515 ERROR CODE SC390
the problem is with the toner density sensor.a quick fix would be to replace the photoconductor unit.thereafter you need to do the developer initialization adjustment.
Jun 09, 2009 | Office Equipment & Supplies
Sc 390 cod. what this?
hi,what is your machine brand?may be the problem is on paper supply be sure wrong size paper in each tray.i'll wait your comment.
May 20, 2009 | Office Equipment & Supplies
Error code sc 541
I have infotec machine when I powered machine a error code genereted sc 541 what is the solution?
Sep 21, 2008 | Ricoh Aficio 2018D All-In-One Laser...
Error code 390
This issue occurs when the issue is with the telephone line. Try to send fax to another number and check the result.
For more information, please open the below webpage.
http://h10025.www1.hp.com/ewfrf/wc/genericDocument?docname=buu02549&cc=in&dlc=en&lc=en&jumpid=reg_R1002_INEN
May 14, 2008 | HP Officejet 5610 All-In-One InkJet...
Ricoh Aficio MP6001 Copier Logo
145 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
