Question about HP LaserJet M1005 All-In-One Printer
Can not communicate with scanner
How to solve this problem.
    Novelist:
  • HP Expert
  • 175 Answers
This error appears when the scanner cable has worked loose or when the main pca has failed,
remove the right hand panel locate and remove the two rear covers, then remove the two screwx that hold the scanner unit in place - disconnect the scanner unit and remove from the printer, now you are able to inspect and check carefully the ribbon cable inside the scanner as weel as the connecting cables to the printer,
Posted on Mar 20, 2014
When I try to scan, the scanner setup window will not open and nothing will scan
first reinstall operating system
and after it install scanner setup if scanner setup not run
then
downlode another setup and install it
problem will solve
Oct 22, 2012 | Nuance PaperPort 12
I installed the new Canon LiDE 110 scanner drivers. When I click on the Scan button, it gives the error msg: Cannot Communicate with scanner. Cable may be disconnected. Scanner driver will be closed
I was getting that same error message, every second time I tried to scan something. I had the scanner connected to a USB 3.0 jack. I switched to USB 2.0 jack, and the problem was solved.
Oct 06, 2012 | Canon CanoScan LiDE100 Flatbed Scanner
My computer cannot detect my scanner. Error Code: 0x0070800
The FB320P is a parallel port scanner and is having problems communicating with the computer. Are you connecting it directly to the parallel port on the computer? In that case, you may not have bi-directional communication enabled. Turn off the scanner and the computer and disconnect the data cable from the computer. Turn on the computer and enter the BIOS. (Press Esc, F1, F10, or Del repeatedly after you turn the computer. You should see a screen with the correct key to press; it varies depending on your BIOS and motherboard. If you miss the timing, shut down the computer and try again.) In the BIOS, search for the parallel port settings and see if you can enable bi-directional communication.
Not all parallel ports support bi-directional communication. If you can't enable the feature, you need a different parallel port. Try a PCI slot add-on card; just check the features and check the manual for enabling bi-directional communication.
If you are using a USB to parallel port adapter, get a different one that supports the bi-directional communication.
What OS are you using? There are a few that had ASPI driver issues; a third party app, ForceASPI, may help. See http://www.afterdawn.com/software/cd_dvd/dvd_tools/frcaspi.cfm for information.
I hope this helps. Please add more information about the configuration (cable, OS, etc) for extra ideas to solve the problem.
Sep 16, 2012 | Canon CanoScan FB320P Flatbed Scanner
My computer does not recognise my scanner. Not sure how to communicate from computer to scanner. The printing side of it is fine.
Hello.
Make sure the scanner is installed.
Click Start - Control Panel - Scanners and Camera's
If your model scanner does not show up on the left should be a tab to install new hardware, do this and select install automatically when asked.
I hope this solves your problem Regards GM
Jun 06, 2011 | Office Equipment & Supplies
NCR scanner scale 7875 communicating with pc
You would need a PC to communicate it with. Either Via USB or the DataRX port.
Capital Computer Group, LLC
651-405-8293
www.capcom-ncr.com
We specialize in the NCR arena, also have many other point of sale needs.
Free bench testing equipment failure on any p.o.s hardware item.
Mar 18, 2010 | NCR 7875
I'm tring to find codes for a police scanner for henderson,ky.
RadioReference.com is the world's largest radio communications reference website, featuring a complete frequency database, trunked radio system information, FCC License assignments and callsign maps, 10-Code Lists, agency maps, files, downloads, links, and detailed agency information for most public safety, military, and local government communications.
Best of all, registration and access to all the data is free, however some special reporting features and downloads are only available to Premium Subscribers of the site.
that should solve your problem
Jan 11, 2009 | Radio Shack Pro-95 Handheld Scanner
No option to scan Film Negatives
In order to see these options, you must have the Film Adapter Unit (FAU) attached to the scanner. The FAU is designed to scan in 35mm film, either positive or negative. The scanner has no options to scan in mounted 35mm slides.
Does the scanner work for scanning at all? If not, you may have a communication problem between the computer and the scanner, i.e., the computer doesn't know how the scanner is configured so it doesn't show the options. If it's a communication problem, check for any other USB devices that might interfere with communication. Especially, some printers seem to take over communications. Try disconnecting all other USB devices (except keyboard, mouse, etc.), reboot, and see if the situation corrects itself.
Also, try the online troubleshooting database for this model at this link.
Sep 30, 2008 | Canon CanoScan LiDE 600F Flatbed Scanner
Communication with scanner
You could take it apart and see if you can lubricate the shaft the the scanner sits on with some vasoline. If that doesn't it could be that the stepper motor that controls the scanner is going bad in it.
Jul 18, 2008 | Epson Expression 1680 Professional Flatbed...
Buttons on 3570 hp flatbed not working
u r open to the scanner and see the botton r attach to the properly to the devices or not then change to the botton in nearest reparing center
Mar 14, 2008 | HP Scanjet 3570 Flatbed Scanner
Scanner connection to the PC
i solved mine by replacing the usb cable with one that is 2.00 high speed and inti noise shelded benton-r
Nov 04, 2007 | Canon PIXMA MP160 All-In-One InkJet...
HP LaserJet M1005 All-In-One Printer Logo
19 people viewed this question
Seeker5211
Seeker5211
