Question about AEG Washing Machines
Hi I have a aeg 74810 washing machine it finishes the washing cycles in about 30 mins instead of 1hr 30. no error codes
Have checked self cleaning filter appears fine
  • 1462 Answers
SOURCE: AEG Lavamat w850 not finishing cycle! help!
check no kink in drain hose and if plumbed in unbder sink, check spigot into sink drain is not blocked. put drain hose lower down band check there is water coming out freely. if not, then suspect something trapped in hose from tub to pump
Posted on Mar 26, 2007
fanny
  • 146 Answers
SOURCE: washing machine not spining
You may have a problem with the rotor position sensor. This sensor is situated on the motor windings and should really be replaced by a qualified tech.
Posted on Nov 04, 2007
  • 1294 Answers
SOURCE: aeg lavamat 538
Your door will not open if there is water still in the machine. Try "spin only". If this fails, get a bucket, remove your outlet tube from the wall drain, put into bucket. Wall plug off first. After all the water is drained try the door, do not force it.
Then check your outlet filter; the water does not go thru for there may be a block in your filter, or tube from the tub to drain area. Or finally in your pump. Dont forget to refix drain pipe in wall in exact position.
And rate me pl.
Posted on Dec 01, 2007
SOURCE: My Zanussi ZWF14581 washing machine shows an error
The error code E10 is in relation to low water pressure.Have you checked that the hose at rear is not kinked or check the filters in the ends of the hose.Also make sure when you have hose off check the pressure in the supply.If all that is ok then it could be a faulty solenoid valve.
Hope this helps.
Posted on May 09, 2010
supernova278
  • 1932 Answers
SOURCE: washing machine lavamat 74810
EFO error is a water leakage error.You need to call for service.
Thank you
Posted on Sep 10, 2010
I have an AEG Lavamat 74810 washing machine which is 10 years old. On any cycle , the drum does not spin, on pressing the two left hand buttons, you get error code E52.
The E52 code indicates that the motor is not moving. This could mean the the carbon brushes have worn out, the entire motor is bad or that the wiring or control units have damage so that the message to spin is not getting to the motor.
Take off the back of the washer (after unplugging it). Inspect the motor plug and wiring to that plug. If those look okay, take out the motor and inspect the carbon brushes. If those are worn or broken, then you need to replace them. If the brushes are okay, then the entire motor or the control board are more likely to have a fault. See http://shop.aeg.co.uk/search?prpp=20&ppn=1&psfo=A&filter=category%3ALaundry%3AWashing%2BMachines and use the full product number to find out the part numbers you may need. Other sites will have these parts.
I hope this helps. Please add the product number of your AEG Lavamat 74810 if you need assistance finding parts.
Feb 15, 2017 | AEG Washing Machines
How do I fix my AEG Lavamat T57800 dryer
E51 - Motor power triac short-circuited
Motor faulty ; Wiring faulty ; Electronic board faulty ; Motor capacitor ; also check tension of belt
Dado
Jul 15, 2014 | AEG T57800 Electric Dryer
Washing machine does not work on any program though stop light and spin speed light are flashing t
The stop light and the spin light flashing are acting as an error code. Have you tried to google what this means? here is a link to candy error codes for that machine...
http://www.ukwhitegoods.co.uk/help/fix-it-yourself/fault-codes/laundry-fault-codes/3319-candy-grando-washing-machine-series-fault-codes.html
hope that helps
Jan 15, 2014 | Candy Washing Machines
AEG Lavamat W1450 Electronic - after about 10 mins of programme machine is making beeping sound and stopping
this is an errorcode !
try to download a servicemanual,
then you can figure out the exact failure -
like : does not heat up etc. ....
May 05, 2012 | AEG Lavamat W1450 Front Load Washer
Can anyone help me with my washing machine (aeg lavamat 66840 l).After choose a washing cycle and the timer displays 2.20 h , the washing cycle finishes in 1.45 h !?Any ideas?
HI HAVE YOUR PUMP FILTER CHECKED IF OK CHECK HEATING ELEMENT ..SEE IF ITS IN CIRCUIT.. THATS WHAT NORM HAPPENS IF THESE ARE NOT HAPPY.BET OF LUCK.
MARK 07779933829
Nov 22, 2011 | Washing Machines
Hi, i have an AEG Lavamat 1100. Although the machine runs through the spin cycle, and shows the wash cycle as being finished, when i open the door there is still water in the bottom of the machine and the...
Hi bwileman435,
It may not be draining well, because it is dirty, did you clean the Drain Pump filter?
Please follow my below Tip on how to do it:
ACCESS, DRAIN & CLEAN THE DRAIN PUMP FILTER
Kind Regards d")
* If this solution helped you, please rate it
Aug 05, 2011 | AEG Washing Machines
Lavamat 86800 stop the washing cycle after few seconds without any error code
Hi - did you ever find a solution to the problem? My 12 year machine now showing the same issue.
Oct 11, 2008 | AEG L86800 Front Load Washer
Error code 50
i think you should pull out the filter, and clean it. appliance doctor
Jan 23, 2007 | AEG L66600 Front Load Washer
Washing Machines Logo
15 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Einar Axel...
Einar Axel...
Level 1 Expert
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
