Question about Toshiba TDP-T90 Multimedia Projector
How do I reset the lamp timer to '0' hours when I replace the bulb?
When I replace the lamp in my Toshiba T90 it still shows the number of hours the projector has been 'on'. Now that I have a new lamp I want it to track hours from zero.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 88 Answers
Make sure the main power switch is OFF. Hold the "ON", "MENU", and "INPUT" buttons at the same time and turn the main power switch on. Keep them held until the yellow power standby light comes on, then let go.
Posted on May 23, 2014
Status light blinks seven times
the lamp timer is failing
lamp timer chip is on the lamp housing,is a little chip
you need to reset the timer chip by using a Programmer
select a date of 0 hour..
Our company supply this chip with 0 hours USD15
We supply original projector lamp,bulb,parts,Lcd panel,Lens,DMD chip,color wheel,motherboard,powersupply,ballast... with high quality and competitive price.
any questions, feel free to contact me
have a nice day!
Jerry,Lampdeng Limited
Jan 31, 2014 | NEC MultiSync MT1065 Multimedia Projector
I heard a pop on the Toshiba rear projection TV (model #62hmx84) and immediately lost the picture
Sir the problem of your unit is the lamp try to replace it it is much better to use a gloves and wash your hand after replacing the lamp because this lamp contains mercury. follow this steps.
1. Unplug the unit to main ac outlet. Remove the bulb housing cover from the back of the TV. Using a screwdriver, carefully remove the cover to reveal the old bulb. Using a cloth, remove the bulb from the TV by first unplugging it from the wiring harness. Carefully rock the harness back and forth until it comes free from the bulb. Push in the bulb slightly and turn it a quarter-turn to remove it from the bulb housing.
2. Install the new bulb. Do not touch the new bulb with your fingers, as any grease or fingerprint from your hands will damage the tiny mirrors in the bulb. Instead, carefully handle the bulb using the cloth. Insert it into the bulb housing and secure the door. Test the unit. Plug in and turn on your Toshiba TV and make sure that the new bulb is installed properly and that the image looks crisp.
3.
Reset the lamp time counter. Each Toshiba TV comes with a lamp hour meter stored in its software. If you do not reset the lamp timer, the unit may stop operating when it gets to a certain time (refer to your manual because each Toshiba TV is slightly different). To reset your Toshiba lamp timer, turn off the TV, wait 10 seconds, hold down the "on," "menu" and "input" buttons on the remote at the same time, and turn the power back on. A yellow light should appear in the bottom corner of the TV indicating that the lamp timer has been reset.
Hope this help good day and best regards.
Sep 23, 2011 | Toshiba 62HMX84 62" Rear Projection HDTV
I have replaced the bulb in a Sharp PG-F211X and all is working well. How do I reset the lamp hours back to 0?
While simultaneously holding down MENU/HELP, ENTER and the down arrow on the projector, press STANDBY/ON.
LAMP 0000H is displayed, indicating that the lamp timer is reset.
May 16, 2011 | Sharp PG-F211X Projector
Replaced main bulb in front but lamp button on front of tv is still blinking and tv won't show picture
The lamp timer on the Hitachi projector must be reset whenever the lamp has been replaced. The "Lamp" indicator on the display will light red or the "Change the Lamp" message will display when the lamp timer needs to be reset. Hitachi recommends that the lamp timer never be reset without replacing the lamp and to always reset the timer when the lamp is replaced. The message functions of the projector will not function properly if the lamp timer is not correctly reset.
  • Turn the power on. Press the "Reset" button for three seconds until the "Lamp xxxx hr" message appears on the lamp timer on the bottom of the screen.
  • 2
    Press the "Menu" button on the remote control while the lamp timer is displayed.
  • 3
    Press the left arrow button. Select "0" and wait until the timer display clears.
  • If this was helpful a vote on the thumbs up for the free advoce would be greatly appreciated. Thanks
    Apr 04, 2011 | Hitachi 60V500 60" Rear Projection...
    Need to reset lamp. replaced lamp and installed new lamp.
    Press RESET, <, >, ENTER keys on remote within 5 seconds to reset lamp timer.
    Jul 29, 2010 | Sony VPL-CX86 Multimedia Projector
    After just recently replacing the bulb I am
    Here is proceudre to reset lamp timer in your TV..
    While pressing the VOL Down button on the projection display, hold down the PIP or SPLIT button on the remote control at same time for more than 5 seconds.
    When reset procedure is complete, the screen message ' lamp time was reset to 0' will appear.
    Hope this info will help you.
    Thanks.
    Nov 18, 2009 | Panasonic TY-LA1000 Projector Lamp for...
    Toshiba tdp-t90 projector. I rplaced the lamp on
    set the beamer off, unplug the power line, press -on-/input/menue at the same time and plug the beamer to the power line again thereafter you can remove your fingers from the below mentioned buttons. now the lamp counter should be reseted to 0 hope this helps it works on a TDP-T100
    Aug 02, 2009 | Toshiba TDP-T90 Multimedia Projector
    How to reset the bulb timer for TOSHIBA TLP-XD2000
    The booklet that comes with a new lamp specifies the following for the TLP XD2000. While holding down
    Mar 12, 2009 | Toshiba Office Equipment & Supplies
    How do I reset the timer
    1. While holding the ENTER on TV
    2. Hold the MUTE button on the REMOTE for the TV for at least FIVE seconds
    3. The Lamp hours reset menu should appear on TV screen
    4. Press select on remote (large button in the middle of four arrow buttons
    5. Press select button again, hours should reset to 0 and light will go out
    Aug 21, 2008 | Zenith E44W46LCD 44" Rear Projection...
    Toshiba TDP-T90 projector, lamp
    is lamp cover closed firmly-is power cord good(try with another cable)-is power fuse ok!!!-is power supply ok.and gives normal rating output voltage as a the book say.all previous will check first befor lamp and fan.
    Feb 16, 2008 | Toshiba TDP-T90 Multimedia Projector
    Toshiba TDP-T90 Multimedia Projector Logo
    127 people viewed this question
    Top Toshiba Office Equipment & Supplies Experts
    didi2005
    jasbo
    jasbo
    Branko Djurdjevic
    Branko Djurdjevic
    Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
