Question about Bosch 11241EVS SDS-Max Rotary Hammer
Service minder light comes on when switch in on
The oil was all black and thick. The oil was changed and still the light remain on. the brushes are in good condition and all dust was remove from machine
  • 154 Answers
There is a small brown wire on one of the brushes that has to be hooked up to the brush holder plate. If this wire has fallen of it will cause the service light to be on. If this is not the problem and the brushes are good, I would suggest taking it to a Bosch repair depot for a diagnostic.
Posted on Jun 15, 2009
What does service soon A mean? Oil changed last week.
Bring your car down to autozone store or an auto part store that will diagnose engine lights or service lights for free.
It could be something else that needs looked.
Normally. The oil change shops reset the service light for you.
Hope it helps
May 15, 2015 | 2004 Acura TL
How do i reset my manint req's light after an oil change on a 2003 Honda pilot
Reset oil service light Honda Pilot. From years: 2003, 2004, 2005, 2006, 2007, 2008, 2009, 2010, 2011, 2012.
How do you reset oil service light Honda Pilot. From years: 2003, 2004, 2005.
  1. Turn off the engine. Press and hold the SELECT/RESET button in the instrument panel and turn the ignition switch to run (one position before starting).
  2. Hold the button for at least 10 seconds, until the indicator resets.
  3. Turn the ignition off and then start the engine to verify the indicator has been reset.
How to reset oil service light Honda Pilot. From years: 2006, 2007, 2008, 2009, 2010, 2011, 2012.
Resetting the Engine Oil Life Display if maintenance service is done by someone other than your dealer, reset the maintenance minder as
follows:
  1. Turn the ignition switch to the ON (II) position.
  2. Press the select/reset knob repeatedly until the engine oil life is displayed.
  3. Press the select/reset knob for about 10 seconds. The engine oil life and the maintenance item code(s) will blink.
  4. Press the select/reset knob for another 5 seconds. The maintenance item code(s) will disappear, and the engine oil life will reset to 100.
All information is taken from the Honda Pilot owners manual.
Mar 09, 2015 | 2003 Honda Pilot
What is solution for wrench light staying on for a 2008 F 250 Diesel Ford truck Lariat model
You have to reset the oil change minder feature. It is done through your instrument cluster. If you have switches on the steering wheel i.e info, menu etc. scroll through until you find oil change reset and follow the prompts. If there are no info switches on the steering wheel the same process is accomplished by using the trip minder reset button on the instrument cluster.
Sep 29, 2014 | Ford F-250 Cars & Trucks
My 2007 ACURA TSX HAS A MAINTENANCE CODE OF A. WITH A MESSAGE THAT READS MAINTENANCE IS 100 MILES OVERDUE. WHATS THE MEANING OF CODE A?
This is your vehicles maintence minder system letting you know you are 100 miles over due for an oil change. If you had an oil change performed recently and they did not reset the maintenece minder go off the rec. mileage sticker on the windshield. In answer to your question code A is the main code for an oil service. Often times the main letter codes will be followed by sub-codes that will appear as numbers following the letter. Exp.. A-1, B-1, B-2... The Dealership can clarify what each series of codes and sub-codes means in regards to the needed service. Best piece of advice when the maintenence minder hits 15% oil life remaining bring the car in for service. And check the oil at least once a month.
Nov 04, 2012 | Cars & Trucks
A wrench appears and 34a I don't know what that means and I don't have the manual, it happen two days ago. I put engine oil because it showed 15% oil.
That wrench is a maintenance minder indicator lettting you know that your oil's service life is at 15%, not that the level or amount is low. Have your oil changed and have the maintenance minder light reset.
Aug 24, 2011 | 2005 Honda Odyssey
Service engine soon light on, what is the problem?
There is noproblem - that's a "maintenance-minder" light based on miles driven. It's reminding you that some scheduled maintenance based on your mileage is recommended (oil change, brake inspection, tire rotation, etc). If there was a problem the check-engine light would come on.
Aug 12, 2011 | 2003 Nissan Sentra
B12 15% comes up in dash window box
this is your maintence minder code.
A- oil change
B- oil change brake check and adjust
1-tire rotation
2-replace engine and cabin air filters
3- replace transmission fluid
Dec 31, 2009 | 2008 Honda Accord
Oil change
Hi There
Well it's bets to change it every 3000 miles. or every 2 months. It keeps slug to build up in your car. here's another tip for you change your radiator fluid once a year to keep it clean. hope this gets you in the right direction.
Best Regards Richard
Dec 29, 2009 | 2008 Acura Tl
My 92 honda accord's "maintenance required" light won't go off, even after an oil change
If you had the oil changed at a shop, they forgot to reset the sensor. Bring it back to them and ask them to reset it.
If you did it yourself, bring it to a shop and ask if they can reset it for you...don't be surprised if they don't want to do it...in which case you can take it to a Honda dealer and have them reset it.
Oct 15, 2009 | 1992 Honda Accord
Bmw 323 'r' reg e36 engine oil light flashing
your oil pressure switch is a great place to start. since the oil was really thick you could have a horrible oil sludge problem. about 50-100 miles before your next oil change take a bottle of Transmission Fluid and dump in with your oil. and Drive for the remaning 50-100 miles with the Trany fluid still in the oil. The Transmission Fluid is a great Cleaner for sludge.
hope this helped you
Apr 29, 2009 | 1999 BMW 323 Series
Bosch 11241EVS SDS-Max Rotary Hammer Logo
269 people viewed this question
Top Bosch Drills Experts
Matt Olenzek
Matt Olenzek
woodzowl307
Are you a Bosch Drill Expert? Answer questions, earn points and help others
