Question about Targus Chill Mat PA248U Laptop Cooler
Targus chill mat won't work
Had this mat for a few years and for a bit, it was sounding super noisy when the fans ran (probably a few months) and recently I've noticed it's stopped working. The USB ports are fine on my computer as they work with other things. There is some dust and cat hair buildup inside the fans from what I can see, but not enough to impede movement. I can't get the stuff out because I see no way to get the mat apart.
    Problem Solver:
  • 5 Answers
It is definatly either a wiring issue or a cpu issue
Posted on Mar 18, 2014
5 Suggested Answers
steve_e_uk
  • 1675 Answers
SOURCE: Lost the targus notebook chill
hi this can be purchased from somewhere like radio shack specs are Output: 5V 2000mA, centre is + positive so really just your standard adaptor will do, this also comes from the targus site hope that helps
Posted on Oct 02, 2010
SOURCE: targus chill mat not working properly
This problem is being caused by a wire becoming disconnected from the switch in the usb power cord. The easiest way to solve this problem is to open the switch using a flat blade like a knife, and either reconnect the loose wire yourself or to completely remove the switch and connect the wires together completing the circuit and allowing the fan to operate. I hope this helps.
Posted on Jun 03, 2009
SOURCE: Targus notebook cooling chill mat.
I have the same problem, and I looked inside to see the cause- the interior part for the power is poorly made and comes loose. That's the reason for the one fan not working and it getting weak. Sometimes wiggling the cord or trying to stabilize it will help. But, as I learned the hard way, it will eventually break. Its a poorly made product, and I've had mine about 4 months now and it completely broke today. I opened it and did my best to stabilize the part, but... it will break. As best as I can tell, its a poorly made product and there is no permanent solution.
Posted on Oct 24, 2008
bronk50
  • 27725 Answers
SOURCE: My fans have stopped working
click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you should see a yellow question mark?
right click to reinstall drivers
if you can see your usb drive but its not working
ports(com&lpt)right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts also
scroll to disk drives if you can see your drive + to expand right click you should see options update driver disable uninstall scan for hardware changes
select properties you should see options in the general tab to troubleshoot policies volumes driver and details under the driver tab you will have the options to check the driver details update driver rollback driver or uninstall
if your computer came with a motherboard disk the drivers could be on it
hope this helps
Posted on May 09, 2011
What are the other ports used for, and can I use them to run the fans?
Do you mean the USB-ports on your laptop? If so, than yes, you will need one free USB-port to connect the Chill Mat to.
Feb 18, 2016 | Targus netbook chill mat dual fan awe39us1
The little insert in the usb port on my targus dual fan chill mat has become loose. How do I re-insert it and keep it from becoming loose again?
Tawny, If port still functioning, use 2 part epoxy to secure port, be care, no glue inside port.
press the helpful button
Laptop chill mat getting lould and fans needs to be cleaned
It will probably be more efficient and easier to replace the cool mat. They are very inexpensive.
Mar 28, 2014 | Targus Computers & Internet
Targus AWE81US grinding noise in fan
any luck y fans make a grinding noise. vegasguy913@gmail.com
Feb 25, 2014 | Targus AWE81US Chill Hub and Chill Mat...
Targus awe81us disassembly
is it catching on a loose connection, have you damaged the bearings? try youtube .
Jan 26, 2014 | Targus AWE81US Chill Hub and Chill Mat...
Targus chill mat cleaning fans?
You could use a vacuum with a hose attachment as well to **** the dust out.
Jun 26, 2012 | Computers & Internet
Lost the targus notebook chill mat power cord (usb from computer to the mat). Where can I find a replacement?
Oct 02, 2010 | Targus Chill Mat PA248U Laptop Cooler
Targus Chill Mat Fan On Fritz
The fan rotor is stuck due to accumulation of dust. Take out the fan and clean it. Put a few drops of alcohol or lacquer thinner on the rotor/bushing assembly while manually turning its blades to loosen the hardened dirt until the fan freely spins like the good one. If it does not work, replace the defective fan if spare is available.
Aug 19, 2009 | Targus Chill Mat PA248U Laptop Cooler
Targus notebook cooling chill mat. One fan has stopped running after less than 2 months. Can you help
Sep 28, 2008 | Targus Chill Mat PA248U Laptop Cooler
Targus chill mat not working properly
Oct 30, 2007 | Targus Chill Mat PA248U Laptop Cooler
Computers & Internet Logo
169 people viewed this question
Top Targus Computers & Internet Experts
steve morris
steve morris
dhnguyen
Are you a Targus Computer and Internet Expert? Answer questions, earn points and help others
