Question about Gaggenau Cooktops
Not switching on - Gaggenau Cooktops
One of the burners ignition will not turn off - it continually is sparking - i have to turn off the elec supply to stop the ignition ? any ideas
Hi and welcome to FixYa, I am Kelly. On the burner your having problems with the ignition control switch located in front of the gas control vale on the stem has failed. These are cheesy little switches that are thin ceramic with nothing but 2 strips of copper inside them. One piece is fixed and the other piece is movable by the ceramic switch cam. If the movable copper arm or fixed copper strip gets bent the ignition will not shut off. Also if the ceramic cam of the switch fractures it will cause the switch to stay actuated. The gas valve has to be disconnected and removed to change the switch on most units. The wires in the switch have to be unlocked by inserting a jewelers screwdriver into the holes in the switch body to release the wires. These switches are common to most every gas cook top models no matter the brand. Without your model number I can not provide you with the manufacturers replacement part number. Change the burner ignition switch on the front of the gas valve for the burner with the problem and it will work fine.
Thanks for choosing FixYa,
Kelly
Mar 05, 2011 | Cooktops
30 in. JGP336 Gas Cooktop: We have a GE model # JGP933SEK2SS gas cooktop. ...
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
heatman101
May 18, 2010 | GE 30 in. JGP336 Gas Cooktop
Alarm code FC and F7, everyting works but the alarm keep come back.
Hi There
I have found the code for you and hope help this helps out.
F7 - E1 Common switch wire is defective Common wire (+5VDC) to latch switch, and to door switch is shorted to chassis ground or neutral. A double oven will have two of each switch and one common wire.
1. Check connections at control and at the latch switch and door switch.
2. If all connections are good, then check the individual switches as outlined for the F5 failure. 2 Digit Failure CodesThank You for writing to Fix Ya.
Best Regards Richard
Feb 18, 2010 | Cooktops
I have prolonged igniter activation even when a burner is lit. I have searched the possible causes for this and none mention a bad flame sensor. I assume the sensor is built into the igniter. Is that...
Your problem is a stuck igniter switch or a bad spark module.
Each surface valve has its own igniter switch. Turn off the gas. Remove the panel covering the valves to access the switches.
With the gas OFF,turn on all surface switches. Move the dial past the LITE setting. The switches should still be making the sparking sound.
Remove one wire at a time from each surface switch.
When the sparking stops,that last switch with the wire removed will be the bad switch. The one that needs replacing.
If you do not find a bad switch the main spark control module will have to be replaced.
Part # 71003385 Igniter switch.
Part # 71002783 Spark module.
Occasionally a igniter switch becomes dislodged from the correct position and can be re-seated. Look at the position of all switches before you do any test. Make sure they are all seated.
Nov 08, 2009 | Jenn-Air 34 in. Expressions CVGX2423 Gas...
Element on cooktop will not switch off
Probably the contacts at the switch are welded together. I suggest removing the switch and if found to be so, separate and clean with a small bit of fine sandpaper.
Jun 21, 2009 | De Dietrich 22 in. DTI305W Electric...
Broken selector switch
TURN OFF CIRCUIT BREAKER. Lift out cooktop, remove all machine screws holding the glass frame. Remove plastic knobs and lift glass top straight up. Make sure rubber gromits are not ripped or torn. Unscrew the small screws on the selector switch and then lift up and tilt over the small aluminum chasis holding the switches to expose the wiring connections. Pull off the wires and pull out the defective switch. Replacre switch, connect wires, re-seat switch chasis, and secure switch with screws. Carefully drop in the glasstop lining up the switch shafts and the rubber grommets. Secure the top with machine screws and drop back in the cutout.
Apr 18, 2009 | GE 30 in. Profile JP350 Electric Cooktop
The on/off gas switch keeps buzzing in the on position!
Each gas valve has its' own ignitor spark switch.
One or more of your switches has shorted out.
Remove the panel to access the switches. Remove the wires from one at a time until the sparking spots. That will be the bad switch.
Mar 25, 2009 | GE Profile JGP636 Gas Cooktop
Jp 989 switch replacement
not timely but no.
i have a dead switch, had to unhook it cause it kept tripping the breaker. 3 out of 4 work now.
can i buy 1 switch or do i need a whole new assembly. where to buy online ?
Aug 09, 2008 | GE 30 in. Profile JP989 Electric Cooktop
Stove top dual infinite switch
If the new switch is a substitute, should have come with instructions.
If no instructions, I would suggest matching the markings on the switch next to each terminal.eg, match terminal marking on old switch as L1 to marking on new switch as L1. The markings are industry standard and should match from old switch to new switch.
If you need further assistance, let me know
Regards,
reg501
Jun 24, 2008 | Cooktops
Cooktop fan switch replacement
1. Turn off the power at the breaker box.
2. lift off the air grill.
3. remove the two screws at the front of the control switch panel (escutcheon)..
4. slide the control panel forward until it disengages, then lift up to expose the switch assembly and wiring.
Jun 14, 2008 | Jenn-Air JED8230 Electric Cooktop
Cooktops Logo
69 people viewed this question
Top Gaggenau Cooktops Experts
Paul Carew
Are you a Gaggenau Cooktop Expert? Answer questions, earn points and help others
