Question about forbes.com Computers & Internet
Step down transformer burnt of forbes aquaflo water purifier.
Need to know the voltages outputs
Hi there we have a ALGORITHMIC TRADING PLATFORM
to implement, test and optimize your trading algorithms for free.
Do you have great trading idea but need help in implementation? Here is the answer http://empirica.io/.
Posted on May 30, 2016
Sanyo sound system built-in transformer amp usage
If no one has the specs on this transformer but you know the power rating, apply this formula: Power/Voltage= Amperage. It might not be a big help but it sure will put you in the right range. The other solution would be to obtain a schematic or parts list for the unit. Hope this helps!
Nov 30, 2013 | Sanyo Audio Players & Recorders
I recently bought a U.S. version Nakamichi 600 II cassette console (120V), and I accidently burnt its transformer out by a 220V mains supply. Now I need to replace this burnt out transformer better with a...
To match it with an other transformer, you have to know about its secondary voltages. Try to download its service manual by internet. It will have all details. It will be best to contact any expereienced service technician or to the authorized service center for Nakamichi.
Feb 24, 2013 | Televison & Video
What is the output voltage of the transformer in the system, mine is burnt so i need to change the transformer so i need to know the output voltage
Nominal Output Power (Total) -- 2.3 Watt
On the back of the right speaker where the power cable is connected there is a sticker where you can see the voltage the speakers are using. You should read there 120 V - 60 Hz 100mA.
You will have to use a voltage adapter from 120v to 220v. (found in electronic shops) that maintains the Voltage stability.
Regards,
Tariq Khan
Jan 15, 2013 | Logitech Speakers. S-120
Crosley CR24 transformer rating
As transformers are Safety parts they must be replaced by the excat same part or one that is approved by Crosley. You should not attemp to use another transformer unless it's approved by Crosley. Otherwise it could become a fire hazard.
You can contact them here:
http://www.crosleyradio.com/Support.aspx
Nov 17, 2012 | Crosley Cr42 Turntable
How to test for bad transformer
  1. To test a transformer you need to know what type of transformer it is first. There is a step up transformer which steps the voltage up and a step down transformer which steps the voltage down.
  2. You will still test the transformers the same way for step up and step down transformers. If it is a step up transformer apply the incoming power to the transformer or plug it up. Now take your multimeter and place it on the AC volt scale and test the voltage if the voltage on the data plate says the transformer should step up to 220 volts and it doesn't then your transformer is bad.
  3. Now repeat the same steps for a step down transformer. Plug up the incoming or primary power and test voltage on the outcoming or secondary side the voltage should step down to the proper value. If you don't read any voltage on the secondary or outgoing side then the transformer is bad.
  4. To read the voltage place the two meter leads on the secondary side, or the side you will plug your equipment into. If the secondary side is an outlet then place the two meter leads into the top two slots in the plug and read voltage. You also want to make sure the incoming power is working as well. Otherwise you will be reading a bad reading every time.
Dec 16, 2011 | Emerson LC320EM8 32 in. LCD TV
How to identify the matching transformer terminal by means of terminal resistance? and which terminals is for input or output?
Doing a resistance test on a transformer will not give the information you require as you will read very little, if any resistance. What you need to do is an impedance check and that gets involved. If it is a normally wound transformer, not an auto transformer, you can isolate which is the primary and the secondary windings. Unless the transformer is a multi voltage input unit, the primary side will have continuity through only two terminals. The secondary could be more than two if it is a multi output voltage one. If the transformer is a step down, the primary windings will be the thinner wired windings and vice-versa. To actually test the transformer, get hold of a transformer with about a 20 vac output and try it across the two terminals you have identified as the primary windings, you should ge a proportional voltage of the actual output. eg. with 20 vac input and a 2 vac reading at the secondary, the actual output would be 11 vac if your mains voltage is 110 volts. Take care that you are using the transformer at the voltage it is designed for, otherwise it will overheat and burn out.
May 11, 2011 | Kitchen Ranges
Hi .. I recently got a bose 321 home entertainment system. Unknowingly i plugged it to a 230 V main .The display in the DVD player came for a moment and then went off..I came to know that i need a 230V to...
Right now the Transformer in the BOSE system might have burnt out or it might be shorted out. It would be better to check with BOSE, but for burnt transformers you cannot claim warranty from BOSE.
If bose refuses to provide the warranty then take it to a TV repairing shop and ask them to change the Transformer so that it would support direct 230v....
Apr 19, 2011 | Bose (321GS) System
What should the output voltage be on the high voltage transformer be
Between 20K to 30K. Voltage drops with the age and condition of the screen.
Aug 26, 2010 | Ecoquest Flair Air Purifier
Light wont come on. Purifier wont work
When the high voltage transformer is working right, it will make the neon bulb glow.
You probably have a burned out high voltage transformer. That's what produces the ozone. Helpful hint...........the high voltage transformer is also the one used in bug zappers
Mar 14, 2010 | Ecoquest Flair Air Purifier
Hello i have a Sony Vaio PCW-W2 that i brought to canada from uk. how do i switch voltage to 110?
u can find voltage converter connectors......try using that....u can ask for travel adapters....hope u find them
Mar 08, 2010 | Sony Computers & Internet
Computers & Internet Logo
37 people viewed this question
Top forbes.com Computers & Internet Experts
David Payne
David Payne
Are you a forbes.com Computer and Internet Expert? Answer questions, earn points and help others
