Question about Ariston Technologies Washing Machines
How to remove front of Ariston washing machine AVD 129 SK
Hi, I have an Ariston washing machine AVD 129 SK and I would like to replace the door seal (gasket). However, I have encountered problems while trying to remove the front of the machine (in order to get to the inner retaining wire). My question is whether it's actually possible to remove the front on this particular model? I've managed to take off the door lock (interlock), but the front still won't come off. Can anybody tell me 1) if it's possible to remove the front and - if so - 2)how to proceed? Thanks
Take the top off,remove the soap bucket,take the screws off on the pc board/front cover. the top screws of the front pannel are usualy behind the display cover. the botom screws are behind the bottom plastic cover which you have to prey off with a screwdriver from the top side.
Posted on Mar 18, 2014
SOURCE: Door won't open
My Zanussi has an outlet filter that is accessible by a little door at the front. It gets clogged if not cleaned for a month or two. Then the machine can't drain and the door won't open. Removing and cleaning the filter should correct the problem. You'll need some sort of container to catch the water that will pour out after you remove the filter.
Posted on Feb 11, 2007
SOURCE: washing machine replacement door seal
It is held on by a spring that stretches around the outside of the seal. The seal simply hooks on to a small lip so all you need to do is start in one spot and push it down and away. Then just work it around like removing a bike tire until it is fully removed. Be careful of the spring. It is hooked together so it may unhook once some of the tension is removed and snap around.
Posted on Nov 17, 2007
SOURCE: Frigidaire washing machine collects water behinf door seal
Frigidaire has several mfr defects with their new front loading machines. The detergent/bleach drawer retains water, the door often leaks, water does accumulate in the door seal and the spin has broken twice on us and the machin is only 15 months old! Repair is contracted out by Lowes to independant repair companies, who demand payment, even when Lowes says it is covered under warrantee. What a waste of a large amount of money! We will NEVER purchase Frigidaire or recommend their products to anyone.
Posted on May 11, 2008
Coldcut
  • 1554 Answers
SOURCE: bOSCH WASHING MACHINE RETAINING SPRING FOR FRONT DOOR GASKET
it is very hard to get the ring on front load washers,
it is much easier to remove the top. bottom and the front control panel
then the door and support panel.
now you have access.
some times you have to remove the counter weight in some models before putting on the ring.
if you can do it without removing these items you are very very good.
Posted on Jun 04, 2008
This is a two person job. The spring part of the metal ring goes at the 6:00 position (note the groove on the metal part of the machine). Fit the ring into the gasket as much as you can on the hinge side. While one person uses pliers to stretch the spring, another person uses a flat head screwdriver to move the ring into the gasket groove. The trick is to stretch the spring as straight and close to the machine as you can or else the ring pops off and the gasket has to be reset.
Posted on Jun 25, 2009
Tip
How to replace the door seal on an Ariston or Creda washing machine
Hi.
The procedure is quite complicate, because the seal is secured to the front panel, and you will need to remove top panel, detergent drawer and access control assembly
  1. Disconnect appliance from power
  2. Remove the door, held by two screws located on the rear side of the lid.
  3. Lift the top panel, held by two screws at back.
  4. Undo the two screws joining the detergent dispenser to the inlet valve.
  5. Undo the two screws located at the front corners. So to release the fascia and dispenser.
  6. take out fascia and the dispenser alltogether and put it on one side. Take care to not disconnect wiring and do not drop parts.
  7. Release the retaining wire that keep the seal secured to the front panel. Look after it, you will need it again.
  8. Undo the two screws that hold the front pane. They are located on the front side.
  9. Remove the kick panel
  10. Behind the the kick panel you will find the two screws that will release the front panel, remove both of them.
  11. Disconnect the door switch conntector.
  12. Lift the front panel. You may need to help yourself using a putty knife.
  13. Remove the clip with two hooks inside, it is located about postion one o'clock. This will finally release the seal.
  14. Remove the seal and clean the area where you will fit the new seal.
  15. Start mounting the seal from the lower part on the right, at about four o clock. You will notice the seal matching.
  16. Put back the retaining wire usingf long-nose pliers to put the wire in tension.
  17. Reassemble the washer in reverse order.
Mark connector and keep screws ordered and separate while doing the procedure above. This replacement is suitable for an expert DIYer.
on Apr 08, 2010 | Ariston Technologies AWD120 13 lb. Washer...
How to change noisy bearing on Ariston AQXXF 129
inner and outer drum has to b removed replace the bearing kit 2 bearings one oil seal as kit
Aug 25, 2014 | Ariston Technologies Washing Machines
How do you remove the top cover ariston am xxl 129 washing machine
see the video and proceed according . God bless you
Oct 16, 2012 | Washing Machines
Replaced door seal now door is difficult to close.
Sometimes, it is hard to close door after fitting a new seal.
Make sure you have got it fitted correctly round the flange on the front of the cabinet, and that the retaining clamp is securely fastened.
Try smearing the door glass with washing up liquid, this can help to close the door more easily
Please rate my solution.
Thankyou.
Feb 13, 2010 | Ariston Technologies Washing Machines
Hi I have an Ariston Aqualia front loader. It has
You could try mild solution of bleach to the drum, perhaps replace door boot seal..
Nov 04, 2009 | Vacuums
How do I remove and then replace a new door seal on my hotpoint WD420 washer / dryer
First switch off electrics , Remove door interlock , leave wires on .remove soap dispenser,remove front panel with controls 3 screws top of machine 3 screws bottom remove front casing you can now see door boot. remove sring note how boot came off refit is oposit to this noting top / bottom of seal ..Hope this some help-
Oct 03, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
Washing Machine Door will not open
it is poss that you pressure system has not released, and this can keep the door closed. Unplugging it will not cure this fault. It is also poss that you have a blocked filter or waste. Unfortunatly has you are older people I would call an engineer
Jun 23, 2007 | Ariston Technologies AW129NA 16 Lbs Front...
Washing Machines Logo
405 people viewed this question
Top Ariston Technologies Washing Machines Experts
Darren Moxam
Darren Moxam
Gerry Harvey
Gerry Harvey
Are you an Ariston Technologies Washing Machine Expert? Answer questions, earn points and help others
