Question about Exercise & Fitness
Realistic dx-380 schematic req'd - Exercise & Fitness
  • Alex Talkachoff
    Alex Talkachoff Mar 20, 2014
    Require circuit diagram for Realistic DX-380 short wave radio
I need Realistic schematics for 31-2087
do a search for " realistic 31-2087 schematic ". this should give you what you are looking for. Also" radio shack archives".
Jun 08, 2016 | Radio Communications
Idealistic graphic equaliser model 31-9081
Connect your Denon outputs to the Realistic main inputs.
Connect your Realistic main out to the Rotel tuner in.
Connect your Technics out puts to the Realistic Tape 1 inputs.
Connect your tape 1 out puts to your Rotel cd inputs.
And you should be good to go.
May 02, 2016 | Audio Players & Recorders
Need schematic diagram
A schematic, or schematic diagram, is a representation of the elements of a system using abstract, graphic symbols rather than realistic pictures. A schematic usually omits all details that are not relevant to the information the schematic is intended to convey, and may add unrealistic elements that aid comprehension.
What is schematic diagram definition and meaning
Feb 05, 2016 | Computers & Internet
Installing a echo board into a Realistic 5 pin mic.
95% of realistic mics are 5 pin It would be easier to install it inside the radio.Better than that you buy a noise toy that hooks to the rear of the radio and then your antenna hooks to the toy.
Mar 07, 2014 | Galaxy Radios DX-2547 40-Channels Base CB...
I need the Realistic SAF-40B schematic
Hi Trini,
The only people I know that deal with the Realistic Brand, are Radioshack or similar store.
They may or may not have what you're looking for.
Cheers,
Peter
Feb 20, 2013 | Kenwood Radio Communications
I have a crosman model 380, .22 cal pellgun that leaks when the co2 is inserted and punctured. I cant see any seal or O-ring at the puncture point. What is missing and how can I fix the problem. Matt
I have the same problem and have dealt with guns for 40 years !
I am glad to see that the other folks have some realistic and innovative ideas of how to remedy this problem.
I went to Lowe\'s on a "tip" and found some very small \'O\' Rings for $ 0.87 for two and I am experimenting with them. The first try I couldn\'t crank the screw down far enough to even puncture the CO2 Cartidge. Using a larger screwdriver I finally managed to puncture the cartidge, unfortunately it still leaked but waas a much smaller leak.
Still experimenting.
I am going on-line to locate the Model 380 Schematic diagram which is where I ran int this site.
Good luck all !
Aug 17, 2011 | Crosman (4032)
Trying to find realistic sta 2000d receiver owners manual
Try going to Realistic.com They usually have schematics and manuals.
May 09, 2011 | Audio Players & Recorders
Cobra 150gtl dx / can not find - D38 - ON SCHEMATIC
Check out this web page .... it will give you ALL the details that you need
http://cbtricks.com/radios/cobra/150gtl_dx/index.htm
Apr 06, 2009 | Cobra 150 GTL DX Base CB Radio
Need driver for DX-UBDB9 for Vista.
http://www.dynexproducts.com/searchadv.aspx?IsSubmit=true&SearchTerm=+DX-UBDB9&SearchTerm_Vldt=[req][len%3D2][blankalert%3DPlease+enter+something+to+search+for!]&SearchDescriptions=1&ProductTypeID=0&SectionID=0&ManufacturerID=0&DistributorID=0&ShowPics=0&MinPrice=&MinPrice_vldt=[number][invalidalert%3DPlease+enter+a+valid+currency+amount%2C+e.g.+10.00+without+the+leading+%24+sign!]&MaxPrice=&MaxPrice_vldt=[number][invalidalert%3DPlease+enter+a+valid+currency+amount%2C+e.g.+10.00+without+the+leading+%24+sign!]
Sep 18, 2008 | Computers & Internet
Exercise & Fitness Logo
41 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
